Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Cannot remove cover plate to change ice dispenser motor on a whirlpool GS6NBEXRS02 side by side refridgerator
  • 2 more comments
  • kenitzerllko Aug 26, 2010
    Drifter,
    Great advice and website. One more question, does the motor need to come out through the front drink area or through the top of under the ice holder if through the top how do I get that cover plate off under the ice holder? I started to pry butr it looks like it will break and looking at the diagram the motor screw come out through the bottom which I wouldn't have access that way.
    Thanks
  • kenitzerllko Aug 27, 2010
    I hope that's not the advice you give everybody, how to do the repairs the right way is what I'm talking about. I feel it was a waist of my six dollars to even hear from you
    I acceped your advise sorry it say I didn't
  • kenitzerllko Aug 29, 2010
    Great forum and help thank drifter and Kelly
  • Whirlpool Master
  • 3,740 Answers
Hi and welcome to FixYa. I am Kelly. Download this job aid: https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/8527f904cc8ea8cd85256b5800672333/$FILE/4322658A.pdf and see pages 20 - 22 on how to remove and re-install the motor. It is done from inside the door. If you still have questions after reading and reviewing the manual just respond here and someone will help you.
Thanks for choosing FixYa.
Kelly
Posted on Aug 28, 2010
  • 22,265 Answers
Cut a hole in it then when you have finished changing the motor ,make a plate up with a piece of plastic and screw it on
Posted on Aug 26, 2010
  • 4,924 Answers
The front dispenser cover can be removed by inserting a screwdriver blade into the two slots on the bottom side of the cover. By gently turning the blade, the cover will snap free at the bottom and can be slid upward to be removed.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=244301&diagram_id=38351
here you will find some diagrams that might help you ..and parts too..
  • Catalin Turcu
    Catalin Turcu Aug 26, 2010
    after removing the screws the cover will snapp out of the bottom ..and after that will slide to the top ...
    is it the cover under the ice tray or the drink dispenser cover you are talking about?
I need to replace spring in In-Door-Ice Dispensing System. How do I get to it. taking the face plate off?
The start device on some models of refridgerator for maytag and whirlpool have been recalled. If your appliance was manufactured in the last 5-10 years you may be having an issue with this component. Mine recently caught on fire at this device that is located near the compressor. If you would like to be a part of the petition for a recall on this appliance contact me at jboooor@hotmail.com
Jun 10, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool refridgerator is leaking water on the freezer side (side by side refridgerator) onto the floor. The ice machine was overflowing with ice and has frozen ice in the ice maker that won't budge. We...
WAS IT LEAKING FROM INSIDE THE FREEZER OR FROM BOTTOM OF FRIDGE? ONCE IN A WHILE YOU NEED TO TAKE OUT THE ICE BIN AND DUMP ICE OUT AND CLEAN IT. HOW CAN THE ICE MACHINE OVERFLOW WITH ICE WHEN THE ICE IN THE TRAY WON'T BUDGE? NEED CLARIFICATION. SOUNDS LIKE YOU EITHER HAVE A BAD ICE MAKER MODULE OR THE SOLENOID FOR THE ICE ON THE WATER VALVE IS BAD.
Jan 24, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool model ed5chqxkbo1 wont cool
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} That is usually the evaporator fan motor ($30).
Check to be sure you can get a replacement fan first, they last about 4 - 5 years. Can get from a parts supplier or electric motor company.
Unplug fridge. Located usually in top of freezer behind a vented cover plate. Remove cover, remove screws holding fan in, may have to cut wires. Replace with new motor, make sure the fan pushes air into the freezer area and doesn't spin backward drawing air from the freezer area.
Oct 31, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
I need to replace the torsion spring on the ice dispenser door. I have a new spring but can't figure out how to take the front cover housing off in order to get to the spring. Thanks, Jeff
there should be two small holes on either side of the face plate,
push a small nail in those the face plate will pull off
once you have the face plate of, it should be fairly obvious how to remove the padles and springs
hope this helps
Oct 24, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool side by side model # ed25uexhw00
Open the door and hold the door switch down and try the ice dispenser. Do you hear any thing. Take all the ice out of the bin and try. Anything? Take the bin out and try. Anything? The motor is behind the back cover where the bin sits. See if you get power to it using a voltmeter. If your are, probably bad motor. If not dispenser switch.
Sep 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
How do I remove the trim around the ice maker/water dispenser on My whirlpool side by side refridgerator model # GD2SHAXLB02
The trim is snapped into place. Start at a corner and gently pry. one tab at a time.
Thanks for using FixYa - a 4 THUMB rating is appreciated for answering your FREE question.
Sep 12, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerator making too much ice, not dispensing the ice
You need to replace the dispenser motor.
It is located under the dispensing unit INSIDE the freezer door.
Remove the two screws hold the cover and replace the motor.
Sep 05, 2009 | Whirlpool GS6NBEXRB Side by Side...
How to repair the ice dispenser door on a whirlpool refrigerator
If you will look on the bottom of the dispenser cover you will see 2 notches on the left and right side. carefully pry the cover off using a flat tip screw driver. then you will see a white switch plate that is either held on with latches or 2 srews depending on model. once this is removed you will gain access to the dispenser door.
once you gain access I think you will find the hinges for the dispenser door are broken off. if so you will need a dispenser door repair kit form whirlpool part # 8201756 this kit includes new door and hinge repair kit. this is something you can do yourself if you are pateint and pay lose attention to detail. otherwise I would recomend a god servie company. thanks for using FixYa Peyton
Feb 18, 2009 | Whirlpool 21.8 cu. ft. Side-By-Side...
GS6SHEXMLoo side by side ice dispenser not working
On advice from the tech I removed acess door. It was covered by frozen moisture.
I removed the motor it was full of water. I verified 120 volts at plug to motor from control
by depressing the door switch and ice dispenser lever at same time. The motor ohms out
but because of amount of water removed from it I am going to replace it and see what happens.
Aug 05, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
463 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
