Question about Refrigerators
My refrigerater is cooling well at the bottom in the refrig and freezer but warm up top
    Scholar:
  • 149 Answers
Sounds like a defrost problem or the freezer fan is stopping at some point, verify if your freezer's iced up if it is suspect a faulty defrost timer/ thermostat if your handy with and voltmeter put it on the continuity or "beeping" function check your defrost element (with power off) you disconnect the wires to the defrost element put one lead of the meter one one end and the other end on the other side.
if it whistles, element's good if it doesn't whistles suspect a bad defrost element replace element/and defrost thermostat
Posted on May 06, 2008
Vegetables in crisper are frozen, as well as liquids in bottom 1/2 of fridge door. The fridge & freezer temp controls won't adjust to our settings. Also, we're getting ice, but no water will dispense.
The freezer cools the refrigerator, so you actually get very cold air passing from the freezer to the refrig. The air from the freezer enters the refrig on the top and falls to the bottom where it is drawn back into the freezer. The temperature of the refrig is regulated by a thermostat and a fan that runs when the thermostat calls for cooling. If the refrig thermostat is faulty and causes the fan to run more than it should, there will be a freezing problem in the refrig at the bottom because cold air falls and warm air rises. If the refrig is thermostat is calling for cooling constantly, this will take more cold air from the freezer than is normal. Your freezer temp might be higher than normal and the refrig will be colder then desired. If the fan from the freezer is running constantly I would suspect a bad refrig thermostat.
May 06, 2015 | Refrigerators
Bottom freezer maytag refrig. not cooling. freezer fine. #mbf1956kew
the refrigerant could be low, the compressor might be shot, either way it's better to get someone to fix it for you.
May 20, 2012 | Refrigerators
Bottom freezer is fine but top refrig. is warm. Have vacumned bottom front coils, unit less than 2 years old. Any suggestions, other than calling repair? thanks.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 26, 2010 | Amana AFF2534FE Bottom Freezer French...
Top freezer works but the bottom refrig is blowing warm air
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Sep 03, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Freezer build up with ice bottom refrigerater warm
you have a defrost problem or a plug drain problem.
Jun 24, 2009 | Roper RT14DKX Top Freezer Refrigerator
Kenmore top freezer unit-refrig not cooling past 50degrees
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
Sep 03, 2007 | Kenmore 64802 Top Freezer Refrigerator
Refrigerators Logo
77 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
