Question about Husqvarna Garden
I have a husqvarna residential cz4217...our son bought it a few yrs ago and gave it to me when he moved. It has been sounding like a vehicle that needs transmission fluid when you work the arms. Now the right arm on it wont do anything. Any suggestions?
  • 81 Answers
SOURCE: HYDRASTATIC TRANSMISSION DOESN'T MOVE
Far as I know the warranties are not transferable. Some hydrastatic transmission fluid can be checked by removing the battery and underneath there is a place to put the fluid and to check it. But not all models or makes gives you this option.
Posted on Jun 22, 2009
bargainbin2
  • 123 Answers
SOURCE: deck tension arms not in proper alinement
Here ya go.
Posted on Oct 03, 2009
SOURCE: How do I get the rocker arms to move?
You need to put your hydraulic pump in gear and the lever that runs the hydraulic outlets will run your rockshaft it might not go down if there is no load on the 3-point.
Posted on May 08, 2010
  • 112 Answers
SOURCE: I have 2001 Husqvarna lawn tractor model YTH1746 wnt go into gear
those fluid drive transmissions fail on quite a few brands as they all use the same ones....replace the trans...they are expensive but still cheaper than a new mower.
Posted on Jul 21, 2010
kel1guy2002
  • 3740 Answers
SOURCE: I have a 420 riding
Hi Sid I am Kelly and welcome to FixYa,
Let me just state what I would do in the shop to revive your been resting for 6 years tractor.
Knowing that corrosion has formed in part of system from condensation I would:
1. Purge the entire hydraulic system under pressure by maintaining a good fluid level in the reservoir and pump everything in the system out after loosening the return line substantially and catching the fluids. (You have to wrap the loose connection with a denim cloth several wraps to keep from spraying fluid everywhere.)
2. Purge and FLUSH the trans-axle. If you have an external filter replace that. If you have an internal filter you have to open it up and clean out the housing.
3. The control valves probably all need some TLC and cleaning.
Here is the problem... due to the long non-use period and the corrosion that has manifested in the system ball seat type valve will get micro debris in them and that does not allow hydraulic valves of any type to operate properly. The Hydrostatic drive has springs, balls and flappers in it that are subject to the exact same micro debris issues. What you really need to do is purge purge purge.
After you purge and use it for a month.... I would recommend yet another purge and filter(s) change.
It is tough to tell you exactly what to do because each hydraulic component is affected in some way so, the only way to really make sure they are functioning properly is to remove and clean them.
Here is what I do... I have a short piece of hose I use to listen to components under pressure like a steth-0-scope. If it is making noise.. when in a neutral configuration I remove it and clean it up. The only one you can NOT use this line of thinking with is the pump.
The Hydrostatic drive is usually the most problematic after a long period of use. Especially the reversing valve.
I am sure if you purge the system your going to shocked at the color of the fluid you drain out.
What ever you do.. do NOT use solvents or fuels under pressure to "purge" the system. Both can do more harm than good. If you have something apart; B-12 Chem-tool works really well as does carb cleaner. Both are quite flammable so keep that in mind.
I actually did this for a relative who inherited a unit that sat for 9 years. To get everything up 100 % took me about 2.5 hrs a day for 5 days and one hiccup after that. It works fine now but I will tell you if a customer came to me and asked what it would cost to do a "return to service" job after it sat for 5 years or more they would be stunned at the labor cost. If you have the time to do it right it really is worth the effort.
I recommend you check all bearings you have access too for roughness also. Everything could be fine for 3 or 4 days and then you start having bearing failures.
Thanks for choosing FixYa,
Kelly
Posted on Apr 01, 2011
Why won't cz4217 not start with key turn starter
check brake and safety switch some wont start unless you are holding the brake
Aug 06, 2014 | Husqvarna Garden
Frigidaire dishwasher model fdb1500fls2
Sounds like the capacitor on the motor is bad,
May 26, 2013 | Dishwashers
Red/white x over sound icon lower left/ installed new audio driver it worked earlier today then quit/ no audio device installed
the problem is your using a toshiba. I bought one several yrs ago and in just a few yrs things stopped working. first the sound wuit, then usb ports stopped working then when booting up the laptop it asked for a non existant password. finally i just tossed it out
Mar 07, 2011 | Toshiba Satellite U305-S5097 Notebook
.i used to have get good bright colored pix but
Try removing the print head again, removing the ink and re-cleaning the print head. Once it has been cleaned leave it to air dry for a few days before returning it to your printer and make sure the ink cartridges are fully clipped in. Let me know how you get on.
Mar 01, 2011 | Kodak ESP 5 Printer
The boiler sounds like it wants to start but it does not startup .that is the only information the customer gave me over the phone.we installed the boiler about 2 years ago.
try cleaning the flame rod and igniter with a cloth (do not use sand paper or emery cloth). Look for evidence of a water leak inside the unit.
Feb 02, 2010 | Noritz 6.3 Gallon Residential Tankless...
Looking for manual for 917375810
Here it is,Just save it to your pc or print it out
http://www.oscar-wilson.com/MANUALS/HUSQVARNA/6522SL%20(96143000800).PDF
Please rate this a fixya
Feb 03, 2009 | Garden
Samsung Side by Side Refrigerator RS2556SH - Making loud noise
Hi, had the same problem with my RS21DCNS engineer came and made a modification to drain hole (made the hole bigger!) this allows for a little more ice to form without causing the horrid noise. A new backplate was ordered as all new models have a larger hole in the backplate already. It only takes a few mins and it under guarantee if you bought less than 2 yrs ago, but you will have to empty fridge side to allow them to get to inside at the back. Good luck.
Sep 17, 2006 | Samsung RS2630SH Side by Side Refrigerator
Garden Logo
183 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
