Question about Dometic Rooftop RV Air Conditioner
We have a 1999 Nomad trailer model #2950, 29'. The air conditioner was working fine and than stopped. The refrigerator was not working but the freezer was. All other electrical are working. Any suggestions?
  • lbearr Aug 26, 2010
    Problem solved. Blowned circuit breaker.
  • Dometic Master
  • 6,674 Answers
Sounds like 2 separate problems here. First on the AC, have you confirmed that your breaker to AC is on? Do you hear any "clicking", or "Humming" at AC when turned on?
As far as fridge goes, how long has it been on? Has it just recently been turned on from being off for a while? Have you checked that lower door is closed and seal good?
Posted on Aug 26, 2010
  • 944 Answers
This is surely not a electrical issue.All the electrical items are interdependent.
First let us see what could be the problem in air conditioner
1)When the filter gets clogged with dust, the condenser fins on the inside part of the furnace can not "breath" which causes it to freeze up, literally. Be sure to change your filter or Clean it.
2)Check the fuse and circuit breakers. The thermostat is to be adjusted to cool and below room temperature. The condenser power and furnace power switches are to be turned on.
3)There could be a small leak in the system that allows the refrigerant to escape and when enough has leaked out, the low pressure switch is activated to shut the compressor down to make sure that the compressor does not burn itself out. When this happens, you will notice the compressor running for a short time and then shutting off. The system needs to be recharged and then leak tested, repaired, and recharged. Generally, a fitting or a hose has leaked and once it is repaired you AC will work fine again.
4)Can you hear Buzzing noise on the outside uni?if it is buzzing then
1)No power
2)Bad capacitor
if it is not buzzing
1) bad contractor
2) Low freon pressure switch could be bad
3) Thermostat wires problem.
For the fridge issue:
Problems with the defrost timer or defrost thermostat.IF they go bad.the exchanger will ice over and make it ineffective at cooling the fridge.So if it is bad replace it.
some time compressor may also fail.See there is no damage in wire and remove the dirt that clogs near the back grill of the fridge.
If you don't have hands on please don't play with electrical items.Please take it to the nearest service center
Please do rate the solution if the issue is resolved or post a comment for further assistance.
thank you for using fixya have a nice day:-)
Where can I find an owner's manual for a 1985 Nomad 5th Wheel,25 foot?
[PDF]travel trailer fifth wheel owners manual - Skyline Corporation
www.skylinecorp.com/faqfiles/1YearTTFWOwnerMan-old.pdf
Nov 15, 1993 - a quality product along with the very best service available in our ..... in this manual includes fifth wheel travel trailers unless otherwise indi-.
Manuals - 1989 & older - RVing-The Midwest Connection
www.rvingthemidwestconnection.com/manuals1989older.htm
1989 Skyline Nomad Manual Request Thank you, Dean Will (4-15-14) ... looking forowners manual for a 1989 Okanagan 5th wheel trailer. ...... Looking for an owners manual for a 1985 Cobra motorhome on a Ford Chasse I have the owners ..
PDF]Skyline Travel Trailer Nomad Owners Manual
www.rjwoerheide.com/skyline-travel-trailer-nomad-owners-manual.pdf
repair manual 2015 used travel trailer - 2015 skyline nomad 190 and 1995 ... bing jabiru 2015 nomad travel trailers/5th wheels - nadaguides ruby nomad ... 1985 service free 1997 skyline nomad 3710 travel trailer lexington, nissan pulsar ...
Jan 01, 2016 | Cars & Trucks
What do I replace it with
The switching on/off is due to frayed wiring.
Aug 17, 2015 | Heating & Cooling
I have a 2010 30' cougar travel trailer, we have never used the air conditioner which is a coleman mach model, when I put it on auto and cool it blows cool air but never gets cold am I suposed to
Check the temperature of the air coming out the vent If it's more than 10 degrees below the air going in it's ok. If it's the same temperature, the condensing system may be not working. The compressor may just be a quiet one!
May 18, 2012 | Coleman Mach III Air Conditioner
On my 1999 camper trailer when I turn on the dc powered lights while the airconditioning is running the compressor will kick off. If you wait 3 minutes it will come back on and continue to work fine until...
Welcome to FixYa
Not enough cooling complaints are due to air flow issues, and not lack of “Freon.RV air conditioner- come from the factory- are hermetically sealed.The first basic area is the air filter. In summer, using the RV and air conditioner around the clock, the filter should be checked weekly and cleaned as needed. RV air conditioners use either a foam type filter or a fine mesh, both of which can be rinsed in water and reused.keep the filter(s) clean.Few years latter even the best filter will let enough dirt past to coat the evaporator coils, though, so they need to be cleaned. If the coils are not too dirty, and if the installation leaves enough room to access the coils.Once the cover is off, you can see the evaporator coil -Clean Coils too...
Thanks for Contacting FixYa....
Jun 10, 2010 | Dometic Rooftop RV Air Conditioner
1999 springer camper Air conditioner stopped
I just repaired mine today...Is your ac ceiling controled or thermostat controled?
May 26, 2010 | Dometic Rooftop RV Air Conditioner
Travel trailer a/c
Hi, W/D here.
Your unit does sound like it is low on refrigerant, but there may be another issue at play here also. Do you fave the ability to bring fresh air into the camper via the A/C? If so, were you bringing fresh air in when it froze up? Here's why I ask; Purely recirculated air has much more humidity in it than air that is coming in from the outside, even in high humidity areas. If your camper was closed up tight and recirculating air, your unit could very well freeze up. That explains why just running the fan fixed it. Contributing factors would be dirt on the coils, and low refrigerant, but ask yourself "Did we have this problem during the day when we were in and out (allowing fresh air in)?" If the A/C worked well when it was hotter, my opinion is that the issue is more of a moisture problem than a refrigerant problem. If you can allow some fresh air in the trailer by way of the A/C, I'd try that first, especially at night
Best regards, --W/D--
"To be is to do -Plato-
To do is to be -Socrates-
Do Be Do Be Do -Sinatra-
Aug 14, 2009 | Dometic Rooftop RV Air Conditioner
I have a duo therm brisk air model 57915-001 leak
Could be the drain path is clogged.. Take the cover off & see if you can get it cleaned..
Jul 09, 2009 | Dometic Rooftop RV Air Conditioner
2008 Jayco Eagle 31bhds furnace and air conditioner problem
check your power source coming to the unit. also check to mack sure you have the unit set for A/C if your air conditioning. Also on most furnaces there is a kill switch when you remove the doors, usually on bottom. make sure that button is pushed in, if not it will completly kill the power to everytihng.
Apr 22, 2009 | Heating & Cooling
Dometic Rooftop RV Air Conditioner Logo
74 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
