Question about HP Compaq nc6230 Notebook
How t connect a to the s-video output - HP Compaq nc6230 Notebook
  • danaraco Aug 27, 2010
    yes this works but the image is just showing in black and white, no color.
    New Friend:
  • 76 Answers
Connect the cables to the laptop and tv and then on the laptop press the Fn key plus the key that has a image like a monitor on it then check tv to see if it went through
Posted on Aug 26, 2010
Is there a docking device for connecting iphone with panasonic receiver
There are lots of docks, but they all connect via USB
https://www.google.ca/search?q=iphone+6+plus+dock+connector&rls=com.microsoft:en-CA:IE-ContextMenu&biw=1366&bih=643&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjMh9Hpg97QAhVPVWMKHVosD3kQ_AUIBigB#tbm=isch&q=iphone+6+plus+dock
Your receiver only has s-video.
Total Harmonic Distortion 0.7% (6ohms) (at 20Hz-20kHz)
  • S-Video Inputs/Outputs 5 inputs, 1 output
  • Video Inputs/Outputs 5 inputs, 1 output
  • Video Rec Outputs 1 output (with S-Video)
  • Front Audio Inputs 1 input (S-Video)
  • Digital Inputs/Outputs 4 in (3 optical, 1 coaxial)
  • Audio Inputs/Outputs 6 in, 1 out
  • VIERA Link™ HDAVI Control 3
  • HDMI Input/Output 3 in, 1 out
  • Dimensions (H x W x D) 6 1/4'' x 16 15/16'' x 13 11/32''
  • Weight 11 lbs
    Panasonic SA BX500 AV Control Receiver with High Quality Amplifier Decoder...
  • Dec 05, 2016 | Panasonic Audio Players & Recorders
    How to connect samsung dvd to samsung tv
    Follow these steps: Component Video Connection 1. Get a component video cable. This cable has 3 sets of connectors, one each for the red, blue and green color signals.
    2 Match the connectors to the appropriate video output jacks on the DVD player. Component video outputs will normally be labeled Cr/Cb/Cy. The Cy output jack is matched to green, Cr to red and Cb to blue.
    3 Run the cable from DVD player to the TV. Most TV connections are made from the back panel, but this may vary.
    4 Match the connectors to the appropriate video input jacks on the TV.
    If using S-Video Connection
    1 Get an S-video cable. This cable has a single round connector with 4 pins.
    2 Attach one end of the S-video cable to the S-video output jack on the DVD player.
    3 Attach the other end to the S-video input jack on the TV.
    Composite Video Connection 1 Get a composite video cable. These types of cables are frequently bundled with two-channel audio cables. Composite video cables are tipped with yellow plugs.
    2 Plug one end of the composite video cable into the composite video output jack on your DVD player.
    3 Plug the other end into the composite video input jack on your TV.
    May 14, 2011 | Samsung Televison & Video
    Give me properly installation of stand alone dvr with computer all window how sport the dvr send me properly anstallation of standalone dvr
    Take one co-axial cable, and connect the "input" port to your cable-company's wall-port.
    Look at the connectors on the back of your TV. You could have:
    * coaxial input (lowest video-quality)
    * S-Video input (better video-quality)
    * component input - three cables for video, two cables for audio (better video-quality)
    * HDMI input (highest video-quality)
    Look at the connectors on the "output" side of the PVR. You could have:
    * coaxial output (lowest video-quality)
    * S-Video output (better video-quality)
    * component output - three cables for video, two cables for audio (better video-quality)
    * HDMI output (highest video-quality)
    Connect the "outputs" to the "inputs", using appropriate cables.
    Turn the PVR on. Turn the TV on.
    Use the "source" button on the TV's remote-control to select from the various inputs
    (Coax, S-Video, Component, HDMI1, HDMI2).
    If your TV has 'PIP' ("Picture-In-Picture") capability, connect more than one output to a second input, so that both tuners inside your TV will receive a signal.
