Motherboard DFI CA64-SC windows XP compatible? Just reformatted and delted all partitions and did fresh win98se install. Last time though I thought I did this and winxp seemed to install but then came up blue screen. Is this motherboard supposed to be compatible, googling hasn't answered. Thanks - BEN
  • 724 Answers
You need to establish how much memory is required, more the better.
The minimum hardware requirements for Windows XP Home Edition are:
  • Pentium 233-megahertz (MHz) processor or faster (300 MHz is recommended)
  • At least 64 megabytes (MB) of RAM (128 MB is recommended)
  • At least 1.5 gigabytes (GB) of available space on the hard disk
  • CD-ROM or DVD-ROM drive
  • Keyboard and a Microsoft Mouse or some other compatible pointing device
  • Video adapter and monitor with Super VGA (800 x 600)or higher resolution
  • Sound card
  • Speakers or headphones
http://support.microsoft.com/kb/314865
Posted on Aug 26, 2010
I reinstalled Windows XP SP2 on celeron PC but unable boot up after copying all installation files getting stuck on the main screen showing XP screen with the scrolling status bar and just froze
Hello, Kindly reformat again your pc. this time delete the partition after that create partition then reformat. this is the best solution. if is not work try other Operating system. thanks
Apr 30, 2011 | Matsonic MS7308E (MBMS7308E) Motherboard
Hi, I have a Pentium II computer with an award 6BC motherboard. I'm trying to make a dual boot hard drive with win98se and winxp os. Have successfully installed win98se on first partition but cannot...
I assume that when XP gives lot a choice of where you want to install it that you are selecting unpartitioned space ( which should be listed after your primary 98 partition) and that there is enough room on that partition for XP.
If that space is already partitioned, try delecting the partition and then tell XP to install in the newly created unpartitioned space. XP should then prompt to format that space after which the install should continue. If it does not, you must be getting some error message indicating what/where the problem is. If you let me know what the error messages are I may be able to provide further help.
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please rate my solution using FixYa's "Solution Helpful" rating scale.
Best regards,
Yavacotech
Mar 30, 2011 | Acer AOpen AX 6BC Pro (91.87810.A03)...
DFI CA64-TC motherboard maxed out at 1 GB memory.
If you've maxed out memory you've outgrown the board. It would be my suggestion to purchase a newer board that can hold more memory. Most boards today can handle from 4 -8 gb of ram.
Good Luck
Mark
Feb 05, 2010 | VIA DFI CA64-TC 694T/686B Mainboard...
Sound card driver
You should be able to find the driver for your audio here:
http://www.dfi.com/portal/CM/cmproduct/XX_cmproddetail/XX_WbProdsWindow?action=e&downloadType=driverTab&windowstate=normal&mode=view&downloadFlag=true&itemId=370
Jan 31, 2009 | DFI CA64-TC Via 694T/686B Mainboard...
I HAVE MY PROBLEM REGARDING MY MOTHERBOARD, AMD ATHLON EP-8KTA3L
Specification DFI AK74-SC Model DFI AK74-SC Socket Socket A Motherboard CPU AMD Athlon /Duron processor 600MHz-1.2GHz and faster Chipset VIA KT133/686A Memory 3 DIMM sockets
max. 1.5GB (unbuffered or registered)
Supports PC 133/ VCM SDRAM BIOS Award / 2Mbit Power Management ACPI and OS direct power management
Wake-on event: RTC/Modem/LAN Hardware Monitor System and processor temperature Expansion Slots 1 AGP slot (Supports 4x/2x AGP)
4 PCI slots
1 AMR slot
1 ISA/PCI slot Audio AC`97 Audio codec with Yamaha AP Super I/O 2 x NS16C550A compatible UARTs
1 x SPP/ECP/EPP parallel port IDE Dual PIO mode 3/4 EIDE channels up to 4 IDE devices
Ultra DMA/66 transfer rate up to 66MB/sec Rear Panel I/O Ports 2 x USB, 2 x DB-9, 1x DB-25, 1x PS/2 Mouse,
1 x PS/2 Keyboard, 1 x game/MIDI, 3 audio jacks I/O Connectors 1 x IrDA, 2 x external USB, 2 x IDE, 1x Floppy,
1 x ATX power, 3 x fan, 1 x WOR, 1 x WOL, 3 x internal audio Form Factor 4 layers ATX Motherboard Form Factor
30.5 cm x 22 cm 12.0 inch. x 8.66 inch. Warranty DFI AK74-SC Motherboard Pro DOA Warranty ONLY
DOA DFI Warranty
DFI Warranty
motherboard
If you want more Information then go to this link :-
http://www.motherboardpro.com/Motherboard-With-ISA-Slot-DFI-AK74-SC-1-ISA-4-PCI-AGP-Socket-A-ATX-Used-Motherboard-p-39.html
Dec 03, 2008 | DFI AK74-SC Motherboard
PM800-M2 Restarting
reformat means that you have to install an fresh copy of your operating system to the hard drive. if you do have a cd of your windows installer like windows xp, just put it in your cd drive and restart your computer and boot from that cd. be sure to erase the partition that has your corrupt operating system installed ok to replace it with the new xp that your going to install...
that wasn't to hard was it?
Apr 30, 2008 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
DFI AK74-EC motherboard CD drivers
hey,
Here are the drivers:
VIA Service Pack 4.24
http://www.dfi.com/download/MOTHERBOARD_DRIVER/MB055VSP.ZIP
VIA Audio Drivers
http://www.dfi.com/download/MOTHERBOARD_DRIVER/MB055VAD.ZIP
VIA Hardware Monitor
http://www.dfi.com/download/MOTHERBOARD_DRIVER/MB055HWM.ZIP
If these don't work please contact me for more assistance we will find the correct drivers in no time :-)
Feb 11, 2008 | DFI AK74-SC Motherboard
Installing new hard drive.
From what it sounds like it is not your motherboard or harddrive. it is the formating of the hard drive. What is the format you are using for your harddrive ? FAT32 or NTFS ? are you Partitioning your drive ? Are you familure with dos commands ?
Sep 22, 2007 | DFI /LAN PARTY NFORCE4 ULTRA-D/...
Continuous restarting with winxp
On computers that contain Windows 98 and Windows XP: ? Windows 98 must be installed on a basic disk on a partition formatted with FAT or FAT32. If Windows 98 or Windows Me is not installed on the system partition, which is almost always the first partition on the disk, the system partition must also be formatted with FAT or FAT32. ? Compressed DriveSpace or DoubleSpace volumes won't be available while you are running Windows XP. It is not necessary to uncompress DriveSpace or DoubleSpace volumes that you will access only with Windows 98. ? Windows XP must be installed last. Otherwise important files needed for starting Windows XP could be overwritten
Jan 28, 2006 | Intel D850MV Motherboard
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
