Question about Whirlpool Duet GHW9150P Front Load Washer
MILDEW My Whirlpool Duet model GHW9150PW1 gets mildew really easy.  Also, there are many times when it vibrates so much that it actually moves from it's regular position. Also, wanted to know if this model can be used as a stackable washer/dryer?  My laundry room is rather small and this would provide me with an alternative to the small space.
    Genius:
  • 1,073 Answers
If you think it vibrates now wait till you stack it more pressure downward on the floor will cause more viberation
Posted on May 06, 2008
I getting a funky smell in my laundry room and bathroom, but only when I am doing laundry. I am wondering if it has something to do with the hose. Its be like this for about six months.Thanks
It probally mildew growing inside the wash tub and associated water connnections like the pump housing, drain hoses. Mildew growth is common problem with front load washers. You can try to reduce the occurance of mildew by leaving the door and soap dispenser door open when not in use. Also wipe with door gasket with a rag to dry it.
To kill the mildew in the machine wash an empty load with hot water and vineagar about once a month. Repeat as neccessary. There other products to help reduce mildew such as affresh. Hope this helps you.
Aug 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I'm finding mold on the inside ring of my washer, and i'm not sure how to get rid of it or prevent it.
If you are referring to a Whirlpool Duet series front loader, the following link can give you some guidance on how to prevent mold, mildew and odors associated with these style washers:
http://www.fixya.com/support/r3608512-getting_rid_front_loader_mildew_odor
If you are not referring to a front loader, please post back with a complete MODEL NUMBER. I hope you find this information helpful.
NOTE: Because of the mold and mildew problems associated with these washers, the manufacturer now includes many of these recommendations in the owner's manual.
Aug 13, 2010 | Whirlpool Washing Machines
I have a mildew smell within the washer and have
Leave the door open all the time and it will dry out and the mold and smell will subside.
Mar 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Sud message on whirlpool duet front load washer also after washing clothes i notice a mildew smell on the clothes.
You areusing too much soap. Run a rinse cycle and use less soap next time. As for the mildew leave your door cracked open after you are done using the machine.
Dec 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool Duet Washer Model GHW9150PW1 Control Locked
I had the same exact problem, the answer is in the User's Manual for this model Dryer, also here: The Users Manual reads: "TO UNLOCK": Press and hold the END OF CYCLE button for 3 seconds to turn this feature off. I did this and it worked perfectly the first time! My first load is drying now after months of being without the dryer (too busy to investigate!). Good luck.
Oct 26, 2009 | Whirlpool Washing Machines
Hi--I love my Whirlpool Duet washer, but how do I clean the door gasket and get rid of the mildew and mildew odor?
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.((((())))
Sep 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The door seal has mold and mildew. It really
first try to clean it with clorox bleach. or some bathroom mold cleaner scrubing bubbles, ect
and if it still needs to be changed look on the computer and find the part shipped to you.
Jul 31, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Odor in front loading duet washing machine
The following link explains how to minimize wash tub odor, and what generally can cause it:
http://www.fixya.com/support/r513372-front_loader_mildew_odor
I personally own one of these washers and have followed this same regiment since I purchased it new 9 years ago. I have never had a mildew or odor problem. Consumers that are not in the habit of using hot water very often will also run into odor and mildew problems, because detergent alone does not always kill bacteria. It is recommended that you run a "Clean Cycle" from time to time, to sanitize. Some newer models have a clean cycle added on the control panel.
NOTE: It is normal to have residual water in the drain lines and in the drain pump. If you need to clean, or check the drain pump, please follow the advice in this next link:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
Debris caught in the drain pump reservoir can often cause some unwanted odors.
If the rubber door bellow develops mildew and mold, use a non abrasive pad (the little green pads are considered non-abrasive) and scrub the rubber with bleach diluted with water (50/50 mix). This will often kill and remove unwanted mold and mildew. If the door bellow becomes embedded with mold or mildew, it may have to be replaced in order to get rid of it.
If you establish and maintain a diligent routine, these washers will not mold or smell. Often what seems to be a dream appliance that is supposed to make your life easier, may actually require more attention in order to maintain it properly.
If you have questions or comments, please let me know. I hope this helps you.
Jan 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Mildew
I have found nappy soaker on a damp rag effective in removing mould from fridge seals. It might also work on you washer.
Mark
Jun 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
MILDEW ODER THAT WILL NOT LEAVE?
Fear not there is new product on the market designed just for your very need. www.affresh.com . but lets go over a few steps first. It actually for the most part ,not mold/mildew although it seems that way. First and foremost you MUST MUST use an HE detergent. not just less of regular detergent but actual HE detergent (and only 2-3 tablespoons of that even) Cut back on the amount of fabric softener that your using (if any) and leaving the door ajar between wash cycles improves air flow through the tub assy. Finding that its actually been a build up of extra detergent not breaking down completely giving of the odors. this product will help!!!!
Mar 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
217 people viewed this question
Dan Webster
Dan Webster
Sal De
