Question about Polaris 800 Twin Sportsman Ride on Toy
No reverse and won't run in low gear. Only 1 wheel turns in high gear
  • Roveer Aug 26, 2010
    This means that a wire has come lose from one of the motors. in high gear only 1 tire will spin. remove the wheel that does not spin and lift the motor. Look for a lose wire (it comes off the post) and reconnect it. It should work just fine after that.
    Genius:
  • Polaris Master
  • 1,508 Answers
Jumper the battery to both motors and make sure that they work
Posted on May 23, 2012
5 Suggested Answers
  • 156 Answers
SOURCE: won't run in low gear and won't go in reverse
It has a wire that has come off the motor or the switches in the shfter need to be replaced
I get all my replacement parts at
http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego.html
because they also help me with my repair questions.
Hope this helps
Posted on Jul 10, 2009
  • 156 Answers
SOURCE: tractor won't go in low gear or reverse
I had the same problem and replaced the shifter which I found at
http://www.mypegperegoparts.com/switches.html.
This fixed all the speeds and now it runs great.
Hope this helps
Posted on Jun 08, 2010
SOURCE: both wheels will not move in high gear, only one
how do i take a part the gear box from the motor
Posted on Jun 10, 2010
SOURCE: Power wheel F150 only works
My son had the same problem. At first I was angry because we just bought this toy, but then I realized he didn't have it in gear all the way. I had him put it in reverse and drive it back a little. Then I told him to put it in drive, and (making sure it was properly in gear), told him to go and it did. I think it just takes the kids a little while to get used to it and make sure it's properly in gear. Good luck!
Posted on Jan 12, 2011
Do both wheels turn in second gear on john deere gator?
yes both wheels should turn in all 3 gears, high low reverse
Jun 08, 2014 | Peg Perego John Deere Gator HPX Ride on...
Atv wont shift into high gear
Is this an electric shift?? SORRY.. take it to a qualified professional!!
Sep 02, 2017 | ATVs
I have a honda trx 350 es my problem is it wont go into any gear the motor was clicking but now its gone dead
Have a helper lift the rear wheel of the bicycle slightly off the ground.
Kneel beside the bike and turn the pedals slowly by hand. Using the shift lever, adjust the front derailleur so that it rests at about the midpoint of its movement range.
If the initial problem is that the chain won't shift onto the largest rear gear, locate the two small side-by-side adjustment screws on the rear derailleur. Turn the left (or upper) adjustment screw counterclockwise a quarter turn with a small Phillips screwdriver. If the initial problem is that the chain won't shift onto the smallest rear gear, skip to step 6.
Continue turning the pedals and shift through all the rear gears. If the chain will still not go onto the largest rear gear, shift the chain back down to the smallest rear gear. Turn the right (or lower) adjustment screw clockwise as far as possible before the chain begins to click or rattle.
5
Shift through the gears again to test. If necessary, turn the left (or upper) screw counterclockwise another quarter turn.
6
If the initial problem is that the chain won't shift onto the smallest rear gear, begin by turning the right (or lower) adjustment screw counterclockwise a quarter turn. Shift through the gears to test.
7
If the chain still won't go onto the smallest rear gear, shift the chain to the largest rear gear. Turn the left (or upper) adjustment screw clockwise as far as possible before the chain begins to click or rattle. Shift through all the gears to test.
8
Follow steps 1 through 7 for the front derailleur, which operates on exactly the same mechanism as the rear derailleur (you still lift the rear wheel in step 1). There are two side-by-side adjusting screws that control alignment.
If otherwise,
Tighten the high gear screw, the one that hits a cam when you shift to the smallest sprocket, until you can no longer shift into high gear. Put the shifter in high gear position and while turning the pedals, unscrew the high gear screw until the system engages high gear again. Shift between high gear and the second smallest several times, backing the screw out a little more, just until the derailleur shifts smoothly.
2. Tighten the low gear screw until you no longer get first gear. Repeat the process for this low gear limit - back the screw out just until the bike shifts smoothly from the second largest to the largest sprocket.
3. If you cannot engage high or low gear, or if the above technique does not work for high or low gear, the cable may be improperly adjusted.
Shift into high gear and push the shifter all the way to the end of its travel. Loosen the cable inner wire anchor bolt. That's the bolt with a hole through which the derailleur control wire is clamped. Pull the slack out of the wire, and retighten the anchor bolt.
If your bike has index shifting, you'll find an adjusting barrel either at the derailleur or the shifter. The adjusting barrel is a hollow screw at which the cable outer housing stops, but which the inner wire continues through. Fine adjust the cable tension by turning the adjusting barrel until the clicks on the shifter correspond with proper shifting at the derailleur.
If your bicycle does not engage high gear, or is slow to engage high gear, even though properly adjusted, the cable is probably the culprit. Replace the sticky or rusted cable, and the problem will usually go away.
If you have done everything right, but the bicycle does not shift reliably, the most common reason is that the chain and freewheel are too worn to work properly. If you replace one, you must replace both. A new chain on an old freewheel or visa versa usually skips, and the new part wears out very quickly.
Another possibility is a bent derailleur. The guide pulleys, those little wheels that take up the chain slack, must pivot on the same plane as the freewheel sprockets. Derailleurs become bent when the bike falls over on the right-hand side. Whenever you set a bicycle down, or put it in a car, set it on its left side to protect the derailleur. You can sometimes straighten out a bent derailleur by simply bending it back and readjusting the limit screws.
Hoping this will help to solve the problem, do take care....
Sep 19, 2011 | Quad Cycling
The low range light has come on its stuck on 4x4 and is slowing my truck down how do i fix this
you cannot run your truck normally in 4x4 low!!!! the low is designed to go slow slow.try shifting into neutral gear on column tap the high 4x4 then shift to reverse,back up 15feet then shift to drive.it should go into high 4x4 then if you want to go back to 2wheel high shift to neutral tap the 4x4 high until the light goes off,shift to reverse and back up 15feet then shift to drive and the 4wheel drive lights should all be off. then you'll be in 2x2 rear wheel drive. thank you for choosing fixya.com
Jan 22, 2011 | Ford Excursion Cars & Trucks
Tractor won't go in low gear or reverse
u might need to get on ebay and try to find a new switch
Apr 30, 2010 | Peg Perego John Deere Gator HPX Ride on...
Won't run in low gear and won't go in reverse
Hope this helps
Jul 09, 2009 | Peg Perego John Deere Gator HPX Ride on...
John Deere Gator 4x2 - Left Wheel doesn't move when in 2nd gear
I would replace the high/low switch and the reverse switch. One time a replaced the high/low switch and the reverse switch quit on me 2 weeks later.
You can also get the Peg Perego Gator Shifter that upgrades the vehicle.
You can get the parts and repair help at this site
http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego-switches-and-shifters.html
They have helped me several times.
Hope this helps
May 21, 2009 | Peg Perego John Deere Gator HPX Ride on...
Peg Perego Gator Ride On Toy
Sounds like the gears are stripped. If a bunch of teeth are missing, only the high speed gear will spin the gears fast enough to move the gator forward. I just bought a used one and found it pretty easy to tear apart and diagnose as similar issue. The gear boxes, located inboard of each wheel contain plastic gears and strip relatively easy if the shifter is moved , during motion from forward to reverse.
Aug 11, 2008 | Toys
Polaris 800 Twin Sportsman Ride on Toy Logo
99 people viewed this question
Top Polaris Toys Experts
Adam Fjeld
Adam Fjeld
cwradio73
D. E. Hev
Are you a Polaris Toy Expert? Answer questions, earn points and help others
