Question about Dell 926 All-In-One InkJet Printer
My printer will not print anything new because there is a document pending to print, but it will not let me delete the pending documant
  • 62 Answers
Please try below steps.
1. Restart the printer.
2. Press the cancel job button on the printer.
3. Delete the printer device from control panel and add the printer again.
Posted on Aug 26, 2010
  • 724 Answers
Disconnect the data line print cable. Shut down and unplug the printer. Go in the related print Que on the computer and delete all peint jobs.
Reconnect the power and data lines to the printer.
The print jobs should all be gone now do a print test from the Que. Make sure of default printer and online status
    New Friend:
  • 76 Answers
Need to clear the printing query
How do i get my printer from offline mode back to online mode
  • Make sure that the printer is powered on.
  • Pull up 'My Computer' then click on 'Control Panel'. From the Control Panel, click on 'Printers and Faxes'. You will then see a list of Printers connected to the PC.
  • Delete pending print jobs to make sure that the correct document will be printed later and for you not to waste paper. Double click on the printer that you want to use, and a window will appear showing you a list of pending print jobs. Simply click on 'Cancel All Documents' from the 'Printer Menu'.
  • After you have deleted all pending print jobs, right click again on the printer icon and choose 'Use Printer Online'.
  • Try printing a test file, if it doesn't work the first time, reboot the PC.
***If you need any technical help on printer then you can reach at here
Jan 02, 2013 | Office Equipment & Supplies
My HP laser jet M1120 MFP is repors error message when printing
Re install the tonner and then go to Printer & Faxes settings and delete the all kinds of pending documents and the go to print a new document and after taht send me the result...........what is happening.
Oct 01, 2012 | HP LaserJet M1120 MFP All-In-One Printer
There has been a pending document in the que. I tried to delete the document but now it states deleting next to the document in the que. Can not print anything.
Open the Print Que and see if it will let you pause the print job. Then close the que and turn the printer off. Open the print que again and see if it will let you delete it. For some reason every now and again a que will hang. This process should reset the que. It will dump everything in printer memory and should release the document to delete the job. In any event pausing the job should release the printer to print other jobs.
Sep 05, 2010 | Office Equipment & Supplies
Pending documents wont print
Your buffer is overwritten. You need to right click on the pending document and select delete it would be easy to delete those processes which are not bufferrred but to delete top document you will have to switch on and off your printer. wait for a minute and restart your computer. You can start printing again.
Mar 18, 2010 | Office Equipment & Supplies
Ok I posted for the wrong type of printer. I have an HP 1600 Deskjet printer. It has worked fine until I went to print out my insurance ID cards. The printer icon showed up and says 1 docment pending. So I...
itz problem/error of print pooler..
often happens due to overload/document mismatch/page error and so on..
itz very common..don't panic..!!..
set all the document in pool to delete..just turn off the printer..restart the system..
hope it'll b fine..
best to seek guidance of ur system admin/vendor....
Nov 11, 2009 | HP DeskJet 1600C InkJet Printer
Everytime I try to cancel the pending document it doesn't do anything just stays the same, so that does not allow me to print anything else because for some reason that pending doc. won't erase... please...
first do a right clickon the printer icon
select run as administrator if there or else try cancelling the document
if still does not work
go to run and type "services.msc" and it will take you to the services page
in the services page look for a service "print spooler "
restart the print spooler
and then try deleting the documents .......................... hope this should work for you let us know wat happens and we will help you accordingly ......take care ............god bless you ...........thank you (HAMID)
Oct 29, 2009 | HP Officejet 5610 All-In-One InkJet...
My printer is not printing any document and when i check whats printing it says its deleting another document
click on start
goto control panel
select printer and faxes
double click on printer icon
and delete all the que printing jobs
Jun 18, 2009 | Dell 926 All-In-One InkJet Printer
Document pending will not print
Well this could be a number of issues. First of all try to make sure the printer is on, (yes I know very stupid request but I've seen it happen thousands of times). Then make sure the printer is connected to the PC, either via USB or LPT port or whatever the case maybe. Thirdly, you want to make sure that the printer is installed on the PC. If you goto START/PRINTERS & FAXES, and see if there are any other documents that are stuck or pending, try to delete them out or delete the printer and reinstall it. Then try to print again.
Mar 22, 2009 | Office Equipment & Supplies
Printing old copied images not saved
go to the printers & faxes documents & look for your printer model, now see if there is any pending documents there & delete it.
Feb 03, 2009 | Lexmark X2500 All-In-One Printer
Printer not printing model z2300 on light is flashing
replace the cartridges if the lights are continuisouly flashing. or if there is a pending document in the print que it will flash the lights.delete that pending documents.
Oct 23, 2008 | Lexmark Color JetPrinter Z23 InkJet
Dell 926 All-In-One InkJet Printer Logo
191 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
