Question about Frigidaire GLTF2940E Gallery 3.5 Cu. Ft. King Size Front Loading Washer
Washer only stays on rinse cycle
No matter where i put the washer control on the gallery stackagle (Quick wash, delicate, whites) the unit never goes into the spin cycle, never drains all the way, never reloads with fresh water.
I reset the power. shift the cycle knobs all over the place, yet no change. Only soppy wet soapy clothes.
  • 3,037 Answers
The first thing to check in a no-spin condition on any washer is the lid switch. The whole purpose of the lid switch is to stop the tub from spinning when the lid is opened and this should also cause it not to drain or fill. It’s a safety thing.
A quick check of the lid switch is to slowly raise and lower the lid a little bit and listen for a faint clicking sound. This is usually a pretty good indication that the lid switch is working but it’s not definitive. A better test is to put an ohm meter on it and test the switch. You can access the switch by removing the washer cabinet.
The lid switch will most likely look like one of the two pictures below. You can click the pictures for a larger view and to order the part.
Older-style Lid Switch
washer only stays on rinse cycle - 00094434.jpg Newer-style Lid Switch
Posted on May 06, 2008
  • Benjamin Patri
    Benjamin Patri May 06, 2008
    here is what the switch could look like
  • Benjamin Patri
    Benjamin Patri May 07, 2008
    Please don't forget to let me know your thoughts about my solution.
    If your problem is fixed, please rate this solution as that is one of the biggest
    aspects of how this website works and in order to receive any credit in
    helping you, I need to be rated.
    Otherwise, let me know if you have further questions and I would be glad to help.
    Thank you
  • 818 Answers
The problem is the door.The door does lock, but does not send the correct signal allowing the washer to spin!!
Sergio
    Genius:
  • 1,142 Answers
Please give the make and the model #
  • Maanita Chadha
    Maanita Chadha May 07, 2008
    It won't drain
    If your washer won't drain, check these:
    It spins, but doesn't pump
    It doesn't spin or pump
    It pumps, but the water returns
    If
    your washer spins but doesn't pump the water out, the drain line is
    probably clogged. In many washers, a small sock or other piece of
    clothing can get between the clothes tub and the outer tub that holds
    the water. If the clothing gets between the tubs, it may then get into
    the drain hose that's attached to the pump--or even into the pump
    itself. If it's in the pump, you need to remove the hoses from the pump
    and pull the item out.
    To remove the sock from the outer tub
    port, open the washer's main access panel and remove the large-diameter
    rubber hose that connects the pump to the bottom of the outer tub.
    Then, using needle-nose pliers, try to grab and remove the clothing
    through the port.
    Sometimes you can't remove the stuck
    clothing from below. Then you have to remove the agitator, top of the
    outer drum shield, and inner clothes tub. This isn't easy to do--and
    you may need special tools--so you might be happier getting a qualified
    appliance repair technician to do the job.
    If the drain line
    isn't plugged, the problem may be with your pump. Even if the pump
    appears to be turning, the internal impeller may be broken. If so, you
    need to replace the pump.
    If
    your washer doesn't spin or pump water out but the motor is running,
    your washer probably has a frozen pump pulley. If so, you need to
    replace the pump. To check the pulley, remove the pump from the washer
    and try to rotate the pulley manually. If it doesn't turn freely--if
    it's frozen or stiff--replace it.
    If
    the water that pumps out of the machine goes back into the machine
    after the spin cycle, your washer may be siphoning the water from a
    laundry tub that has a slow drain, back into the washer. The usual
    remedy for this is to improve the draining of the laundry tub. (Is
    something stuck in the drain?) Also, check for these problems:
    • If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
    • If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Not spinning
Its likely you need a new motor speed control board, its the most commonly replaced board in these washers.On this model its located underneath on the right or left wall.You can't really test this but try putting the washer in to the Spin and Rinse cycle, if it doesn't spin then that is most likely your trouble.I did a quick Google search and found this page for the part:http://www.appliancepartspros.com/frigidaire-control-board-134743500-ap3891780.html
Feb 19, 2013 | Frigidaire GLTF2940FS 3.5 Cu. Ft. Front...
