Kitchen aid model superba selectra oven door will not unlock after self clean control panel shows f3
  • frenchy1930 Aug 26, 2010
    sorry i tried his suggestions but had already done those things thank you frenchy
  • 3,083 Answers
One fellow with a similar model explained what he did to a similar model:
http://www.ehow.com/how_5499974_unlock-kitchenaid-superba-oven-locked.html
Another person with a different model mentioned hitting cancel 3 times. Another method was to press function, (5), then (2).
Posted on Aug 26, 2010
  • 4,924 Answers
T is a 2 to 3 hour process with a cool down time of 1 to 2 hours before it will unlock the door,,,if it does not unlock you will need to replace the door locking mechanism to accomplish this repair.. so ..if you just made th self cleaning ..it will be a period for the cooling down ..and only after that will unlock the door..but there is a possibility that from the high temperatures during the self cleaning process the door lock to be damaged and to need replacing ...you will see that if after you manage to unlock it is still functional or not..
if after a few hours it is still not unlocking ...try to reset it by keep down the start button for a few seconds...and try to shake the door gentle in case it is stuck ..or the volume increased from dilatation ..it has to came out ...after that try something to degrease the lock ..and make it functional again ..
  • Catalin Turcu
    Catalin Turcu Aug 26, 2010
    http://tweetys.com/teacusb20tvtuner.aspx
    In the quality price percent ..this is the stuff you need..
    here there are specs about the item if you want to read about ..
    http://www.superwarehouse.com/Teac_USB_2...
    I assumed that the stuff I presented you first was not on your taste or was to evasive..
    If would get some item to do the job for a laptop this will be the one ..cause it does everithing ...is small compact ..good make ..and reliable
    ..(I repeat on a laptop is almost impossible to insert a internal one cause of the lack of PCI slots)
Why is oven door locked after self-cleaning mode?
How To Fix Oven Door That Doesn't Open After Self Clean ...
www.partselect.com/...Stove-Oven/Door-Will-Not-Open-After-Self-Clea...
How To Fix An Oven Door That Won't Open After A Self Clean Cycle ... This may reset the control and allow you to unlock the door. If you still cannot unlock the .
Repair - Dead oven after self clean mode, blank display ...
? 9:38
https://www.youtube.com/watch?v=UylZKwzAPow
Feb 22, 2014 - Uploaded by Random Repair
Repair - Dead oven after self clean mode, blank display, locked door Kitchen Aid Whirlpool How to repair an ...
Nov 26, 2015 | Kenmore Kitchen Ranges
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
on Apr 24, 2015 | Kitchen Ranges
Tip
F5 - E0 Door Switch
Two digit codes:
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
How to unlock a kitchenaid superba stove
How-To Unlock A Kitchenaid Superba Oven - YouTube
? 1:24
www.youtube.com/watch?v=yKNGTVCEiuM
Sep 22, 2014 - Uploaded by Public Relations & Promotions
How-To Unlock A Kitchenaid Superba Oven ... Repair - Deadoven after self clean mode, blank display, locked door Kitchen
Sep 09, 2015 | KitchenAid Kitchen Ranges
Hi, I have a Selectra 30 and the panel has gone dark and the oven door is locked. If I unplug it and remove the back cover I can unlock the door manually. When I plug it back in the door locks again and...
First of all, why did you post a question about an oven under a dishwasher question? What is a Selectra 30? That is not the model number. The model number of the dishwasher in the subject does not help. Without knowing anything else, I would say you have a bad control board.
Dec 17, 2014 | KitchenAid Kitchen Aid Superba Series...
We a kitchen aid oven the door was accidentally lock. Can you find out how to open it? Whirlpool owns kitchen aid
  • Look for a manual lever to unlock the oven. If there is one, it will probably swing back and forth horizontally, just below the upper edge of the oven door
  • Swing the locking lever, if one is present, all the way to the left. This should unlock the oven. If there is no manual lever to unlock the oven, it may be unlocked using push-button controls.
  • 3
    Check to see if the oven is in a self-cleaning cycle, or has just completed a self-cleaning cycle. If so, the door will unlock automatically once the oven has finished the cleaning cycle and cooled completely, which may take several hours. You cannot unlock the oven before it has cooled.
  • 4
    Unlock the "Clean/Off" button. Depending on the brand and model of your oven, the button may display both of these designations or just one. If your oven door is locked, but the oven is not warm and is not in a cleaning cycle, unlock it by pressing and holding the "Clean/Off" button.
  • Nov 18, 2012 | Ovens
    Kitchen aid wall oven Model YKEBS2780B1 SHOWS
    Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
    2. Test relay contact operation
    3. High resistance in oven temperature sensor F3
    Thanks
    May 26, 2010 | Ovens
    Kitchen Aid Oven - Superba Selectra- receive
    Here is what Kitchen Aid says about F4:
    F4 Meat probe shorted
    1. Disconnect meat probe and measure probe resistance (78kω at 60° F [15.6° C],
    37kω at 90° F [32.2° C]).
    2. If resistance is not valid replace probe.
    3. Insert probe and check for a firm connection between probe and jack (in oven cavity).
    4. Check connection between jack and harness (in rear of oven).
    It sounds like the probe jack may be bad or the wiring between the jack and the control board above.
    May 10, 2010 | KitchenAid Architect Series KEMC308KSS...
    Kitchen aid double convection oven - glass needs cleaning!
    Had to remove the screws on the BOTTOM of the outside door, then panel came off after all the screws (inside oven door included) were off...
    Reversed the order to put back on.. Cleaned (all) three glass pieces nicely... Now after reading the problems with the self cleaning part (doors getting stuck!) - I'm afraid to try mine!
    Jan 22, 2010 | KitchenAid KESC307 Electric Kitchen Range
    Door won't unlock after attempting the self clean. Self clean failed
    Usually an F3 code means the temp sensor has failed. The oven control thinks the oven is to hot to open. You may have a failed control, but I would try replacing the sensor first.
    Post back with any questions. Have been very busy at work and have not been online answering questions much lately but will answer back when I can.
    Thanks, Mike
    May 04, 2008 | Frigidaire FEF376 Electric Kitchen Range
    Computers & Internet Logo
    507 people viewed this question
    David Payne
    David Payne
