Slow hard to start - Computers & Internet
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 50 Answers
I will just give you some reasons why computer starts slowly and I hope these will helps.
1.Theres a lot of program in your computer are set in Startup:
- Try to download "CCleaner", you can download this for free at filehippo.com
- As you install this, go to the tab "tools", you can find the Startup here. Delete all the programs here which you might not need during start up.
2. Theres a lot of junk files and registry errors in your system.
- Using CCleaner, clean the junk files and fix all registry errors,,do not back up during registry fix.
3. You have a lot of icons or shortcut in your Desktop.
- More icons or shortcut slowdown the startup of your pc because it times for the system to read this, other graphics and display at your desktop may also slows down the startup.
Hopes this will help...Comment if you like my post..Thanks..!
Posted on Aug 26, 2010
2005 jaguar VDP 4.0L. Very hard start. Have replaced map and crank sensor, egr valve and intake.
in what way is it hard to start does the engine turn over fast or slow, fast is low compression in the piston chambers slow can be the battery or the starter motor wearing out. ( starter motor has bushes to turn the motor these wear out and cannot turn the engine over fast enough to start.
Aug 10, 2017 | Jaguar Cars & Trucks
Slow start up with pxe over ipv6 sign
It lost communications with the hard drive. Try physically reconnecting / re-seating the hard drive. Then verify that it is seen in BIOS.
Feb 22, 2013 | Dell Inspiron Computers & Internet
Status code 351f0000d08002008007045d my xbox started running extremly slow online
Your Hard Drive/Memory Card is failing, You must replace your hard drive. the reason why its running slow is because your hard drive is not sending its info fast enough which causes to slow your system down.
in order to clear that update code you must disconnect every memory unite you currently have, get a USB drive and got to xbox.com/support and download the latest update files. Insert your USB and your system should accept the update.
Thanks
www.1RepairStop.com
Sep 15, 2011 | Video Game Consoles & Games
Slow
since you have not explained exactly what the problem slow is
a slow computer
try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to recover bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive will speed up your computer
hope this helps
Jan 01, 2011 | Computers & Internet
Very slow computer start up, slow start up on msm or aol
try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/f which will automatically fix any corrupt files on your hard drive then defragment your hard drive
good luck with this
Sep 17, 2010 | Maxtor 40GB INTERNAL 3.5- IN ATA133 HDD...
The laptop boots very very slow
Some of the things that could affect your laptop from booting up are the start up programs e.g. skype, limewire, windows live messenger etc. I recommend checking there first to ensure you don't have programs that automatically start up as they slow up the process. Your antivirus (if you have one) sometimes slows up the process as well as it does a pre-scan before and while you are booting up Windows.
There is a program you can download for a free trial. (Click on start download). It will help you get rid of some of your start up problems and also clean your registry and fix other common errors you may have with your laptop.
Please try it and see if it works for you. Thanks for using FixYa.com and if you were pleased with the results, don't forget to vote!!
Apr 21, 2010 | Compaq Presario CQ60-220US PC Laptop
My dell 610 laptop has started running slow
if you are experiencing these and unsure on what to do, better take your laptop a laptop tech, if you feel that you needed a hard drive change, then take it to a tech, have them replace your old hard drive
Nov 26, 2009 | Dell Latitude D600 Notebook
Hard disk is very much SLOW
Click on your Windows start menu. Select Control Panel>Performance and maintenance. Run the Disk cleanup utility. Run the Disk Defragmenter. When all these steps are complete reboot. Your hdd should run faster. Hope this helps & please take a moment to rate this solution. Thanks.
Mar 19, 2009 | Hitachi Deskstar® 7K250 Hard Drive
Slow start-up
check if you have a CD left in the cdrom drive.
Lots of things can cause the start-up delay too:
- virus and spywares. Clean.
- bad sectors on hard disk (backup and plan for replacement)
- low physical memory. check in the Performace tab of the Taskbar (window$$$ only) PF should not be more than that of physical
Sep 24, 2008 | Dell Inspiron 6000 Notebook
A hard start
not sure of language description ,hard too start or a slow turn over of engine if its slow cranking then drop test battery and a load test on starter motor
Aug 25, 2008 | 2007 Chevrolet Tahoe
Computers & Internet Logo
David Payne
David Payne
