Question about Syntax Olevia LT32HV 32 in. HD-Ready LCD Television
I have lost the screws that mount my Olevia 332b11 television to its base. Can you tell me where I can get them?
Olevia 532 base stand screw
hi, did you find your answer? I have the same problem. eointosullivan@gamil.com
Jun 27, 2012 | Syntax Olevia 532H 32 in. LCD HDTV
We are mounting the Television and would like to remove the base. How do is come apart
if you look at the rear of the set you will notice 8 screws, they should have arrows on the housing pointing at them. Have 2 people hold the display while you remove the screws. have them continue to hold it while you put the mounting plate on the rear of the TV. Below you will find links to the Mfrs.
http://www.hdtvreview.com/Syntax-Olevia-237T-hdtv.html
Good Luck!
Sep 02, 2011 | Olevia 237T 37 in. LCD TV
We lost the screw to mount the olevia 227-s11 65in.lcd tv on the wall and none of the screws would match that of the mounting bracket.where can we get the screws ?
you can get the screws in any hardware shop. just measure the dimension of the screw and mention it to the hardwareshop assistant.
Jul 01, 2011 | Olevia 227-S11 27 in. LCD TV
I have a 37 inch olevia hd tv..It was mounted on the wall but now we want to put it back on the base and cannot find the screws to reattach the base to the tv. Can you tell me the size of the screws?
This is a difficult one as you have about 50sizes possible for this one. Try calling olevia and giving them the model # they might have that info but its pretty technical and more then likely you'll need to go to a Home depot and just pick up several fine threaded screws (about $.05-$.10each) and try em all to see which one fits. Its a pain but may be the only way. Make sure you don't get them too long as this will damage the threads or not tighten the mount. Try about 1" to 1-1/2" screws. depending on how thick the base plate is. you want about 3/4" of the screw inside the tv depending on how deep the threads (can stick a toothpick inside it to gauge how deep) so ad 3/4" to the thickness of the base plate.
Sep 12, 2009 | Televison & Video
Remove base from tv?
How many screws did you remove? You should have eight, there are 2 screws along the bottom that are easy to miss. Make sure you check each hole with a flashlight just to make sure you got them all.
Jan 03, 2009 | Olevia LT42HVi 42 in. LCD Television
Olevia 232-s13 32"
Just talked to Cust Supp, on the back you will see 6 round holes around the label. The screws needed will be 6mmx12mm. I have to do the same tonight. good luck
May 15, 2008 | Olevia LT32HVE 32 in. LCD Television
Olevia 227V LCD
I just repaired a 26" in which the stand came off after I took the primary panel off in the middle of the back then the screws were visible that Olevia is talking about. You might have a different style but it does come off.
Feb 12, 2008 | Digital Lifestyle FA1B32Z 32 in. LCD...
Olevia 227V lcd
All you need to do is remove the two long screws on the back of the tv panel just above the stand, then the two short back panel screws AND the three short screws just above the two panel screws and the stand will come right off. DO NOT remove any of the other screws in the perimeter of the back panel. There is no need.
After much trial and error this is the correct and EASY procedure for this apparently troublesome task. Good Luck !!
Feb 12, 2008 | Olevia LT27HVX 27 in. LCD Television
How to Remove the Base
I have an Olevia 42" TV. I was able to remove the base by removing 16 screws on the back side. They were arranged vertically in 4 sets of 4. The screws go through the back panel, through the base and attach (without nuts) directly into the inside of the TV. After removing the 16 screws the stand simply slides out.
I tried removing two screws underneath the base area. They were small screws and were a pain to remove. I thought I would try that first instead of removing 16 screws but that did nothing.
Dec 10, 2007 | Olevia LT42HVi 42 in. LCD Television
Open Questions:
Syntax Olevia LT32HV 32 in. HD-Ready LCD Television Logo
111 people viewed this question
Top Syntax Televison & Video Experts
Computer Repairing
Computer Repairing
Kolbrun...
Are you a Syntax Televison and Video Expert? Answer questions, earn points and help others