I need to know what the buttons say on the dishwasher. Mine have no letters
Some SHX46 washers have 4 wash cycle buttons and others have 5. The button on the left side on top of the door is the start/stop button regardless of how many wash cycle buttons you have.
If you have 5 cycle buttons, reading from left to right they will be as follows.
1. Top Rack Only / Sanitize
2. Power Scrub Plus - (Long wash for heavy soil)
3. Regular Wash - (Economy wash for light to medium soil)
4. Delicate Wash - (Shorter wash at a lower temperature for delicate items)
5. Rinse & Hold.
These buttons are also used for cancelling a wash cycle. Hold down buttons 2 and 4 (Power Scrub Plus and Delicate) at the same time to cancel a wash cycle and drain the water out.
If your washer does have 4 buttons, it means you don't have a Top Rack / Sanitize cycle, in which case the button configuration - from left to right - will be:
1. Power Scrub Plus - (Long wash for heavy soil)
2. Regular Wash - (Economy wash for light to medium soil)
3. Delicate Wash - (Shorter wash at a lower temperature for delicate items)
4. Rinse & Hold.
With this button configuration, the cancel cycle buttons are 1 and 3.
I hope this solves your problem. If you need any additional information, please post back.
Regards,
BElectric
Dec 12, 2010 | Bosch 24 in. SHX46B05 Stainless Steel...
Kenmore washer model 12502100 goes into rinse cycle fills with water turns then stops. won't drain just stops hear humming or buzzing noise.
Try to put it on rinse on another cycle, like normal, heavy duty or delicate. If it works, then your timer is probably bad. If it doesn't work then maybe the pump. Best of luck
Mar 21, 2010 | Washing Machines
Amana washer only works on delicate cycle
Open the control panel. Unplug the timer and then plug it back in good and firm.
If it does not work correctly after that,
Replace your timer.
Mar 12, 2009 | Amana Washing Machines
Printed wash cycle info missing from front of machine
Quick wash cycle for the Hotpoint FEW12 is 'K'
A 95* White cotton, heavy soil ........ 5.5kg 2hours 30/40 mins Fast spin
B 40* White cotton Heavy soil .......5.5kg 1hour 40/50 mins Fast spin
C 95* White cotton and linen without special finishes......5.5kg 2 hours 20/30 mins Fast spin
D 60* Colour fast cotton, linen or viscose without special finishes......5.5kg 2hours 5/15 mins Fast Spin
E 40* Non-colour fast cotton, linen or viscose.....5.5kg 1hour 40/55 mins Fast spin
F 50* Synthetics, coloured nylon, polyester, acrylic & cotton mixtures, cotton or viscose with special finishes, coloured polyester & cotton mixtures.....3kg 1 hour 5/15 mins Slow Spin
G 40* Acrylics and tri-acetate blends of these fabrics with wool, polyester & wool blends....3kg 40/50 mins Slow Spin
H 40* Wool, shrink resistant machine washable wool, woolen blankets..... 1.5 kg 1 hour 15/25 mins Fast Spin
H...(Wool mixtures with cotton or rayon.....2.5 kg)
J 30* Silk, printed acetate.....3kg 55 mins/1 hour 5mins... Slow Spin
K Quick wash for freshening up lightly soiled items. Warning... not for woolen, silk or delicate items.....1kg 35/45 mins Slow Spin
L Cold wash, cold fill only, no heating action....3kg 55mins/1hour 5 mins Slow Spin
M Rinse and Fast Spin... cotton......5.5kg 55 mins/1hour 5mins...Fast Spin
N Rinse and Slow Spin... Delicates....3kg 30mins Slow Spin
P Fast Spin .... cotton.... 5.5kg 15 mins Fast Spin
Q Slow Spin.... delicates.....3kg 15 mins Slow Spin
Hope this helps
Sue
Jul 14, 2008 | Hotpoint First Edition FEW12 Front Load...