    Feb 03, 2011 | Computers & Internet
    How i can connect the tv as my computer moniter
    Does your TV have a "VGA" input? If so, then connect the VGA-output from your computer's video-card to that VGA-input.
    Does your TV have a "DVI" input? If so, then connect the DVI-output from your computer's video-card to that DVI-input.
    Does your TV have a "S-Video" input? If so, then connect the S-VIdeo-output from your computer's video-card to that S-Video-input.
    Note that only _SOME_ video-cards have DVI output or S-Video output. Check your video-card.
    Dec 01, 2010 | Computers & Internet
    Does this system have a optical input
    Here are the list of connections on this system
    • Audio inputs/outputs 2 analogue input sources,
    1 analogue output connection
    - TV : in
    - VCR : in
    - CDR : out
    - Headphone : 3.5 mm
    • Digital audio in/output : 2 digital output connection
    (coax, optical)
    • Video outputs : 3 output connections (1 S-Video)
    - TV : out
    - VCR : out
    - Monitor : out
    • Speaker Connections suitable for speakers ≥ 6 Ohm
    - left, right, center : click-fit connection
    - rear left, right : click-fit connection
    • Miscellaneous connections
    - TV center speakers pre-out : 1
    - Subwoofer pre-out : 1
    - AM antenna : loop type
    - FM antenna : coax
    please mark this fixya if it has answered your question.
    Dec 14, 2009 | Philips LX3000D System
    Cant hook dvd/vcr to my cable box the manual says I need a extern
    The cable box IS an external tuner.  You should connect the video output (either S video, HDMI, or component video) of the cable box to the video input of the DVD.  Then connect the audio output of the cable box to the audio input of the DVD via stereo RCA cables.  If your tv monitor has multiple inputs (ie: video 1, 2, and 3...) connect the video and audio output of the DVD to your tv monitor using an alternate video input (if cable box goes into your tv thru video 1, connect the DVD to video 2).  If your cable box only has one output, or your tv has only one input, then just connect your cable box to the DVD as above, and connect the DVD to your tv.
    Jun 21, 2009 | Philips Magnavox DVD/VCR Dual Player
    The HDMI "input" ports damage output ports of connecting devices
    i know this sounds stupid, but have you "toggled" or "played" with the HDMI cables? are they the same manufacturer? HDMI channel connections are very fickle. If just one connection is not exactly correct, they go to a limp, no go status. Since they run at such a minimal voltage, i can't see them "blowing" the outputs on the devices.however....if your cable has a serial type output for video only, I would connect the hdmi convertor to it and see if it works.
    Jan 10, 2009 | Yamaha HTR-6140 Receiver
    I'd like to connect my HP laptop to Yamaha 663 receiver
    Connect your S-video output from the computer to an empty S-video input on the receiver. Connect your speaker output from computer to analog audio input on the receiver using a 1/8" stereo connector to RCA patch cable. You may have to set your computer to output video to the S-video jack, consult your HP documentation for instructions.
    Dec 28, 2008 | Yamaha RX-V663 Receiver
    Video Connections
    These are all the connectors on the back. The "1 x component video output" indicates that you can use the "3 color video cord" you have, better known as Component Video Cable.
    Connector Type: 1 x HDMI ( 19 pin HDMI Type A ) - rear ¦ 1 x component video output ( RCA phono x 3 ) - rear ¦ 1 x S-Video output ( 4 pin mini-DIN ) - rear ¦ 1 x composite video output ( RCA phono ) - rear ¦ 1 x audio line-out ( RCA phono x 2 ) - rear ¦ 1 x 5.1 channel audio line-out ( RCA phono x 6 ) - rear ¦ 1 x digital audio output (coaxial) ( RCA phono ) - rear ¦ 1 x digital audio output (optical) ( TOSLINK ) - rear ¦ 1 x network ( RJ-45 ) - rear ¦ 2 x USB - front
    May 16, 2008 | Toshiba HD-D1 DVD Player
    HP Compaq nc6230 Notebook Logo
    26 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
