Question about Dryers
I have opened the back of my Hoover tumble dryer and taken out all the fluff...it is overheating all of the time and a friend suggested that the belt might be broken. I unplugged the machine and moved the smaller round wheel and the belt flew off and now I can;t get it back on!! What a dill I am!! Can anyone help please
    Novelist:
    Champion:
  • 266 Answers
It goes arount the motor pully and the lower side of the belt goes up and over the tension pully. Also on you overheating problem turn your dryer on with no heat and see if air is coming out of the outside vent. It should be a good volume. The next thing to check is the blower housing just follow the exhaust vent and the lint trap they will lead you to the blower wheel housing and duct to the lint trap. Remove the screws around the outside metal casing and seperate the casing exsposing the blower wheel you will find a lot of debris. Make sure the wheel is secure to the center spindle. Then make sure your hose leaving the dryer is not kinked when you push the dryer back and it is clean. Always unplug your dryer before starting on repairs and good luck..These are the most common problems
Posted on Aug 26, 2010
How to fit drive belt on reverse action crusader tumble dryer ct31v
Go to www.repairclinic.com and enter ct31v. You may be able to get some information.
Jun 28, 2016 | Washing Machines
Dryer not tumbling
Look up the model, google or the like and see if u can find some schematics. Its does seem likely to be the belt but u may find a better way to crack it open.
Aug 31, 2012 | KitchenAid KEYS750LQ Electric Dryer
Hoover HDV 7 FM tumble drier. The drum is not turning (its making a loud buzzing noise like its trying to get going) and the filter light is on, although that is free from fluff. Is it time for a new drier...
sumanth m 's answer may well be correct because I have the same dryer and it has the same problem. I got a massive electric shock off mine and so I think the buzzing is a protection measure against a short circuit
Feb 15, 2011 | Hoover HDV7FM Electric Dryer
I need to clean my filter on my beko tumble dryer!
I usually just stick the shower on it to clean out all the bits of fluff that gets gathered in there, but remember to give the inside of that hatch u brought it out of with some kitchen towel before u put the condenser filter back in.
Feb 23, 2010 | Dryers
Hoover tumble dryer vhc392T drum not turning. There is power to the machine but the drum wont turn.
check the belt to see if it is broken. check the drive motor to see if it is working.
Jan 10, 2010 | Hoover HDC6 Electric Dryer
Hoover Maxi 6 TC50 Tumble Dryer making squealing noise
Have you fixed this problem? I also have a Hoover condenser dryer, only a few months old, and has started to make a squeal/whistle. I'm thinking it might be the front fan needing some WD40, OR too much water vapour around the belt that moves the drum causing the sounds.
If it's the fan, lubricating the shaft and its components should fix the problem, if a wet fan then I'd think maybe fully cleaning the condenser filter, reservoir ect will fix the problem.
The problem seems to go away though "mostly" 15 or so minutes after you start the dryer, so that makes me think ones it gets warm something is expanding to allow more "give" so maybe the belt.
Aug 26, 2009 | Hoover Dryers
I need to put a new drive belt on my hoover hdv6 tumble dryer, how do i do this?
usually two belts one from drive motor and the other a big one to turn the drum. Take the back access panel off and loosen the tension on the motor for the first one ... for the drum belt you have to pop the top of the dryer open (use something like a paint stir stick and a hammer on each front top corner of the dryer to pop open the clips. nothing metal or you will chip the enamel paint)
Aug 16, 2009 | Hoover Dryers
The drum on the tumble dryer isnot moving, why is this?
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Jun 18, 2009 | Zanussi TC180W Electric Portable Dryer
Re-Hoover nextra8 hnc380 Tumble dryer
Had this problem with mine. Its the belt tensioner pulleys that have seized and cause the noise.I got 2 net tensioners and fitted them myself.The parts come to about £15 but its a total strip down to replace the parts. been working fine now for about a year
Feb 21, 2008 | Hoover HDC6 Electric Dryer
Zanussi tumble dryer
take it apart and you will see that the belt is probably find the belt broke
Nov 05, 2007 | Kenmore 64902 Electric Dryer
Dryers Logo
63 people viewed this question
Top Dryers Experts
