Question about Price Pfister 18 Series Polished Chrome Waste Overflow Drain with Brass Tur
I have a PRICE Pfister bath clean out (drain) assy. with a 2-screw faceplate. I removed the face plate AND PULLED OUT THE long plastic link rod that has a 'PISTON' on the end with o-rings. Now I can't get it (piston) to go all the way back in. Seems like the piston is not wanting to seat itself into the drain pipe down below. Is there some trick to getting this back together??
  • 43,501 Answers
As you have found out pulling it out is way easier then putting it back in...
To get it back in persistance is the key...also making sure that you get that linkage pushed back in so that the piston not only gets centered but upright, so that it can be pushed back down the hole...this is tricky and takes some learning...the only way to learn is to keep trying and maybe walk away a few times and cool down...frustration will not help....
Hey it can out so it will go back in... keep trying...
Heatman101
Posted on Aug 26, 2010
Replace tub faucet
pry plastic cap, under cap remove Phillips screw,pull handle and replace
Oct 16, 2013 | Price Pfister Single HDL Bath Faucet...
Price pfister chane
There should have been a new rubber seal with the purchased replacement. If not you need to contact the supplier and let them know it was not in your package.
Nov 25, 2012 | Price Pfister Plumbing
ReMove faceplate
Remove the Outer Case Panel on the side by removing the screws on the back that holds it. Now once one side of the case is removed, look down the front on the metal part of the case. You will probably see the plastic catches or hinges from the face plate, push them in to release them and you can remove the face plate.
Apr 11, 2012 | E-Machines D2046 PC Desktop
I have a Kohler Overflow tub with a faceplate covering the screws that would allow me to get to the trip lever...the lever must be stuck "down" because the tub won't drain. How do I take off...
Hey, I think I've got the solution for your situation.
First off, you want to get a caulk remover and apply that on all the caulking between the tub and the faceplate. Let this soak for 20 minutes. Then you will want to take a utility knife to score around the edges of the faceplate between the faceplate and the tub. Be careful not to scratch the tub! When the caulking has been completely cut through all the way around the face plate, take putty knife and pry the faceplate from the side of the tub. Check out the lever, or see if it is just gunk build up on the filter. Either way I hope this helps, and good luck!
May 19, 2011 | Kohler Archer Clearflo 1-1/2in Bath Drain...
I have a bath clean out that does not work properly. The brand looks like SP. When the lever is in the up position it holds water in the tub, but does not lock into place to allow the water too drain. ...
Replace it. Remove the two screws. With the lever in the up position, pull the assembly up and out. You may have to jiggle it to remove it. Remove the cotter pin to disengage the faceplate from the linkage. The faceplate is a standard part that can be gotten from any plbg supply or Home Depot. While you have the drain assy out, you may want to grease the plunger with silicone grease or faucet grease. This will make the drain easier to operate.
Jul 15, 2017 | Price Pfister 18 Series Polished Chrome...
We have the price pfister bath clean out drain assembly that is about 20 yrs old (the bucket part of the assembly is a spring like thing) we want to replace the the plate because the up and down lever...
you can remove the overflow plat,(check to see if you have 1 or 2 screws in the plate,the new one must match.The strainer piece in the bottom of the tub,is difficult to remove,but it can be done with a little effort and wd-40,the straineris a standard 1.5 inch npt (national pipe thread)
Apr 11, 2010 | Price Pfister 18 Series Polished Chrome...
New Price Pfister Ashfield Bath Faucet - Hot H20 pressure is weak
I had the same problem. I simply removed the small brass fitting that the water supply screws onto.i removed the screen that is inside the brass fitting. Now the pressure is fine.
Feb 15, 2010 | Price Pfister Pfister Ashfield Wide Satin...
Unable to remove faceplate or eject cd on kenwood
remove the to of the unit, then the two in the actual cd player, pull out cd player, there will be two more screws,these hold the faceplate assembly in place, remove them. This will allow you to pull a small plastic hook down to let the face plate slide out. then remove the face plate from it's holder, slide it out. Remove the four screws on the back of the faceplate inside the there is a very small piece of plastic that has a hole at one end and squared at the other. This is the problem causing piece. I suggest super gluing this piece where it attaches to the inside of the faceplate. This should fix the problem.
Jan 17, 2010 | Kenwood KDC-516S CD Player
Tighten the outside faceplate of a qwikset dead bolt.
The inside face plate snaps on. To remove it remove the T handle and use a small flat head screwdriver to genty pry it off. Behind the cover you will find 2 screws to remove the lock halves.
Don't forget to rate
Mar 12, 2009 | Kwikset Professional Door Lock...
Handle on faucet shuts off on its own
I had the same problem. The Price Pfister web site recommends removing the handle (unscrew the dome cap, then remove the phillips screw to get the handle off) then tightening the retaining ring (I used channel lock pliers on largest setting. It worked. However the retaining ring is plastic on some models, and they recommend replacing it with a brass one. I haven't taken that step yet, we'll see how it goes (mine is plastic).
Dec 01, 2008 | Price Pfister Marielle Kitchen Faucet with...
Price Pfister 18 Series Polished Chrome Waste Overflow Drain with Brass Tur Logo
540 people viewed this question
Top Price Pfister Plumbing Experts
bwbconstruct
Level 1 Expert
john h
TED
Level 1 Expert
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
