Question about Disney DTD1363-CAR 13" TV/DVD
DVD tray wont close.
DVD was stuck and once we got that out, the tray wont close. The tv wont even turn on?
    Problem Solver:
  • 9 Answers
You probably striped the gears in the tray mechanics. New gears at a TV shop is your only hope.
Posted on May 06, 2008
Artisan 730 keeps ejecting CD/DVD tray?
Possibly the the eject switch is stuck, open the case carefuly check and rectify.
Mar 25, 2015 | Epson PRINTER,ARTISAN 730
I have an RC100H that keeps opening the DVD/CD tray as if it does not read the disc. Even if I have no disc in it the tray opns and stops. The only way to keep the DVD Tray closed it to hit the close...
eject belt propably worn out, does not close lid proper - so ejects back. change of belt solves problem.
Thanks for using FixYa - a 4 THUMBS UP rating is appreciated for answering your FREE question.
Feb 21, 2011 | LG RC199H DVD Recorder/VCR
My husband always operated the DVD player. He has died and now I'm at a loss what to do. I rented a DVD at the video store. I tried to put it into the tray on the DVD player. I had to pull the tray...
Hi, Very sorry for your loss. As always the first step is to make sure the player is connected to the wall outlet and turned on. To put a disk in the DVD you should push the "Eject" button to open and close the tray it looks like a home(a triangle over a dash) on the front side of the box down left corner of the tray. You have the same button on the remote marked "Eject". Push either once, put the disk with the shiny side down on the tray and push the Eject button again to feed the tray back into the player. Usually the disk starts automatically and you will see a menu on the TV with alternatives like "Play the movie", "Setup", "Scenes",... you may highlight the "Play the movie" alternative, using "Up", "Down", "Left" and "Right" and then press the "OK" button. Or just push the "Play" button either on the box or the remote control. If you click "Here "you can download the manual in PDF form. To open it in your pc you'll need "Adobe Acrobat Reader" (or any other PDF reader) installed.
I will gladly answer your questions Best Regards Bruce
Aug 23, 2010 | Amphion Mediaworks S99 DVD Player
Getting sound but no picture when watching dvd and in can't get sound from tv when watching tv
Thanks for using FixYa. Make sure the Red and White wire is connected into your TV “AUDIO IN” and the Red and White wire is connected into the L & R. Also check that the DVD player Audio setting Analog Out is set to “2 Channel” and the TV is turned to the correct Video line (AV Input/Video Input 1,2,3.etc). Once your TV is turned to the correct video line, you should see the “COBY” logo and it will work normally. If still the issue persists, then you’ll need to reset the DVD Player for which you’ll need to follow these steps---
Using the DVD player remote control: Open the Tray and press the “PROG” button and then press the “ZOOM” button.
Once the above procedure is performed the tray will be closed which means the DVD player has been reset back to the factory default settings.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Oct 18, 2009 | Coby Televison & Video
DVD Tray stuck open
the tray is not catching (underneath the tray is ridges). unplug the dvd player from the wall for 5-10 min...plug back up and give the tray a lite push while tapping the open/close button
Jun 17, 2009 | Yamaha DVD-C920 Multi-disc DVD Player
E1 (rear) error. DVD tray will not open.
there might be a possibility that as soon as the tray closed the dvd shifted inside the machine. the dvd is stuck yes which means that the tray wont open because the dvd is blocking the gear turning. if so you are going to have to take it to your Dealership to open up the player and remove the disk. you can try it yourself but it's not recommended. tray gears will have to be tested to see if the tray will open once the disk is out though
Mar 29, 2009 | Philips Magnavox DVD/VCR Dual Player
Jvc dvd player not playing
Even you don"t have a remote you can play it manually and DVD player play it automatically.Just try this open the tray put the DVD disc on the tray and close it then turn it off for 30 seconds then turns it on then it play automatically if not then there's something wrong to the player.
Hope it may help you:
Mar 23, 2009 | Audio Players & Recorders
DVD stuck in tv combo unit
Had same problem! Husband took back off tv, lots of screws, unscrewed the dvd player and turned it over. There is a white wheel, turn that slowly. It opens and closes the dvd "tray". He turned it until DVD came out. Tried another DVD but no good. Had only used the DVD once since owning tv. Won't use it again.
In the past we would not buy combo units. Won't ever again!!!!
Jan 31, 2009 | Westinghouse SK-32H590D Television
Eject tray stuck
Turn it [the TV] on its RIGHT side......... slowly press the eject button once every second. Pay attention to gears winning [as if something is trying to catch. If that don't work try it on its LEFT side. The gears have to be on one of the sides. If you continue to have the same problem, u need to replac the PLASTIC gear assembly.
May 11, 2008 | Bush DVD142RC 14 in. TV/DVD Combo
Tray opens / closes on its own and will not play
Your open/close button might be stuck, you can try and unplug it and spray it with silicone lubricant and push it over and over again for a couple of minutes and then turning it back on after about 30minutes so the lubricant dries down first.
If all else fails, have a local appliance technician take a look at it...
Dec 09, 2007 | Hitachi DV-P323U DVD Player
Disney DTD1363-CAR 13" TV/DVD Logo
87 people viewed this question
Top Disney Televison & Video Experts
Jaime Hernandez
Chris Goulet
Are you a Disney Televison and Video Expert? Answer questions, earn points and help others
