Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
Water is leaking from the motor? - Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
  • Ace Hardware Master
  • 43,501 Answers
If water is leaking out of the motor then the disposal unit is no good... it is fixable, but will cost more to fix then to replace it...
heatman101
Posted on Aug 26, 2010
Whirlpool LSR8010PQ0 motor hums and leaks water
Somethnig is wrong with your transmission. Since it is leaking, the seals are broken or damaged. The water leaked in your transmission. The problem with Whirlpool washing machines, the motor is directly coupled with the transmission. There is a high probability that the leaking water corroded the transmission, thereby freezing it. Your best bet is to have the transmission and the water leak fixed. Do not run the washing machine till you have this fixed, otherwise, you face the chance of losing your motor.
Jun 22, 2014 | Whirlpool LSR7333 Top Load Washer
Water leakin behind the motor
could leak water pump that what you did.
Feb 28, 2013 | Cars & Trucks
Water leaking behind motor when car is parked passenger side oddly when motor is cold
Could be a line leaking also could be heater core leak or water pump or comeing from overflow. Many things it could be. My best suggestion is take it and have it looked at. hard to guess with out looking at it
Aug 12, 2012 | Audi A4 Cars & Trucks
I have a water leak after the water runs through the radiator and I believe the motor the water leaks
sounds like if its leaking from front of motor then it is your water pump thats bad but first make sure its not from a hose at the thermastat housing. hope this helps
Sep 13, 2011 | 1993 Ford Econoline
As soon as the motor starts up after the dishwasher fills, the motor makes a loud grinding noise that turns into high pitch whining. Water begins leaking from above the pump.
That shows a leaking water seal. Water would run into the motor bearings which then rust and make noise. You probably need the motor / pump kit.
May 20, 2011 | Dishwashers
Im leaking radiator fluid pretty badly and it leaks when i drive and but leaks all over the ground when it sits and its not the hoses and i just resealed the thermostate housing and now its leaking agian i...
I would look at the water pump. It either that or your radiator draped out. Park it after it hot and put a box under the belt area between belt and motor and under the radiator. That should help narrow it down a bit. Hope this helps
Mar 29, 2011 | Toyota Pickup Cars & Trucks
Headlight washer system leaks out all the fluid just sitting without using the pump button
first check where it's leaking from, if water dropping near front wheel it's leaking from tank first check the rubber grommet for both washer motor 1 wiper washer motor and 2 head light washer motor, both are in the water tank, if your car water dropping from front end under the front bumper it should leaking from washer nozzle in this case need to replace the head light washer nozzle. some time leaking from hose if you check from underneath you can see where it's leaking from,
Nov 20, 2010 | 2000 Mercedes-Benz S-Class
Dishwasher began leaking underneath when turned on. Humming as if trying to start, but nothing further exept water on floor
I don't know how old this dishwasher is but the symptom your describing sounds like the ceramic water seal on the bottom of the impeller assy but above the motor has failed. When the seal fails it allows water to run though the motor and then the bearings in the motor fail. Once water starts running though a dishwasher motor they are pretty much shot. The reason for this is that the leak starts out slow and it leaks for a long period before you ever see the water under the dishwasher. So by the time you see the leak water has been going through the pump / motor assy for weeks or months. By that time the service technicians only option is to replace the motor pump assy.
Kelly
Apr 14, 2010 | Bosch SHU5315UC Dishwasher
LG 3 in 1 Dishwasher model LD2131SH showing E1, leaks water
e1 is a leakage error. you will have to find where it is leaking from...crack hose .crack motor assy.. water must be leaking
The excessive RPM of Washing Motor happened during Wash cycle due to water leakage.
Water leakage in Hose connections. Water is leaked by damages. The Motor Water Seal leakage of Sump assembly. The height of Drain Hose connection (sink-Drain Hose) is not over 20 . Impeller of the Washing Pump is worn away.
Sep 11, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Whirlpool Dishwasher GU1500XTL Leaking from wash motor
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
q3taga
Aug 31, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
42 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Mike
Treefrog15
Treefrog15
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
