Question about Whirlpool LER5644J Electric Dryer
Our dryer works, and you can hear when it fires up, and it stays lit for a little while, but then it goes off, and we have no heat
    Novelist:
    Champion:
  • 266 Answers
Can you hear the dryer turning. It sounds like you have a Hi Limit switch kicking the heat off. This can be caused by lint build up in the bottom of the dryer and in the blower motor housing. Usually the drye exhaust vent is pinched and has plugged with lint. Try cleaning this first. There are other more indepth problems if this doesnt help just let me know I will be happy to help. good luck and remember to unplug the electricity before taking the back off the dryer ect.. be safe
Posted on Aug 26, 2010
My majestic fireplace lights and the burner lights and I turn on the switch and the burner stays lit for a minute or two then I hear a click and the burner and pilot light shut off
yes this would appear to me to be the classic symptoms of a bad thermistor , this little device proves that fire has lit (via heat) and keeps gas valve open , otherwise gas valve times out and shuts off (safety)
Oct 15, 2016 | Majestic Heating & Cooling
Coils lights up but no heat goes up to drum
if your heater coil is working
dryers have a cool down cycle built in
the coil heats shuts down
and drum rotates till end of cycle
Oct 13, 2016 | Dryers
My jotul 200 direct vent gas stove pilot light won't stay lit. The pilot lights normally, and fires when the thermostat calls for heat. But when it turns off the pilot goes out as well. We cleaned ou
There's a little screw that adjusts the pilot light. It is usually on the block with all the other valves. Follow the pilot lite supply line to where the screw probably is located.
Nov 22, 2013 | Stoves Heating & Cooling
Jandy lite 2 pool heater will not stay lit.
I'm having the same issue as the above user with Jandy Lite 2 (which from what I can tell stands for the number of times that you can get this POS to work annually)!
The unit LIGHTS OFF, but WON'T STAY LIT! Igniter engages, gas valve opens, unit lights, burns for 10 seconds, and flames out. Error code FL 2, after third attempt, already replaced the flame sensor....
May 12, 2013 | Pool & Spa
I have AMANA NGD 5500TQ0 DRYER AND FIRES WON'T LIT
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 18, 2011 | Amana NGD5500TQ Gas Dryer
Gas Dryer not staying lit....it will fire up then the flame goes out. We replaced both thermastats.
This is usually the dryer coils have failed. They tend to fail as they heat up. They are inexpensive and easy to replace. Here is a video on replacing the dryer coils. If you need further help try this link for troubleshooting a gas dryer
Dec 16, 2010 | Crosley Dryers
Maytag neptune dryer will not stay lit. It starts up, lights, stays lit for about 1 minute and then goes out
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Aug 09, 2010 | Maytag Neptune MDG5500AW Gas Dryer
We have a commercial inglis gas dryer..under door is a model number JO-71200 when i search for it says no match.dryer quit about a week ago we replaced a few rollers then we noticed clothes weren't...
Well I'm not familiar with gas delivery systems on dryers, but I can tell you how they work on home heating boilers and I'm sure they are very similar. There are two type, standing pilot (which you have) and spark ignition. Spark ignition uses two electrodes with an electric spark to ignite the gas. Now your situation your dryer may have what is called a thermocouple which is like a little metal cylinder connected to a wire. When the flame is lit it heats that thermocouple which produces a voltage. That voltage keeps your gas valve open to keep the pilot light lit. If your pilot light is lit then the thermocouple is not bad. You need to check your circuit and see where the break is. Its true it could be a thermostat. To check a thermostat you need to take it off the dryer and you can either use a lighter or put it in boiling water till you hear is pop or open up. If you hear it pop twice then it is good (you'll hear it pop once when it heats up and once when it cools down). There is a circuit that keeps that gas valve open, and after 10 seconds something is opening that gas valve circuit, you need to see what all is connected to it, then you will solve your problem.
May 08, 2010 | Dryers
Gas dryer not heating properly
This sounds like the flame sensor is bad to me.
If it does not work properly, the unit will shut off for safety. The machine assumes that the burner did not light and rather than run gas into your house, it shuts off. It may try to start a certain number of times and then shut off.
You may be able to remove and clean it (flame sensor) lightly with a scotch brite pad and it may work properly again.
Otherwise it will need replacement.
This is a very common problem and the part is probably in stock.
Post a comment on your progress as this solution is likely to be useful to many people.
Thanks,
Tim
The problem is not the gas valve.
May 06, 2009 | Whirlpool LGR5636L Gas Dryer
Maytag dryer dg712 does not stay lit
Yeah change the coils read my page on intermittant coils HERE
Apr 12, 2009 | Dryers
Whirlpool LER5644J Electric Dryer Logo
14 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
