Question about Invicta Watches
Adjust bracelet on sea spider? - Invicta Watches
  • 831 Answers
Thank you for contacting FIxYa.<br /> I suggest you take your watch to a reputable local jeweler for sizing. Expect to pay a nominal fee (around $5) for this service. Do not attempt to size your own watch! You may damage or scratch the watch and bracelet. The liability is yours.<br /> If you still decide to do, follow instructions given here:<br /> <a rel='nofollow' href="http://www.webwatches.co.uk/how_to.htm" target="_blank">http://www.webwatches.co.uk/how_to.htm</a><br /> Best wishes. Jewel
Posted on Aug 26, 2010
Looking for band for invicta sea spider 1261..i want to replace it with a stainless steel band..
Sea Spider 1261 INVICTA Sea Spider Men 50mm Stainless Steel Gold Black dial 3600K Mechanical watch located attached link offers multiple compatible straps
Nov 11, 2017 | Invicta Watches
Adjust jubilee bracelet
You bend it , literally take hold of the inside arch and bend it with your hands in not out this shortens the , the length and helps it close .
Oct 02, 2014 | Rolex Lady Datejust 179173SRJ Watch for...
How to remove links from invicta sea spider polyurethane bracelet
You should use two extremely small flat head screw drivers to remove links on Invicta polyurethane watch bands. The smaller pens on the polyurethane watch bands have a notched cap (tiny screws) on each end .You must use one screw driver to hold the pen cap (screw) steady and the other screw driver to turn the cap (screw) counter clockwise. You only have to remove one notched cap (screw). These caps (screws) are very small and you should be careful not to lose them. Once you removed the cap (screws) you can use a small screw driver or paper clip to push the pens through the links. You should repeat this til you remove the desired links.
Nov 24, 2011 | Invicta Sea Spider Chronograph...
How do I remove pins to size an Invicta Sea Spider model #0140
mcdevito75 here, Aren"t the spring bars (pins) built into Invictas Strap?? Look on the back of the Strap real close to where ot attches to the watch, see a little tab you can move with your fimger, this tab should compress the spring bar (pin) and allow you to remove the strap.
Jul 03, 2010 | Invicta Sea Spider Chronograph...
Adjust the band
Click on my profile (escapement), then click on Tips and Tricks. There you will find tip how to add or remove watch bracelet links. Rate me, please
Mar 10, 2010 | Invicta Sea Spider Chronograph...
How do you adjust the band on a rolex watch
Unscrew bracelet screws from the side and take out/add link. Then screw bracelet screws back.
Jan 29, 2010 | Rolex Day-Date President 118239 Wristwatch
Self-adjustable bracelet watch
If you are ready to take that risk, here is how you can do that.
First- get watch on your wrist and by squeezing the bracelet count how many links you have to take out to make it tight enough (say 4 for example).
Check the sides of a bracelet. You will notice that the upper bands metal is flipped over the bracelets side. Take tweezers or small pliers and unbend one of these. Try to do as little damage as possible.
When it's done, you will see two metal staples inserted into the bracelet. You have to pull them out. While pulling out, remember how they where positioned, as you will need to drive them back in the same manner.
So, when the staples are out, do the same on the other side of bracelet. Now you have bracelet in two halves.
Count off 4 links and undo the staples in joint of 4th and 5th link in the same manner as previously.
When links are out, take the staples and drive them back into the bracelet koining two ends together. You have to do that exactly the same way and position as you took them out.
When all staples are in place, bend the metal back over to the bracelet sides.
BE WARNED: as you gonna do it first time, be ready that you can damage the bracelet or can not put it back together.
Good luck.
Rate me, please.
Mar 19, 2009 | Timex 2J611 Watch
I want to adjust the steel bracelet on my new GMT II
You can do it yourself but proper watchmakers screwdriver is needed.
Check the sides of your bracelet and you will see screw ends with grooves. Unscrew them and adjust your bracelet (take the links out). Then screw them back in.
Regards
Arthur
Dec 13, 2008 | Rolex Watches
Fossil watch me1001 bracelet adjustment
I took mine to a watch store, and had them remove a link.
Dec 08, 2007 | Watches
Watches Logo
234 people viewed this question
Top Invicta Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you an Invicta Watch Expert? Answer questions, earn points and help others
