Question about Gestetner Office Equipment & Supplies
I would like to print in a short band paper, 8.15 x11 however the selection only gives us two options, A4 and long bond paper. how can i set the paper to short size. im using gestetner MPC2030. thanks for the assistance
checkitright
  • 1362 Answers
SOURCE: Will not select legal paper when printing and faxing, letter only.
You have to go into the menu and change the setting to Legal.
here is the manual:
http://www.fixya.com/support/p202524-panasonic_panafax_uf_595_plain_paper/manual-7600/page-3
Posted on Oct 23, 2007
IB4G2008
  • 3587 Answers
SOURCE: Problem Priniting on a Non Standard Paper Format with IP5200
the issue here is whether your canon can handle that size of paper. is it running on the manual insert tray?
when you choose paper source, you'll need to identify where the paper is coming from..
try that..
of course, up to date drivers are here
Posted on Feb 28, 2008
SOURCE: Manual Feed Issue
will not pick up envelopes to print
Posted on May 21, 2008
leroyal
  • 2120 Answers
SOURCE: change from letter to A4
No can do!
You need a metric fax machine.
Posted on Oct 06, 2008
  • 105 Answers
SOURCE: printing to 4 x 6 paper
Hello oyam26,
For any paper mismatch issue, first thing you do is try to set the paper type to plain. This will fix the issue in most of the cases.
gud luck
Posted on Nov 05, 2008
Why does our Kyocera Taskalfa 181 keep displaying a "Print mode error" message?
It is usually because you have the machine set up as A4 and the your documents or printer driver set to 81/2 X11(American letter size) size paper ,to override this ,got to the menu system button in the top left of the operation panel ,scroll down to printer setting in one of those menues you'll find A4/letter override turn it on and you'll get rid of the problem .
Apr 21, 2015 | Kyocera Office Equipment & Supplies
How do I clear the in use alarm on a canon mx340 printer?
The in use alarm appears to be related to fax reception and printing. There are some options below that you could try:-
Memory Reception If the machine receives a fax under one of the following conditions, it will not be able to print the received fax and will store it in its memory. The In Use/Memory lamp is lit and Received in memory is displayed on the LCD. When the problem is resolved as described, the fax stored in memory is printed automatically.
  • Ink has run out: Replace the FINE Cartridge.
    i_green_arrow.gifRoutine Maintenance
    i_note_e.gifNote
    • You can set the machine to forcibly print a received fax even if the ink has run out.
      However, part or all of the fax may not be printed since the ink has run out.
      Also, the contents of the fax will not be stored in memory.
      If the ink has already run out, we recommend that OFF be selected for Auto print in FAX user settings to store the received fax in memory and print the fax manually after replacing the FINE Cartridge. After you replace the FINE Cartridge and select ON for Auto print, the fax stored in memory will be printed automatically.
  • Paper has run out: Load the paper and press the OK button.
  • A different size of paper from that specified by Page size is loaded:
    Load the same size of paper as that specified by Page size, then press the OK button.
  • Page size is set to other than A4, 8.5"x11"(LTR), or Legal (or 8.5"x14"):
    Set Page size to A4, 8.5"x11"(LTR), or Legal (or 8.5"x14").
  • Media type is set to other than Plain paper:
    Set Media type to Plain paper.
  • You pressed the Stop button to cancel printing of a fax:
    Press the FAX button
Alternatively turn the printer off, open the devices and printers section of Control Panel, right click on your printer and select "see what's printing" and left click on this. A window will pop up which may or may not contain a list of documents. If it does these must be cancelled (Menu - Printer - Cancel all documents). Once all documents have gone from the list turn the printer on and try to print.
Other than the above suggestions I would need to know more about your OS and exact problem. Hope this helps.
Aug 06, 2014 | Canon PIXMA MX340 Wireless Office...
Why does my printer cut off top and bottom of page when printing, and sometimes side margins. But on the print preview page it shows it printing all of it.
