Question about Mitel 5340 IP Phone
We have a Mitel 5340 IP Phone at a hotel and we have it set up to forward calls from the front desk to rooms, etc. One of the rooms can't make outgoing or recieve any calls and when we look at the room on the phone, it says "LOK" instead of "IDLE". Is there any way to unlock the phone?
    Sergeant:
  • 378 Answers
I believe the room phone is off hook.
Posted on Apr 22, 2011
Is phantom calling rooms 1am to 6am there are no alarms set all cleared.
Pull the plug on the whole system for 5 minutes and plug it back in and it will reset its faults.
Jan 04, 2016 | Mitel SX-50 SX50 MS-55 PBX PHONE SYSTEM...
Trying to answer call in hotel back office Mitel 5212 phone frm Superconsole phone at front desk. How do we do that?
Attendant Directed Call Pickup
Description
The attendant can perform a directed call pickup from the console. This will permit calls to be retrieved before the recall timer expires or if calls have been transferred to the wrong extension.
Conditions
None.
Programming
Assign an access code to Feature 09 (Directed Call Pickup).
Enable COS Option 218 (Directed Call Pickup).
Operation
• Dial the Directed Call Pickup code.
• Dial the extension number of the ringing telephone - the call is connected.
Apr 24, 2011 | Mitel 5212 IP Phone
No dial tone on Mitel 5340 IP Phone. The message on the phone is DHCP: Discovery.
The network isn't configured properly for your phone to boot up. You should contact your phone vendor or system administrator for support.
Apr 05, 2011 | Mitel 5340 IP Phone
What does option 128 missing mean? On MITEL 5340 IP Ohone
It means that your DHCP server on your network is missing the options to allow your phone to boot up. After a month (time on this message), I hope you've managed to get the issue resolved. If not, I hope you've fired your IT support team - they should be able to get this resolved quickly.
Sincerely,
Mark
Feb 21, 2011 | Mitel 5340 IP Phone
Handset on Mitel 5340 IP phone with bluetooth has no dial tone but has dial tone on speaker. Bluetooth signal is fine. Help.
Are you referring to the Mitel Cordless handset or headset? The handset and headset must be paired to the module on the back of the phone. Press and hold the button until the display indicates pairing. Then press the Answer button on the handset or headset.
Jan 07, 2011 | Mitel 5340 IP Phone
My Mitel 5340 ip phone will not turn on. i've changed the cable's and it still won't turn on. what could it be?
Is it plugged into the correct port (not the PC port)? The phone requires Power Over Ethernet - this is either done with a PoE Switch or PoE injector. This should provide power to the phone so it can boot.
Dec 14, 2010 | Mitel 5340 IP Phone
My Mitel 5340 will not go to voicmail and keeps ringing
You need to set this extension up in the Call Rerouting form in the PBX. Program the First alternative to go to the voicemail extension.
Oct 29, 2010 | Mitel 5340 IP Phone
We have issues with the ringer..
it seams that you have set the ring to silent mode to change the ring type go to menu --> settings --> basic --> ring type --> and select the ring type the steps may not be the exact but they are similar
Mar 31, 2010 | Mitel 5340 IP Phone
Mitel superconsole 1000
Yes, there are things you can do to clear the locked out phone.
~ The locked means something is wrong with the phone -or- wiring to the room from the Mitel system...
Locked out is like leaving your phone off hook too long, you get that irratating beeping noise, then when the beeping stops, the phone is locked out to save power going to the set.
Ok ~ the first thing I would try, go to the set and play with it, hang everything up and test to see if you can get dial tone... the next thing is change out the telephone set, and test.
If you changed out the telephone set, and there is still a trouble, there maybe a wiring issue, in which case you will require a cable tech to test connectivity...
Mar 23, 2009 | Mitel Lands Phones
Mitel 5340 IP Phone Logo
319 people viewed this question
Top Mitel Computers & Internet Experts
Martin Murray
Are you a Mitel Computer and Internet Expert? Answer questions, earn points and help others
