Question about KitchenAid 30 in. Architect II Series 4.3 cu. ft. Single Convection Steam Oven - KEBU107SSS Dual
I have a 6KAO 200 Kitchenaid electric oven but is dead even though the oven power switch is on
2 Suggested Answers
diodeic
  • 1622 Answers
SOURCE: Problem with the KitchenAid KEMC378
There may be fuse. Some are located where the power cord enters, sometimes under range top back in a corner. Does this have a selector knob for broil/oven? If yes, I have seen times where the thermostat knob and the selector knob have been reversed. Someone takes knobs off to clean and, oops, wrong spot. Maybe both igniters are bad.
Hope this helpout in solving the electric double oven. Take care
Posted on Sep 12, 2010
I have a Garland Mater 200 electric oven and the fan continues to run even with the door open. Is there a switch / sensor that controls that?
https://www.manualslib.com/manual/55869/Garland-200.html?page=103#manual
This web site had a manual that may answer you question. It seems that here is a heat/cool switch. The cool switch is designed to function to cool the oven down by running the fan with the door open. If you close the door, it will heat so the door has to stay open.
Aug 20, 2017 | Garland Ovens
Bottom oven is not working even though the top one is 720EF model
When you turn the bottom oven on, does the fan start to run in the oven? Do the oven lights come on? Does the main cooling fan switch on? Does the oven control knob illuminate? Does the thermostat neon illuminate?
As a guide, the power/control for the bottom oven is via the main switch on the front panel. Power then goes from the switch through the thermostat to the the oven/element/fan. The lights go direct from the switch.
I hope this helps.
Sep 17, 2010 | Stoves 720EF Electric Double Oven
De Dietrich electric oven has power but no heat
hi it is probably the timer not making the switch properly even though it looks like its on stopping power going to the thermostat
Dec 11, 2009 | Ovens
Ovens won't heat up beyond 250 degrees.
if you cant program it for more than the 270 you may have changed it from farienhiet ( bad spelling) to celcius. pushing and holding broil may switch it back.
May 02, 2009 | KitchenAid Architect ® II KEBS208S...
Wall oven controls do not light-up or function.
i cant call you but iv seen this a few times the display part of the board went out (you can still probably get it to cook but cant see the temperature) you are gonna have to replace the board.
Dec 12, 2008 | KitchenAid Architect Series KEBC107KSS...
Oven unit not heating up - Kitchenaid KEMX377GWHO
This sounds like a blown thermal fuse, a common problem. What model oven was this?
Dec 02, 2008 | KitchenAid Architect® KEMS378S Electric...
Oven keeps tripping when switched on
The reason why you oven is tripping is because the oven element is most likely burnt out...
The electricity supply going out should not have affected this... it is easily replaced and is not to costly..
Jan 30, 2008 | Ovens
Kitchenaid superba
switch off electricity to oven, then switch it back on - that reboots the computer that controls the oven.
Dec 21, 2007 | KitchenAid KEMC378 Electric Double Oven
KitchenAid 30 in. Architect II Series 4.3 cu. ft. Single Convection Steam Oven - KEBU107SSS Dual Logo
50 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
