Can the Parkzone ZX10 RC Transmitter be used as a buddy box. Can a Trainer cable be connected to it.
Transmitter and receiver
you have to use crystals and come in pairs. they plug in and out easily and make sure they are the same mhz
Mar 08, 2014 | Office Equipment & Supplies
Tip
RC looper and DR880 syncing.
RC-50 & DR-880 Setup
Rather than using the RC-50 to change patches on the DR-880, I have connected an FS-6 footswitch to both the RC-50 & DR-880. This gives me control of both units, I can select up & down through the patches easily.
Use a dual TRS connector and 2 stereo "y" cables connected to ports 1,2 & 3.4 on both units.
Once connected, you will need to assign the control function for each control port. I assigned Patch Decrease to CLT 1,2 & Patch Increase to CLT 3,4 on both units.
I then connected a MIDI cable from the RC--u control of start/stop & tempo via the RC-50 footswitches.
on Feb 25, 2015 | Roland Boss RC50 Loop station (with )
Tip
Using a video transmitter to extend your cable network to another TV in the...
When I first purchased a cable plan I only had one TV in my house and it seemed like a waste to get multiple cable boxes for TV that I had not yet purchased. When the prices came down on TVs I decided that it was time to get a set to go in my bedroom upstairs but I didn't have a cable box to connect to the set.
I could have gone out and spent a $100+ on a new bulky cable box that is not really all that pretty or I could get a video transmitter that will extend my signal to the upstairs TV set for around $50. Even though it takes a little bit of set up the results are great, I can even use the one remote on both television sets.
To set up your video transmitter first you have to take the transmitter and receivers out of the box and make sure that they are both set to the same channel. This will ensure that they will read each other. Then you take the cables that came with the transmitters and connect them to the back of the cable box, matching up the yellow, red and white cables to each other. Position the transmitter box so that it is lined up with the signal transmitter of the cable box.
Then you want to go upstairs to the second TV and connect the receiver to the back of the television set the same way that you connected the transmitter to the cable box. Take the remote from the set downstairs and it should have extended the connection of the cable box to both TV sets. Now you are able to control the cable box from upstairs and watch your stations on both TVs.
on Jan 22, 2014 | Televison & Video
Rc helicopter loses connection
Check the transmitter crystal (if it has one) and check the wires in the heli's receiver unit.
You should turn heli on wait 3-secs then turn transmitter on.
Dec 26, 2013 | Toys
I have a 42 inch maxent but i dont know where to plug my cable cord because i have a comcast box and theres no where in the t.v to plug my cable cord
If your comcast box has video (yellow), audio R (Red), audio L (White) out, just connect RC cables to the input of the TV at video, audio-in RC Jacks. If your comcast box has only RF out, buy one RF to audio-video converter and then connect these to the TV.
Jul 11, 2012 | Maxent MX-42HPM20 42 in. Plasma HDTV
Where doI find the slot to recharge my helicopter
with most rc helicopters you have to disconnect the receiver unit from its battery and connect the charging lead to the battery lead the charger should have 2 leads 1 for the transmitter & 1 for the receiver
hope this helps
Aug 08, 2011 | xheli Exceed RC 24Ghz WarHawk 300 4Channel...
I assembled my new Super Cub RC plane and when I put the battery in the plane the elevstor snd rudder would move, but when I pushed the throttle up it didnt work. I am new to this and troubleshot it many...
G o back to your manual. I had this problem also. The procedure must be followed properly. First, make certain your throttle is in the off/down position. Second, turn on transmitter. Third connect battery. Once you place the battery in the enclosure and lock the cover you should be working properly. Last but not least, when finished flying, remove the battery BEFORE powering off your transmitter. You must follow these steps. You can NOT leave the battery in the plane when not in use.
Jul 21, 2011 | Hobby Zone Hobbyzone Super Cub Propeller...
I need directions for Disney's Tokyo Drift Mater and Lightning Mcqueen RC cars. They came with a small wire that connected the car to the remote. I removed it when I first opened the boxes. Now, three days...
I think that the wire is for establishing communication between Mater and the remote. My son got one this year for Christmas and the batteries wore out quickly. I replaced the batteries in both, turned both off, hooked up the wire, then turned both on. When I disconnected the wire, it works again.
Dec 27, 2010 | Mattel Disney Pixar Cars Remote Control...
1989 zx10 transmission
dont buy it is not worth it.......
Jan 18, 2010 | 1988 kawasaki ZX 10
Terk wireless transmitter
Hi Sleopard,
Wireless transmitters should allow broadcasts of a single source such as a VCR, DVD player, or cable boxes. They normally wouldn’t be able to transmit something like a cable signal to your television. One way this could work is if you connected a cable box right below your outlet and then connected the cable box to your transmitter. If your transmitter has a infrared extender you may be able to change channels by pointing your remote at the wireless receiver.
Cordially,
Agent Jon
Go Ahead. Use Us.
Apr 13, 2008 | Televison & Video
Computers & Internet Logo
77 people viewed this question
David Payne
David Payne
