Question about Dell 1320c Laser Printer
I have horizontal lines on my dell1320c printer. How do I do a clean and align cycle?
Alignment failed
Your cap and wiper assembly has build up on it. The cap and wiper assembly is the part of the printer that keeps you ink cartridges clean but after a while it accumulates a lot of dried up ink and dirt / dust. If you open up your printer and get the carriage assembly to slide over, unplug the printer and look inside where the cartridges just came from. The wiper assembly looks like a little rubber windshield wiper and works much in the same way. Some models have as many as four wipers. You can use a q tip with some alcohol on it to rub the wipers clean and get off all the ink. After cleaning all the wipers off re-run the printers cleaning cycle a few times and the lines should go away.
Nov 03, 2013 | HP Photosmart Premium C309g multifunction...
HP 6180 Print Problem: I'm getting horizontal streaks when printing either in colour or black, Have cleaned the heads through the printers tool box and ued both levels of cleaning. Also aligned the pr
Fill an old black cartridge with hot water and scan and copy something with a lot of black on it. cleaned out my black ink clog after about 12 copies. Put new ink in and it's working fine. Oh yeah, use a syring minus needle to fill lower o-ring on back of cartridge.
Dec 26, 2011 | HP Photosmart C6180 All-In-One InkJet...
Describe your Epson Photo 1400 Stylus printingProblem I have lines appearing on My prints, I have cleaned and re aligned the print heads but no joy
: i'mma having problem with my epson 1400 it keep on having horizontal line on the picture after in clean the head and align it
May 16, 2010 | Epson Stylus 1400 InkJet Photo Printer
Horizontal lines in photos
Do head cleaning. Print at best photo quality.
May 04, 2010 | Epson Stylus 1400 InkJet Photo Printer
Horizontal lines
If they are really vertical lines you need to clean the encoder strip. The clear strip that runs across behind the carriage, you clean it with a Q-tip and alcohol. If they are horizontal you need to clean the encoder wheel which requires taking all the covers off. The wheel is on the left and is a clear circle with black bars.
Feb 01, 2010 | HP J4680 Office Jet All-In-One Printer
Horizontal printing not straight
Have you cleaned or replaced the printhead recently?
Mar 21, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Extra horizontal lines on my document.
Have a real good cleanup of the ink that was (presumably) leaking from the old black cartridge. Remove the cartridges from the cartridge carrier and use kitchen paper towel to soak up any ink in the bottom. Give the cartridge outlet holes a dab on the towel as well. Replace the cartridges promptly.
Turn the printer on, and as soon as the print head moves, pull the power cord out of the back. You should now be able to (carefully) move the print head by hand. Place a layer of paper towel on the printer track, and move the print head across it to mop up any surplus ink. Move the print head across to the left out of the way and use kitchen towel to mop up surplus ink in the Print Head parking area.
Now turn the printer on and carry out a cleaning cycle (right click the little printer icon in the bottom right corner of the screen and select clean). Now run a nozzle check (right click the little printer icon in the bottom right corner of the screen and select nozzle check). Are there any extra black lines in evidence now? If so, try another 1 or 2 cleaning cycles and nozzle check. Black lines gone now?
If you still have the black lines, come back with a new comment.
If this information is useful to you, please rate it.
Jan 29, 2009 | Epson Stylus C88 InkJet Photo Printer
Horizontal red lines when printing
Horizontal line is carriage axis , while moving its may give line if some dust or resdual ink may be on he carriage base
clean the caping station and cleaning wiper ( place where carriage rests )
if its not resolved please update sample images for same
May 24, 2008 | HP Officejet 6310 All-In-One InkJet...
Faint blue horizontal lines
Try re-installing the printer driver it might be caused by a virus... if not then you need somebody to clean your printers head mechanism.. the blue cartridge might have messed an ink to its circuit.
Oct 27, 2007 | Epson Stylus Photo R200 InkJet Printer
Dell 1320c Laser Printer Logo
559 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
