Question about Pride Celebrity X 3-Wheel Electric Scooter
My scooter blinks 7 times indicating the speed pot in manuale how do i fix
  • 944 Answers
Please don't worry this can be easily solved.This is an error.Technically calling it has Flash Code #7
Flash Code #7 is caused due to Throttle Pot or Speed Pot Error
Click here to download the repair manual PDF.
Since the steps are diagrammatic,i will give you the PDF,Please follow the PDF.The solution is in page no 16.
post a comment for further assistance.
thank you for using fixya have a nice day:-)
Posted on Aug 26, 2010
My status light blinks 7 times on my pride scooter how do I fix it
Hi 7 flashes ( SPEED POT ERROR ) possible speed control pot ::: wig-wag. control lever ,is ,faulty or it's possible the computer (CONTROL BOX ,) is Faulty...Get in touch with pride mobility ,..www.pridemobility.com.au .. Cheers
Jan 14, 2017 | Pride Health & Beauty
Light is blinking a 7 fault code, what does this fault code mean.
According to the owner's manual for this scooter, flash code 7 indicates a speed control lever fault. This is the lever that you push to go forward and reverse. The lever is attached to a throttle potentiometer to control the speed of the scooter. The lever has to be in the middle or neutral position when the scooter is turned on, if not, you will get a 7 flash code. If the throttle potentiometer is damaged you will also get a flash code 7.
You can try to adjust the throttle pot or try manipulating the neutral position and turning the scooter on and off until the computer sees neutral. This is a potential work around and will cause the scooter to creep forward when running with hands off the throttle lever because there is no zero setting. I usually just replace the throttle potentiometer and this solves the problem. I hope this helps.
Oct 23, 2014 | Drive Medical Spitfire Travel 4-Wheel...
I have a IMC Heartway Gypsy and the power light blinks 5 times and the scooter won't run. I have just replaced the batteries. Is there list of what each code means? Thanks
1. Battery low
2. Battery charge is too low
3. Battery voltage too high or charger still connected
4. Current limit. turn scooter off for a few minutes and then on
5. Brake lever in freewheel mode
6. Throttle lever not in centre on switch on or faulty
7. Speed pot or throttle pot error
8. Motor volts error
9. Other internal fault/control fault
Hope that helps you.
May 18, 2014 | Pride Mobility Products Go Go Ultra X 3...
That is the speed pot
Hi , the throttle pot , not the speed pot, that is the lever is fixed to, you push to go forward or backwards, please can you tell me the make and model of this scooter ?
Regards
Rob
www.gewizrepairs.co.uk
Feb 28, 2014 | Pride Health & Beauty
How do you fix the 7 beep on go go
Jul 26, 2012 Yup you got a code seven failure code, speed pot malfunction . What pots typically do is that they oxidise. This pot is a variable rersistor that opeates between 0 - 30k ohms. When tuning the pot it shoud ram up and down smoothly. To test for this
You may also need a VOM meter only $9
http://www.amazon.com/Mastech-YG188-Pocket-size-analog-multimeter/dp/B00064CH6A/ref=sr_1_8?s=hi&ie=UTF8&qid=1339024102&sr=1-8
Disconnect batteries from the scooter. Simply attach the multimeter to the pots terminals, select correct ohms scale and watch the needle. Th needle when turning the pot should move gracefully up to 30k down to zero as the pot dial scooter speed increases. Failure is detected when the needle jumps around, the oxidation causes the pot to connect inteermitently. USE CRC CONTACT Cleaner to get the oxidation out of the pot. The potss are not sealed so there are little holes you can spray into. Use liberal of cleanner.
Jul 27, 2012 | Pride Go-Go Ultra X 3-Wheel
Hello, my scooter is fully charged, all the lights and horn are working. But it will not move forward or backward. The small green light flashes 7 times and stops for a while before flashing again. The...
outback you will have to get a new speed pot and replace the old one. Contact the provider where you got your scooter to see if they will fix it for you Hope this helps
Apr 16, 2011 | Health & Beauty
No forward, only backward
Hi. If the light flashes 7 times, it has a speed controll fault. It might be the throttle lever ( wig wag ), or it might be the speed pot that controls your top speed.
Try moving the throttle lever ends up and down while you are driving the machine. Doing this wont fix it, but it will highlight the problem, if the throttle lever is faulty. Also try moving the speed pot back and forward a few times.
Good luck. Neil.
Jul 17, 2010 | Pride Mobility Products Hurricane PMV...
7 bleeps on my GO GO ELITE TRAVELLER SCOOTER
Hi. 7 beeps is fault code for a faulty speed potentiometer. Might also be a broken wire on the pot or a faulty connector. Most times, a new pot will fix the problem.
Good luck. Neil.
Jul 08, 2010 | Pride Go Go Elite Traveller Plus HD 4...
Golden Companion Scooter not moving - diagnosed via owner manual
Hi. Many scooters will display this fault code if the potentiometer is not exactlly centred when you turn on the key. The pot is not always faulty. Some scooters also have a smaller additional pot to controll the speed. If this pot is faulty it will cause the same fault code. Any other switches such as indoor/ outdoor switches. I have had a few machines fitted with curtis controllers where the fault is in the controller.
Check the wiring and plugs and connectors.
Good luck. Neil.
May 09, 2010 | Golden Technologies Companion II Travel...
Pride Celebrity X 3-Wheel Electric Scooter  Logo
696 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
