Sparked and now does not get cold - Heating & Cooling
  • 43,501 Answers
Hi,<br /> What sparked?? indoor unit or outdoor??<br /> High voltage or low voltage???<span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN"> </span><br /> <span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN">Here is a tip about troubleshooting your air conditioner...</span><br /> <span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN">There are many things that can cause your air conditioner not to cool&hellip;<br /><br /><a rel='nofollow' href="http://www.fixya.com/support/t4975332-c_run_only_humming_noise_when_turned" target="_blank">Air Conditioner</a> Trouble -Review the <a rel='nofollow' href="http://www.fixya.com/support/t5003406-compressor_failure_sends_out_hot_air" target="_blank">Possibilities</a> <br /><a rel='nofollow' href="http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi" target="_blank">http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi</a><br /><br />heatman101 <br style="mso-special-character: line-break" /><br style="mso-special-character: line-break" /></span><br />
Posted on Aug 26, 2010
Where does a cold start sit on a chev spark 0.8 2008 and can that cause it not to start?
sounds like it needs a good tuneup, and maybe a battery! most cars start in about 5-10 seconds, even on a cold morning.if all is ok. good-day!
Apr 25, 2014 | 2012 Chevrolet Spark
Engine will not turn over after cold weather
which engine?
cranks but will not start or remain running
tune up time, cold damp cause spark parts bad
oldest story in world. damp conducts, bad insulators do wet.
end result , bad spark.
flooding ? crank wide open throttle, (oper, guide, on start page.s...)_
check spark..,got spark to all cylinders
yes,
try test fuel, if not flooded,
starts then stalls?
Jan 11, 2014 | 1998 Toyota Avalon
My 2000 Chrysler Voyager with 2.4 will not start whens it cold
1st thought is weak spark.Really gets noticeable in cold weather.
Need to check the spark at the coil pack.
Jan 07, 2014 | Chrysler Voyager Cars & Trucks
43cc motovox will start and run ok for a couple of mins. then loses power and dies . Checked compression hot and cold OK , new carb and spark plug didn't help.
when it stops immediately check for spark if no spark when warm but spark when cold suspect ignition coil or related component
Oct 11, 2013 | Motovox MVS10 43cc 2 Hp 2-Stroke...
2002 malibu will not start when cold. After it starts by priming it then starts fine.
ever tune it up, try new spark plugs. gapped to spec.
starts fine and runs fine, not said the latter....????
Cold starts are the hardest, takes
these things to start good. cold.
1: go winter fuel (if cold out, isit? then winter fuel works best)
2: a good engine and good spark plugs, (hot spark)
3: good cold start fueling,
to get #3 the modern car 89- now. needs a working and accurate
ECT sensor, this tells the ECU exactly how much fuel to use.
if the ECT reads warming than REALITY, the fueling will be weak
and may not start or stall fast.
no location stated, nor if car is a daily driver, that is fresh fuel
every week,,,,
Sep 27, 2013 | 2002 Chevrolet Malibu
Lexus LS400 cranks but will not stars
CHECK FOR SPARK AND FUEL.IF ALL IS GOOD A BAD COLD START VALVE WILL CAUSE COLD ENGINE START UP PROBLEMS COLD START VALVE DOES SAME JOB AS ENGINE COOLANT TEMPERATURE SENSOR IT ENRICHEN FUEL SYSTEM FOR COLD START UPS. DO LITTLE TUNE UP MAKE SURE SPARK PLUGS AND WIRES GOOD, REPLACE DISTRIBUTOR CAP AND ROTOR,CHECK IGNITION TIMING, REPLACE AIR FILTER AND FUEL FILTER. IF CAR GETTING FUEL AND SPARK.CAR TIMING BELT COULD HAVE JUMP TIMING IF TIMING BELT NEVER BEEN SERVICED OR REPLACED.
Oct 24, 2011 | 1993 Lexus Ls 400
Hello . Whats the valve settings on intruder 125 cc VL 99'. Thx
Intake valve:cold 0.010-0.15mm
Exhaust valve:- cold 0.18-0.32mm
Idling speed :-1400+/- 100
Carburator airscrew 3.25 turns outwords.
Spark plug NGK CR8E
Spark plug 2 NGK CR8EIX
Spark plug Gap: 0.60mm.
Jun 03, 2011 | 2000 Suzuki VL 125 Intruder LC
1998 BMW Z3 1.9 Cylinder misfire codes. Rough on cold wet starts
Spark plug wires may be the cause. for cold damp start issues water is a conducter and will send spark directly to an engine ground not through spark plugs. also look for oil in spark plug wells this can also cause a misfire under certain conditions.
Aug 12, 2008 | 2002 BMW Z3
Heating & Cooling Logo
32 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