Put 2 pieces (scrubs) in the whirlpool duet steam washer alone on quick wash cold cycle....alarm sounded code F 20 blinked...door stayed locked no matter which control I pushed...had to unplug the unit to...
not a serios problem but one i reccomend calling whirlpool about, can be a number of things causing issue from poor water supply to a kinked water hosewithin machine
Jul 09, 2008 | Whirlpool Washing Machines
Water
its probably normal as new machines now only put in enough water to saturate the clothes its only the rinse or wool/delicate cycles that use a higher water level
Mar 01, 2008 | GE Energy Star WCVH6260F Front Load Washer
Service Mode
System Diagnostics
SERVICE MODE
The service mode provides service personnel the
ability to verify the operation of the washing machine.
The service mode can be entered in the middle of
any wash cycle. While in the service mode, the
servicer can start a variety of special service tests.
Accessing Service Mode:
Pressing down the delicates and heavy soil keys for
3 seconds places the machine in the service mode.
Motor speed will be displayed when started. To exit
Service Mode, press delicates and heavy soil keys
for 3 seconds again.
Troubleshooting
December 2004 4 16025861
©2004 Maytag Services
Stage of
Wash Cycle
Advances To
Presoak End of Presoak
Wash Every 5 Minutes of
Wash Time
Spin/Drain Every Step of The
Spin Profile
Rinse End of Rinse
Speed Range Displayed
a) 0-99 rpm 0-99 (actual)
b) 100-999 rpm Speed / 10
Quick Service Cycle
While in service mode, pressing the delicates key
will start a quick service cycle. This will be a quick
check of all systems.
The following steps will be followed.
1. Energize the cold and bleach water valves. Fill to
Low level, then turn bleach and cold off.
2. Energize the hot and fabric softener water valves. Fill
to high level, then turn all valves off.
3. Lock the door.
4. Tumble using 7/3 tumble pattern for 12 sec.
5. Turn the drain on.
6. Spin to 800 RPM using default rates.
7. End spin and coast down.
8. Unlock the door when the RPM is zero.
9. Display a ‘PA’ (Passed) on continuously for 10 seconds
if no diagnostic codes were logged during this
test.
The up arrow if pressed will advance to the next step.
The right most dot will be turned on as an indication
of failure and stay on until quick service cycle test
has reached the end. Any diagnostic code logged
during this test will result in failure of the test, but will
not necessarily stop the test. While in quick service
cycle, the pressing of the hand wash will suspend
the machine at this step for 30 minutes until the
Hand Wash key is pressed again. All LED’s will
flash on and off while the cycle is suspended, or on
hold.
Motor Drive System
To check the system, check the board for proper
output to the motor control. Performing a board
output test does this. Then perform the Motor
Control Board Output Test.
Motor Control Board Output Test
1. Disconnect power to the washer.
2. Remove the front panel and pull the JP4 Connector
from the motor control board.
The following Quick Spin test steps are as follows:
1) Lock the door.
2) Spin to 350 rpm and hold for 6 seconds.
3) Spin to 550 rpm and hold for 6 seconds.
4) Spin to 600 rpm and hold for 6 seconds.
5) Spin to 650 rpm and hold for 6 seconds.
6) Spin to 800 rpm and hold for 6 seconds.
If the Spin key is pressed again during the Quick Spin
test, the current speed will be held indefinitely. Pressing
the Spin key again will allow the quick test to
proceed as listed above.
When the washer is in the Service Mode, the speed
will be displayed as a two digit number or a letter/
number.
Quick Spin Test
While in service mode, the pressing of spin key shall
start the washer in the quick spin mode.
3. Reconnect the washer power cord to supply
voltage. Make sure the door is closed.
4. Press delicates and heavy soil keys for 3 seconds
to activate Service Mode.
Jan 23, 2008 | Maytag Neptune MAH5500B Front Load Washer
Frigidaire GLTF2940E Gallery 3.5 Cu. Ft. King Size Front Loading Washer Logo
104 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
