Question about Brother LS-2125 Mechanical Sewing Machine
I have a brother LS2125i it is easy to use, and I am a complete novice- but when I try to sew heavy denim- Like over the thickest part of the hem it makes a very load click nose- and becomes stuck--- is there a setting I can put on to avoid this or is it just too much for the machine to handle.
  • 3 Answers
It may be the machine, although most machines would have trouble going over the seam. First, use a Denim needle, 90 or 100 and place a "shim" also called a "jean a majig" to keep the presser foot level. If the foot is shifted, the machine will not sew over the bulk. The machine is not real heavy duty, may have problems , anyway.
Posted on May 06, 2008
How to adjust driver timing on brother ls2125i
What exactly is a "driver?" That is not a part normally associated with a sewing machine.
Nov 22, 2016 | Brother LS2125i Sewing Machine
Tension setting for sewing denim on brother LS 2125
Refer to 'Manuals Online', Brother sewing machine user manual. There is an excellent guide to tension settings for all fabric types. Also remember to check upper and lower thread has been wound through correctly and are using the same thread top and bottom. Ensure you have the correct needle size for denim ie 100/16 and the correct thread size ie 40-50 cotton or heavy duty polyester.
Nov 09, 2016 | Brother Sewing Machines
Is pfaff hobbymatic a heavy duty machine?
The term "heavy duty" sewing machine is thrown about loosely lately. There are new machines (including Pfaff, Singer, etc) for sale advertised as "heavy duty," but I would be hesitant to stitch denim jean hems on them. The Pfaff 807, which appears to be an older mechanical, is probably more "heavy duty" than some newer machines on the market. However, "heavy duty" does not mean that you can sew big canvas sailcloth or heavy upholstery projects. A domestic machine (which the Pfaff 807 is) is really meant for general domestic sewing. If you want to sew "heavy duty" fabric, then look to an industrial machine. Remember that frequent sewing of heavy fabric takes a toll on a domestic machine, ie the motor, needlebar, other working parts, thus hastening the demise of your machine and the more frequent need for service & repair.
Jun 17, 2016 | PfaFF Sewing Machines
I'm trying to sew jeans hem and stitches are uneven on top and loops are showing underneath. Also the foot and needle will not sew over cross seams and thread keeps getting snarled up underneath. Tha
a lot of machines struggle with denim because it is such a heavy and dense textile. Many domestic machines won't stitch it at all due to this. Things you can try however:
  • Denim needle, this has a deeper groove at the back and is a heavy gauge needle, or use size 110 if you don't have denim needle.
  • Bash the side seams with a hammer in the area you will be stitching, to soften up the fibres.
  • Use a seam jumper, this is a piece of plastic to put in back of the presser foot as you approach a cross seam to help keep the presser foot pressure even across the fabric. Sometimes called a "thingy-a-jean" or similar.
  • Don't bother trying to use the heavy gauge yellow jean thread unless you put it through the bobbin and sew with the right side down. But even then, many machines can't handle having this heavy thread underneath and the regular 50 cotton on top, my Janome 1600 won't do it.
  • put your machine on slowest speed if you have a variable setting and turn the flywheel to assist it through the heavy side seams.
Personally, I never bother with the twice turned hem on denim if shortening, I just overlock the raw edge, turn up 1 cm and stitch around in a matching blue thread so it is seen as little as possible.
Feb 03, 2014 | Elna Sewing Machines
I have been sewing denim, and the top thread keeps breaking at the needle. What adjustments do I need to make. It also bunches from the bobbin.
Are you trying to use a heavy thread like buttonhole twist through the needle like the yellow thread on store bought jeans? Most domestic machines will not cope with this heavy thread and it will be too large for the eye of the needle too.
If you are using regular weight 50 polyester thread and its breaking then it could be because the top tension is too tight. Just loosen off 1/2 a number on top tension dial and see if this helps.
If possible, buy a pack of jeans needles size 100 too, these are blue coated with teflon I think, and makes it easier to slip through denim which is a very dense fabric.
Hemming denim jeans is probably one of the toughest jobs for a domestic sewing machine so if you are trying to do this, its a good idea to take it slowly and use a "humpjumper" which helps to maneouvre over the thick side seams.
However, even with all the above, many machines won't sew more than one layer of heavy dense weave denim.
Jul 20, 2011 | New Home HF-106
I cut off jeans and turned them up to hem. Following all the directions in the manual, I began to sew, but the thread broke after only a few stitches. My thread is all-purpose thread. I tried tips in...
I turned up my husband's jeans using a size 100 needle. You can get easy thread needles that have a small gap in one side that you slide the thread through. There is a good way to turn up jeans and keep the original hem without having to cut them. Have a look at this site http://www.daciaray.com/?p=38
Aug 25, 2010 | Brother CS6000i Computerized Sewing...
Necchi Heavy Duty Sewing machine model 3205FA, bend needle while hemming denim skirt, replaced the needle, but now the needle is not picking up the bobbin thread, any suggestions for me to try???
Generally when the needle does not pick up the bobbin thread, it means the needle is either too far in or just plain the wrong length. YOu might want to try lowering the needle just a hair and see if that helps.
Apr 20, 2009 | Sewing Machines
I have a Necchi heavy duty sewing machine, I was hemming a denim skirt, the machine got bound up and now the threaded needle will not pick up the bobbin thread and bring it up. What could be the cause of...
I have the same machine. Try replacing the needle, it could be slightly bent and not be in position to pick up the loop from underneath. A good de-fluff may help too.
Apr 19, 2009 | Necchi Sewing Machines
Lower thread problem
are you still looking for an answer? if so I can help but I don't want to type all day if you already fixed it.
Sep 14, 2008 | Brother XL-6562 Mechanical Sewing Machine
Brother LS-2125 Mechanical Sewing Machine Logo
98 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
