Question about Garden
Weed eater 550 manual: This mower does not have a chock or throttle control and I can not keep it running. Where can I get a manual?
Thanks Enginedoc. This fixed my brand new mower. I'm 62 year old lady and with your help it fixed it. THANK YOU SO MUCH! YOU ROCK!
Posted on Mar 22, 2013
3 Suggested Answers
  • 48 Answers
SOURCE: lawn mower
i dont understand the pulling the button - do you mean push the primer button - if you mean primer button it sounds like the high speed jet in the carb is dirty and needs service- you can attempt to start and once engine fires have someone continually push primer to keep running it ma clear the blockage - did You check the fuel tank for any water ?
Posted on Oct 21, 2008
popsgifts
  • 160 Answers
SOURCE: My weed eater 500 series mower is not getting gas.
First possibility: The in-tank filter may be clogged...The fuel line running into the tank ends at a small canister bulb, basically a cage made of screens to filter debris that builds up in every tank...as the filter clogs, only manually pumping the fuel with draw enough to feed the engine.
Make a small hook on the end of a piece of wire ( 8" of coat hanger) and reach into the empty tank to gently pull the filter to the fuel port for removal and cleaning.
* Don't smoke! An empty tank is just as explosive, if not more so, as a full one.
** The inner line is a bit short, and will disappear back inside after removing the filter (and it's a pain to get back), so pinch or loose-wrap the wire onto the line to keep it outside until you're ready to replace the filter.
Second possibility: The problem could just as well be a lack of air as fuel...pull the air filter cover and filter, but replace the bolt a few threads to keep it in place.
After cleaning the tank filter, and refilling the tank, add a few drops (about a teaspoon) of gas into the throat and give it a pull or two.
Once it warms up, shut it off so that you can clean and replace the air filter and button it down.
*** Adding a tsp of Marvel Mystery oil to the tank will finish cleaning the lines and ports...I love the stuff; Works better than most, and it's the best deal in fuel system cleaners.
***Don't forget to VOTE for the guys who take an interest in helping!
Posted on Apr 25, 2010
Starting procedure
Terry: According to eHow.com:
  • Put on a pair of safety glasses. Remove the fuel cap from the Weed Eater and set it aside. Fill the fuel tank with unleaded gasoline that has been mixed with quality 2-stroke oil in a 40:1 ratio. Replace the fuel cap.
  • Move the Weed Eater to a safe place and lay it flat on the ground. Depress the fuel bulb located beneath the carburetor approximately six times to prime the engine. Press it slowly so that fuel has adequate time to traverse the fuel line.
  • Slide the handlebar-mounted engine "On/Stop" switch to the "On" position. Slide the choke lever beneath the fuel tank to the "Full" position.
  • Depress the "Throttle Lock" lever located beside the engine "On/Stop" switch. Keeping the lever depressed, squeeze the throttle trigger. Release the throttle lock. This sequence holds the trigger in the depressed position, which aids in starting the Weed Eater.
  • Roll the Weed Eater so that it is resting on the engine and the trimmer head shield only. This will allow the spinning trimmer head to avoid contact with the ground. Brace the Weed Eater by holding it to the ground with one hand. Using your other hand, pull the starter rope quickly until the engine begins to run. Do not pull the rope more than a dozen times. If it fails to start by then, squeeze the throttle trigger and continue to pull until the engine starts.
  • Allow the Weed Eater to warm up for about 15 seconds, then slide the choke lever to the "Off" position. Let the trimmer run for another minute without touching the throttle lever. After the Weed Eater has warmed up, squeeze the throttle trigger once to disengage the throttle lock. The trimmer is now operational.
  • Read more : http://www.ehow.com/how_6720315_start-gas-weed-eater.html"
    Jun 08, 2015 | Garden
    HOW TO ADJUST DRIVE CHAIN ON WEED EATER ONE
    There is a tension adjustment on the body.. flip your mower over and you can see it better.. do not over-tighten it though because it needs slack to let the 1-2-3 to change on the fly.
    Aug 18, 2014 | Weed Eater WE-ONE 26-Inch 190cc Briggs &...
    Poulan problems
    Poulan Pro Weed Eater. 31cc PPB200E, Crancks good, runs as Long keep chock on , New Carberater, New fuel lines, New fuel filter
    Jan 07, 2014 | Garden
    Weed eater bogs out at full throttle
    Make sure fuel is mixed correctly, make sure the choke isnt stuck on aswel, ive had it happen to me before when the little blue leaver sticks and it wont rev out properly.
    Apr 02, 2013 | Husqvarna 128 LD Weedeater
    Ss30 ryobi weed eater fuel ratio
    I work with weed eaters and mowers. Weed eater fuel ratio is normally a 40:1 ratio. That usually all weed eaters fuel ratio.
    Sep 11, 2012 | Poulan/Weed Eater No. Te475 952711797 17"...
    Weed eater one friction disc problem
    HOW REPEAR THE FICTION HOB WEED EATER TRACTORS
    Aug 22, 2012 | Garden
    John Deere weed eater problems
    remove the muffler and run it if it runs good after that open the muffler and clean the screen inside
    Apr 01, 2012 | Garden
    How do you check the oil in a Weed-Eater-500-Series Side Discharge Mower, Model 10854261. It has a basic Briggs Stratton engine. I have a lost the manual and cannot figure it out!! HELP!!!!
    most mowers have a dip stick like a car and the oil should be changed often and acting as if it wants to stall try fresh fuel gas is only good for 30 days in small engines
    Mar 27, 2012 | Briggs & Stratton Garden
    New wife has cc4125. How do you replace trim wire
    Hello South Texas from former Mesquite resident!
    If this does you any good, get your Model and Serial no. and can go to this web address and download the owners manual:
    http://manuals.mtdproducts.com/mtd/public/list.jsp?BrandCode=30000
    Sep 20, 2009 | Cub Cadet Street Sign- tractor lawn riding...
    Garden Logo
    362 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    john h
