Question about Dewalt 18 Volt Compact Drill Kit
18 volt "brute tough" Bosch cordless variable speed drill is no longer variable speed -- it's wide open at first squeeze of the trigger
You need to replace the trigger unit to correcxt the problem.
Posted on May 23, 2008
My new bosch cordless drill chuck doesn,t have a screw in it how do i remove the chuck ?
Dear Fred,
Please go to Replacement Parts in the link provided below. Too replace and remove your drill chuck on a cordless drill.
How to Remove Drill Chuck
Fare Well
Feb 07, 2015 | Bosch 13618 - 2G 18V Brute Tough Cordless...
Bosch cordless drill not working.
First The model is pretty new. you need to register your tool on line. this takes you from a one year warranty to a three year warranty. They will give you a pro-vantage number. with that said it sounds like a trigger switch. Yhe trigger switch is the brain of your tool. not only does it do your variable speed but it also controlls the brake and your fuel gauge. Because of the cost I highly recomend taking it to your closes Bosch service center.
Oct 13, 2012 | Bosch Cordless Impact Driver, 18V, 1/4 Dr,...
How can I test whether the charger or battery id faulty. I live in Windhoek,Namibia
You have to check You have to check the battery and charger for voltage with a volt meter. The charger should be putting out at least 14.5 volts and the battery should read 14 volts. There are metal contacks on the battery and on the charger inside the hole where you insert the battery.
Mar 11, 2011 | Bosch 33614-2g 14.4v Brute Tough 1/2"...
How to use hand drills?
Use of both is the same:
- loosen "chuck" (part where bit is installed).
- insert bit (hand tighen chuck so that bit is secured)
- tighten chuck securely with chuck tool, or by holding rotating chuck with hand and pulling trigger (GENTLY or you will shave off skin!)
- put drill in forward or reverse mode and pull trigger to inser or remove screw / drill hole.
ensure that battery is charged on cordless drilll.
squeeze connectors to remove and place in charger when battery is too low to operate drill.
Apr 27, 2010 | Bosch 14.4V Brute Tough Drill Kit
1) No variable speed; 2) Grinding sound when using <high2speed>, although drill still works
starting with the variable speed the switch part # is 2607200457 and list for 47.58, the gearbox part # is 2606200930 and lists for 75.90 and lastly the motor part # is 2607022865 and lists for 75.90, the grinding could be the motor bearing going out or the magnets cracked, if you want to tackle this I suggest going to Boschtools.com and on the left side towards the bottom type in your model number so you can look at a breakdown of this tool. Before I started spending that kind of money I would think about possibly replacing it. If I have helped you would you please rate my response accordingly and Thank you.
May 07, 2009 | Bosch 33618 1/2" 18v Cordless Drill Tool...
Bosch 18volt brute force cordless drill how do i remove chuck
Put the screw back in the chuck, tighten it up then back it out 1 turn. Take a punch, put it in the chuck and give it a quick hit with a hammer. That should do the trick.
Jan 31, 2009 | Bosch 33614-2g 14.4v Brute Tough 1/2"...
Bosch drill 14.4 volts
A fresh set of carbon brushes will solve this problem. P/N 2607034900 Go to a Bosch service center and they should have them
Oct 11, 2008 | Bosch 14.4V Brute Tough Drill with Blue...
Dewalt 18 Volt Compact Drill Kit Logo
189 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