Make sure you have selected the correct paper size to match the paper you are using. For example, your printer properties may be set to A4 (metric) while you are using Letter (8.5"x11"). These are slightly different in size and would produce the results you are describing.
Be sure to set your Default printer properties to the paper size you normally use so that you don't have to make the change every time you print.
Jul 26, 2014 | HP Officejet 7610 Wide Format e-All-in-One...
Printer will not print from any computer and keeps saying that A4 paper is not available even though full
a4 is metric for 81/2 x11. check your printer properties ensure they match what the copier thinks it has in the paper draws, also check control panel printer properites mite be that a4 is default
Jan 28, 2014 | Konica Minolta Bizhub C364 Color Copier /...
My manual was in a strange language. How do I
Your manual can be found here.
Printing on both sides of paper You can print on both sides of a paper; duplex. Before printing, decide how you want your document oriented. You can only use this feature with Letter, Legal, A4, US Folio, or Oficio sized paper.
Do not print on both sides of the special media, such as labels, envelopes, or thick paper to print on both sides of paper. It may cause a paper jam or damage the machine.
  1. To change the print settings from your software application, access Printing Preferences. (See Opening Printing Preferences.)
  2. Click the Layout tab.
  3. From the Double-sided Printing section, select the binding option you want.
    • Printer Default: If you select this option, this feature is determined by the setting you’ve made on the control panel of the machine.
    • None
    • Long Edge: This option is the conventional layout used in bookbinding.
    • Short Edge: This option is the conventional layout used in calendars.
    • Reverse Double-Sided Printing: Check this option to reverse the print order when duplex printing.
  4. Click the Paper tab, select the Paper Options.
  5. Click OK or Print until you exit the Print window.
If your machine does not have a duplex unit, you should complete the printing job manually. The machine prints every other page of the document first. After that , a message appears on your computer. Follow the on-screen instructions to complete the printing job.
Good Luck!
Jesse
Jan 06, 2010 | Samsung ML-2855ND Laser Printer
Paper out message, wanting A4 size
Hi rmfgco2009
A4 paper is 8.3"x11.7" OR 210x297
Letter size is 8.5"x11" OR 216x279
So your paper is called LETTER size not A4
What you have to do is;
  1. On the LCD display of the printer, through the SETUP, change the paper size from A4 to LETTER. Save the settings and Exit.
  2. Also, From the Control Panel, printers, properties, preferences, features change the paper size to LETTER. This step can be done from EXCEl also through the printer menu.
  3. You may need to Turn the printer off and on again.
Hope this will work for you. If this solution is helpful, please give a rating.
Have a Good Day
luciana44
Nov 30, 2009 | HP LaserJet 4 plus Printer
Whenever i change paper size from A4 to letter,
Don't set by using the "Print" option.
Go to [Start]
[Printers and Faxes]
right-click on the HP printer entry
! Don't select "Printing Preferences"! from there
Select [properties]
Select [Advanced] tab
Select [Printing Defaults]
[Advanced}
(I know, the screen looks the same, but it functions differently this way)
Change paper size to "Letter"
[OK, OK, OK]
*done*
Sep 25, 2009 | HP LaserJet 4350 Printer
A4 paper giving error
When you print, under "Paper" be sure that the paper source is set to "Auto Select" in the options.
Apr 08, 2009 | HP LaserJet 1005w Printer
MX2700N printer keeps giving A4 paper error.
Go to system setting, under printer setting there's a menu to forced output print or A4/Letter changing, if you can not find it try the key operator program/ admin mode ( default password for admin is admin )
Feb 19, 2009 | Sharp MX-2700N Color Copier
Printing problem
Make sure the page settings in the printer options is set to AUTO. Sometimes this is set to LTRr or LEGAL. Hope this helps, let me know?
Oct 10, 2007 | Canon imageRUNNER 400S Copier
77 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
CheckitRight
CheckitRight
 Larry
Larry
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
