Question about RTO Massey-Ferguson Tractor TE20, TO20, TO30, ITFE2
I have a 1950 TO 20. It starts just fine, runs 5 minutes sputters, like it is out of gas, and quits. It won't restart but I can wait a little while and it will restart but do the exact same thing. Any clue what is wrong? Does it have a fuel filter that could be stopped up?
My first guess would be that you are not getting correct flow of fuel into the carburator. It would run for a short while on the fuel in the bowl then konk out when it gets exhausted. Waiting a while the fuel would build up and then run fine until it is exhausted again. First thing to do is check fuel flow by removing the line into the carb. If you are gettng good flow then I suggest removing the carb and cleaning paying special attention to the needle valve and float. If you have not had a carb kit installed in recent memory it may be a good idea to do that. I had multiple issues with my '50 until a complete cleaning and kit was installed.
Posted on Sep 16, 2010
I have a Miller blue star 3500 with electric start Honda engine.
Have you stripped and cleaned out carburettor?
sounds like a blocked idle jet?
Dec 27, 2016 | Miller Welding Tools
My car is sputtering and dying. If I try to restart it, it will immediately go into sputtering/dying mode. If I wait a while an hour or so it will start up and drive fine.
When was the last time that the carburetor was stripped and cleaned? Also have you checked the fuel filter? Finally, the problem seems to come and go as the engine is run (and it gets hot) check that the fuel line and any electrical cables are well away from the hot engine as far as is possible.
Jun 16, 2015 | Cars & Trucks
My 2004 Honda shadow vt600 vlx quits running after approximately 10 minutes of riding. It just shuts off and won't start. Has a new battery, plugs and changed oil & filter. What will fix this prob
How does it quit? Just suddenly stops, or coughs and sputters (probably gas), or gets jerky (ignition). Does it run just fine and then just stops, or does it run crappy and then stop? How long do you have to wait until it starts again? Is there a choke? Do you turn it off?
Sep 27, 2014 | Motorcycles
My x5 3.0i 2006 t won't start this morning but temperature, gas level clock were wrong so I turn the engine off and restart a couple times it won't start and I saw message trans. false safe...
no. I'd suggest to disconnect a battery for 15 mins, reconnect, wait for 5 mins and try to restart. If it doesn't help (sometimes there's a program block to prevent stealing equipment) call a dealer
Aug 04, 2017 | 2003 BMW 5 Series
I have a 1993 4.3 6 cyl chevy S-10, it starts fine when you give it a little gas then when you start driving it 5 to 8 minutes later it is spitting and sputtering misfiring and backfiring give it a little...
5 years ago for cap & rotor???? It sounds like it's in dire need of a complete tune up - plugs. wires, cap, rotor, all fluids & filters ESPECIALLY fuel filter. I'd start there and run a good fuel system cleaner through it. Do your tune ups more frequently like every 30K - not wait 5 years!
Mar 22, 2011 | 1993 Chevrolet S-10
Hedge trimmer starts fine then stops after 5 minutes
Carburetor high speed adjustment ( screw nearest the filter ) open ( counterclockwise ) 1/2 turn.
Adjust again as needed to run when hot.
make sure the gas mixture ratio is as required.
Henry
Sep 20, 2009 | Ryobi Factory-Reconditioned 30cc 18" Gas...
Mower stops running after I've been mowing for about 30 minutes. I changed the spark plug and fuel filter. It seemed to work and I was mowing the lawn then it just started acting like it was running out of...
Mower stops running after mowing about 5 minutes. acting like it was running out of gas unitl eventually stops. I wait 10 minutes and then it restarts, runs good, then erratic...then quits again?
Aug 23, 2009 | Garden
Snowblower runs then quits
check to see if gas cap vent is clear . its the little pin hole at the top of cap . if not clear it will cause a vacuum and stop the flow of gas ... good luck
Dec 19, 2008 | Mastercraft Garden
RTO Massey-Ferguson Tractor TE20, TO20, TO30, ITFE2 Logo
673 people viewed this question
Top RTO Toys Experts
The Scrivener
Pete Bruk
rostit
Are you a RTO Toy Expert? Answer questions, earn points and help others
