Question about Tanita Jenny Craig Glass Digital Lithium Healthytrack Scale
This scale stopped working this afternoon. I have changed the batteries (all 3) and the screen remains blank, but with a shadow of all the info that can be entered were it working. I tried pressing each button, but they all feel "dead" and there is no response. Did it die?
  • supernana1 Aug 27, 2010
    This morning I checked out the scale and the screen was cloudy; I stood it on its side and when I came back, it was clear. I inserted the batteries and was able to put the date in and weighed myself (ugh). Can't program it yet, but perhaps there is damp in it?
  • 4,924 Answers
If the control light are lit ..but the screen do not light up ..than it is just a matter of the LCD screen which has a faulty connection on the ribbon ..or just died...but if no control leds are lit ..than the power is not present and the unit either is dead or the batteries are not inserted proper ..or just not the right kind of batteries..
try another set of better ones...and if it is still continuing to act like this you need to get it to be seen by a electrician cause it will be necessary to be opened and measured to see what is not functioning ..
Posted on Aug 26, 2010
  • Catalin Turcu
    Catalin Turcu Aug 26, 2010
    BY the way ..first remove the batteries and insert them again and pay attention on the mapping to be sure that you inserted them in the right way ..after that try a second set of batteries ..but buy some quality ones cause cheap batteries sometime have a low amperage and do not operate well sensitive devices..
  • supernana1 Aug 26, 2010
    Thanks, the screen does not light up, but glows a bit (I think that is the 9 volt battery that provides the light. The batteries are 2 x 2032 and a 9 volt and appear to be inserted properly. Sounds as it is a goner and cheaper to replace than repair. What do you think?
Reset change engine oil light 2009 ford escape xlt
This is how it works on my 2010 Escape. There are 3 buttons to the lower left of your steering column (Info, Setup, and Reset):
1) when it's displaying the "oil change required" message, hit the "reset" button to get rid of the message2) then hit the "Setup" button twice and you'll see the "oil life" screen, which is now at "0%". It tells you what to do next (i.e. "hold reset" until it say 100%).
Mar 14, 2010 | Ford Escape Cars & Trucks
I have a Hobart Digital Scale model 7930 that will cycle through its turn on mode but shows a blank screen from the scale any suggestions?
have you tried changing the batteries? sometimes if the batteries are weak it will have enough power to power up but not enough to power the display in weigh mode
Mar 11, 2010 | Health & Beauty
Changed the AAA batteries but screen remains blank
Check for corrsion on battery terminals AND check batteries are in the correct direction.
Jan 24, 2010 | Texas Instruments TI-84 Plus Silver...
Acoustic Solutions TV/DVD P1480 has stopped working
Doh me, daughter had accidently hit the standby button without realising, had a brainwave after posting above and tried that, everything working fine.
Oct 01, 2009 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
I put the new battery in my Taylor 7004 V1812 and the screen rem
Check and see if you put the battery in right. Make sure the rough part is facing bottom.If this doesn't work your battery may be bad.
Jul 22, 2009 | Taylor & Digital Scale Lithium Scale
My meizu M6 SL player stopped working
Yeah, back to the battery which "showed a charge"
A partially charged nicad will show a full charge, while failing to hold a full charge due to the memory
effect, so these were changed for Lithium Ion batteries with no such effect, but even these will fail after
a certain number of recharge cycles and though the unit is perceived by your laptop or desktop when
connected by USB the actual power to do so is furnished by the usb itself, not necessarily the failing
battery.
Change the battery, as the worst possible outcome from this method of troubleshooting is that you wind
up with a spare battery that you can charge while the other one is in use.
If the battery proves not to be the problem and the unit is warranteed, then have it serviced or swapped.
If not warranteed and you can afford a replacement, do so.
Apr 17, 2009 | Meizu M6 miniPlayer
Denon AVR 4802 Receiver w/ Denon DVM 4800 DVD player - video fail
no the problem is at the plasma you will have to change the setting back to the scale range that will accept the signals from the Denon, see Plasma's manual for instructions
Jan 27, 2009 | Denon AVR-4802 Receiver
Skyscan Atomic Clock WWVB
figure out where yu are north south west east zones on your map from where yu are , then pull battery again it should stop at for eight or twelve push time zone then set in a window facing your zone it should automatically pick it up shortly in awhile
sw i think it may stop at four also but then wait
Oct 14, 2008 | SkyScan 86709 Atomic Wall Clock
Changing user settings on Conair WW67T scale
1. Tap the scale
2. Wait for "0.0" display
3. Set
4. Use the up arrow then stop on the user you desire
5. Set
6 Using the up/down keys enter Height
7 Set
8 Using the up/down keys enter Age
9 Set
10 pick the little man or woman
11. Press SET - the scales will redisplay your profile settings for verification.
12. Wait Until the Display Goes Blank.
13. Tap the Scale.
14. Press USER, select desired profile, P-01 is the default.
15. Wait for "0.0" display
16. Step onto the scales and wait for all measurements to display
Oct 02, 2008 | Health & Beauty
Tanita Jenny Craig Glass Digital Lithium Healthytrack Scale Logo
71 people viewed this question
Top Tanita Health & Beauty Experts
Tre Elkins
Ankit Chandel
Ankit Chandel
Tom Chichester
Are you a Tanita Health and Beauty Expert? Answer questions, earn points and help others
