Question about Intermatic Inc. ST01C Digital In-Wall Timer
Once in wall and operating lights blink and there is clicking noise at the switch
You have timer wired wrong.
If you have ST01C timer, then red wire is connected where blue wire should be.
http://waterheatertimer.org/ST01C-program.html
If you have another brand of timer, then white wire is connected to red wire.
White wire must be connected to Neutral or to bare ground.
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
If you have different timer, add a comment with in-focus photo of your timer for correct identification and possible assistance.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
Add a comment for more free help
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Apr 22, 2011
TV CUT OFF,CLICKING NOISE NOW & STANDBY BUTTON FLASHING
"Short circuit" protection section circuit detects a short circuit; most often with its main board; and shuts down the set immediately after switch ON; to prevent further damage to components. This is what happening with your TV. Contact any service technician.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Type in the brand name of your TV, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 16, 2015 | Televison & Video
Mitsubishi TV How do I fix green blinhing light in mitsubishi DLP TV 52825
most likely its a bad power supply. the wd52825 is known for that issue. check youtube for repair videos.
Jan 28, 2015 | Mitsubishi Televison & Video
Blinking interior lights and clicking noise behind dash
Could be two problems,bad switch driver door[blinking],could be four way switch[clicking].
Sep 24, 2013 | 1997 GMC Safari
Lg ru48sz40 rear projector
I think this is a hardware failure and only professional technician can help you. Even then, try to master reset once and then check it.
Car Reviews
Aug 27, 2012 | Cell Phones
Phillips Plasma - Model #42PF7320A/37 - 3 flashing red lights
it sounds like you could have a signal board problem they are pretty expensive but there is a web site that sells refurbed parts
Nov 17, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Sony kv-32LS35U
Sounds like a power supply problem. How many times does the light blink? The times that the light blinks could possibly tell you around what circuit is having a problem.
Feb 03, 2008 | Televison & Video
Remote control ceiling fan
Possibly a bad circuit board in the ceiling fans remote function. I would suspect that the circuit board has a thermal issue where once warm it works fine. The most common fault that I have seen is a bad solder connection on the board. Pull the board from the fan and check all solder connections for cracks or dull solder. If you see any of these then reflow the solder connections. If this does not work you probably will need to order a new board from the manu.
Jan 26, 2008 | Dryers
Power supply light has blinking green light
If the power box is bad, The computer will not come on. if you only get a green light, you would need to start with replaceing the power box, if you get a new one and the same thing happens, then the mother board is bad too.
Nov 26, 2007 | HP ATX-300-12Z (ATX30012ZBD) 300-Watt...
Intermatic Inc. ST01C Digital In-Wall Timer Logo
169 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Steve
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
