Question about HP LaserJet P2015n Printer
The paper feeder is not working. When the printer tries to get the paper, you can hear it trying but the paper won't feed. The printer is on, everything else seems to be working and a message of "out of paper" shows up on the computer screen. I load more paper, click ok and same thing happens.
  • HP Master
  • 1,684 Answers
The part you need is RK-P2015, this is a complete pickup roller kit for the P2015 printer. Do a Google search for this part number. The roller kit takes about 5 minutes to install and should get you back printing again.
BuddyMc
Posted on Dec 09, 2010
    Problem Solver:
  • 3 Answers
Try cleaning the pick-up roller.. or replace it with new one
Posted on Aug 26, 2010
2 Suggested Answers
SOURCE: Auto document feeder
Did you make sure the tape is removed inside the Document feeder,or maybe you need to check to see if anything is stuck in the rollers. Open the door (if you have not already done so) to the document feeder and you will see pictures on the inside showing how you can remove and/or change the roller (make sure everything is put back as the picture. Good luck, I hope that is all that is wrong with it.
Posted on Dec 28, 2008
Epson 810 automatic feeder won't feed
do you let the paper get pulled by it'self? Maybe try to push it and maybe it will grab it better to pull through...if not try a shop to fix or buy new one.
Sep 09, 2012 | Epson Artisan 810 AllInOne InkJet Printer
Lexmark X4530 won't load paper to copy
Leading cause of paper jams is debris / foreign objects that accidentally fell into the paper feed area. Please try this approach to fix the problem:
  1. Remove the sheets of paper from the feeder.
  2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
  3. If you're willing and physically able, you may also carefully turn the printer over. Any debris should just freely roll out from the feeder.
  4. If feeder is clear, place the printer on the table. Open the printer cover and remove the cartridges.
  5. Check the cartridge area for any obstructions in the paper path.
  6. Close the printer cover.
  7. Re-brick your printer by pulling out the power supply - the black box where the power cord is plugged into. Re-plug after 30 seconds.
  8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again to verify that the problem is fixed.
Mar 16, 2012 | Lexmark Office Equipment & Supplies
How do I clean the rollers on lexmark x2500
You can try to clean the rollers with a cotton bud to reach it.
Leading cause of paper misfeeds is debris or foreign objects that accidentally fell into the paper feed area. Grab a flashlight and look into the feeder for any obstructions.
Dec 24, 2011 | Lexmark X2500 All-In-One Printer
My Lexmark printer 2600 series won't print. It pulls the paper towards the right but won't feed it. How can I fix this?
Leading cause of paper jams is debris/foreign objects that accidentally fell into the paper feed area. Please follow steps below to fix the problem:
3. If you're willing and physically able, you may also turn the printer over. Any debris should just freely roll out from the feeder.
4. If feeder is clear, place the printer back on the table, open the printer cover and remove the cartridges.
5. Check the cartridge area for any obstructions/debris in the cartridge carrier's path or the paper path.
6. If cartridge area is clear, close the cover.
7. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print a document again to verify that the problem is fixed.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 03, 2011 | Lexmark X2600 InkJet Printer
Lexmark X85 won't feed paper. When trying to
There could be something in the paper feeder that's blocking the paper path. Please follow steps below to identify and fix the problem:
2. Grab a flashlight and look inside for any debris.
5. Check the cartridge area for any obstructions/debris that could cause this error or problem.
7. Unplug and re-plug the printer into the power outlet to reset it.
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again.
ns Serif"'>6. When the printer turns on, reinsert one cartridge first.
7. Close the printer cover and check for any errors.
8. If no error appears, reinsert the other cartridge. Close the printer cover.
9. Replace whichever cartridge is causing the error to appear with a new cartridge.
Jul 11, 2011 | Lexmark X85 All-In-One InkJet Printer
When trying to print the paper won't feed through. It will on the left side (looking at the front of the printer) but won't on the right preventing it to print. I just bought and replaced both...
There could be something blocking the paper path. Remove the sheets of paper from the feeder. Grab a flashlight and look into the feeder. Make sure there are foreign objects or debris that could cause this problem.
May 13, 2011 | Lexmark X4650 InkJet Printer
Automatic document feeder not working
Open the adf and rotate the pick assembly till you hear a click and then take a coin and run it up and down against the separator pad and then see if the adf picks the paper or not.If this does not work try this *# 329 and scroll thru and select adf pick test if that fails its time for you to get the printer replaced or get an upgraded printer
May 29, 2009 | HP Officejet Pro L7650 Printer
IBM 1422 not feeding 8 1/2 x 11 paper through multipurpose feeder
Go into the paper menu and set the multipurpose feeder paper size to letter. It will work if the paper size is set correctly for the MPF.
Apr 30, 2009 | IBM Infoprint 1422 Laser Printer
Hp paper feeder wont thu printer
paper feed rollers wont feed paper through and also paper tray is empty prompt comes up when there is paper in the tray tried small amounts of paper and still says tray is empty
Dec 27, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Paper feeder
Check the paper fed tracks- make sure there are no debris in the channels. Can you hear the feed system working or is it not running?
Jun 06, 2007 | Brother MFC 420CN All-In-One InkJet...
HP LaserJet P2015n Printer Logo
220 people viewed this question
Seeker5211
Seeker5211
