HP officejet 5610 all-in-one. Insists there is a printing paper jam - there is not. Also when I drop the ink load door no inks come to that spot.
  • 3,037 Answers
First try resetting it by unplugging it for 5 minutes, let me know how this goes or whether you tried this already.
Also try disconnecting it from the computer when you do this.
please get back to me and I would be glad to help you until this is fixed.
Posted on May 06, 2008
  • Benjamin Patri
    Benjamin Patri May 07, 2008
    Please don't forget to let me know your thoughts about my solution.
    If your problem is fixed, please rate this solution as that is one of the biggest
    aspects of how this website works and in order to receive any credit in
    helping you, I need to be rated.
    Otherwise, let me know if you have further questions and I would be glad to help.
    Thank you
    Master:
  • 555 Answers
A User Manual with troubleshooting steps for your printer can be downloaded here.
Problem with printer or ink system
PDF]HP Officejet Pro X476 and X576 MFP Series ... - Parts Now
www.partsnow.com/.../Officejet%20Pro%20X476%20X5...
Parts Now LLCFigure 2-6 Printer status report-determining genuine HP ink usage . ..... Thesecartridges are linked by flow connections to the rest of the printbar and supply the ink..... The left door can be opened for jam clearance and has a hall effect .... The document feeder will not function when the document feeder cover is open.
db:: 4.32::Printer door will not close after printing 8p - Hivmr
www.hivmr.com/db/8p83f78d97fk8c883x9p9za3mf993scf
On the 50.8 error message, if power cycling doesn't fix the issue you may need to ...Opened printer cartridge access door and removed paper. ... HP Officejet Pro L7580, the latch to the ink cartidges broke, so the door won't close. ... Can not close the printer door on my HP B210a, after cartridge replacement need help?
Re: Do u need Help? -HP All-in-One's(Officejet,Psc's)
www.fixyourownprinter.com/posts/28357
Also, when reinstalling the HP it does print a test page, but will not print from ...Encoder Strip has been cleaned with water (had some ink residue). ..... when opening the door the cartridge does not move to the middle so i can remove it, clean it ...... Iopened the covering part of the scanner (with the glass) nad cleaned all the ...
HP Officejet 6210- repeated ' FixYourOwnPrinter
Dec 28, 2015 | HP Officejet 6600 e-All-in-One -...
HP 5610 printer won't print
Unplug this beast. Take the old ink cartridge out and re-insert. Also, check for any other jammed papers that need to be removed. Then turn this beast back on. See if that does anything old chap.
Feb 04, 2010 | HP Officejet 5610 All-In-One InkJet...
Paper jam
Found this on the HP Web site.
Issue:
The product stops printing and the error message 'Paper Jam: Clear jam, and then press OK ' displays on the product.
HP Support
GOOD LUCK!
Oct 16, 2009 | HP OfficeJet 6210 All-In-One InkJet...
My 5610 all in one series keeps telling me that there is a paper jam. I have checked and there is no paper jammed in the printer. It won't reset. It keeps saying paper jam. Help!
Check to make sure both ink cartridges are installed properly. I don't know why it says "paper jam" when the cartridges aren't properly installed, but it does.
Aug 25, 2009 | HP Officejet 5610 All-In-One InkJet...
2 small rubber pieces have fallen out. any idea
Those pieces go on the clean station and can easily be replaced. They each fit over a stud where the printhead parks and just press on.When they are missing the ink will dry out on your ink cartridges and the machine won't be able to clean them properly.
Jul 24, 2009 | HP Officejet 5610 All-In-One InkJet...
CARTRIDGE ERROR: REFER TO DEVICE DOCUMENTATION TO TROUBLESHOOT
First pull out ink cartdge from printer.
Then check there is any paper jam .Clean ink cartrdge from dust and ink powder also check there is any leakage in inkcartrdge.
Then put again ink cartrdge in its position.
Jun 20, 2009 | HP Officejet 5610 All-In-One InkJet...
My Officejet 5610 will feed the paper but no ink will be on it
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab103
Jun 17, 2009 | HP Officejet 5610 All-In-One InkJet...
Printer will not print after reinstall of software to macbook
yes ..if the sensor detect that there's is no ink or low ink..it display an error on the screen ..
to determine the status of the ink..
goto your desktop ..
click the printer driver software and select ink status..
good luck.
May 20, 2009 | HP Officejet 5610 All-In-One InkJet...
Just bought the product and it is already not working.
Check the paper setting in tray. May be slanted and causing it to pull paper in un-even, this will cause jams. Old, wrinkled paper will also cause same problems.
Feb 12, 2009 | HP Officejet 5610 All-In-One InkJet...
27 people viewed this question
jasbo
jasbo
