Question about Panasonic KX-P2130 Matrix Printer
When I switch the printer on it jambs.
Thes printers are great, many years of use. I moved one and now the print head move completley from left to right and slams into the stop on the right side. It growls like the belt is slipping for maybe 4 seconds and then shuts down with the lights flashing. Can anyone help?
-Richard
    Problem Solver:
  • 7 Answers
There is a small limit switch inside on the left side that can get bent and causes this. It needs to be in the OPEN position when the printhead is to the right side and it closes when the head slides over it. Look for it, it is obvious. Now, bending it back is not a slam dunk but maybe yours is an easy bend back in place. Mine is taking more effort. I have removed the top to work better with it and removed the screw holding it down. I might have to un-solder the two wires to pull it out and put it on my workbench under strong magnification. Good luck.
Posted on Sep 04, 2009
The print head does not moves to the replacement position.
The switch or sensor cover do not work when you open the cover to change your toner tha's the problem why printer do not move the heads.
Mar 03, 2016 | Epson Stylus NX330 USB/Wireless-N...
How to install a hp officejet wireless printhead
You can solve this problem yourself by just following the below steps
1.Turn on the HP printer and flip open the top cover.
2.Hold the "Resume" button until the carriage assembly moves to the left side of the printer.
3.Flip up the print head latch on the carriage.
4.Use the handle to pull the print head up and out of its cavity.
5.Shake the new print head five or six times before removing its packaging.
6.Take the protective caps off the new print head. Do not shake the print head after removing the caps.
7.Press the print head firmly into the printer using the color-coded slots as a guide.
8.Close the print head latch and press down firmly.
9.Close the printer's top cover. The printer will automatically align the new print head and print an alignment page.
Thanks.
Have a great day.
Sep 17, 2010 | Computers & Internet
Canon Pixma MP500
Hello my friend, check if print head carriage has stuck and move the carriage a few times. You can also blew some compressed air around to clear any foreign objects.Also you can try moving the cartridge back and forth a few times and when you do that restart your printer .If still doesn't work you should take it to a repair shop.Good luck:)
Feb 04, 2010 | Canon Pixma MP500 All-In-One InkJet...
How to change cartridges epson stylus sx 400
From older Epsons: If the ink cartridges are empty (red light on), hold the ink switch 3 seconds to move the print head to the left. If they are not empty, hold paper switch until print head moves left. Once you remove a cartridge you can't reuse it, even if there's ink in it according to Epson.
Nov 16, 2009 | Epson Stylus C86 InkJet Printer
Head won't move far enough to the left to get cartridges out
seems a case of carriage jam n needs servicing..
howevr, do it if ur printer is out of warranty and u r a professional..
check for loose/faulty carriage-belt and the drive-assembly..jammed/sticky cleanser-unit (esp the rubber, gears n base)..
also chance of defective/faulty photo/opto-coupler 'sensor(s)'..the diodes and resistors in dis section..
always better to hv professional supervision, contact ur system admin/vendor....
Oct 31, 2009 | Epson Stylus C44UX InkJet Printer
Printing lines not straight and letters shadowed. Help!
Open the cover over the print head and *carefully* inspect the clear thin plastic strip that runs from left to right near the print head. If you see any lubricant (white grease) on this encoder strip, it needs to be cleaned off.
1. With the cover open and the print head in the center, unplug the power cord. This will allow you to gently move the print head left or right.
2. With a cotton swab wetted with rubbing alcohol, *gently* wipe the grease spots from the encoder strip. (Be VERY CAREFUL you don't dislodge the strip.) You may need to move the print head to the left or right to get all areas cleaned.
3. Let the alcohol dry off completely. With the area clear of cleaning tools, debris, and fingers, plug the power back in.
4. Try a test print.
Jun 17, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Wont print
I had this problem recently with my IP90. Both the black and color heads were clogged. After running the "canned" routines several times to clean the heads and deep clean the heads...still didn't help...here's what I did:
1. open the top lid to have the cartridges that are inserted in the print head move to the middle of the printer.
2. remove both cartridges
3. What is left there is the print head holder. Slightly move it to the right and gently lift the print head lock.
4. Grasp the print head and lift it out of the tank.
5. Have several paper towels hand and know that you will have color and bw ink on your fingers
6. Put the print head on the paper towel
7. Pour rubbing alcohol on the blk and color heads and let them sit of about 10-15 minutes.
8. after that dry the heads and re-insert them in the printer
9. I put new cartridges in the printer and ran clean and deep clean a few times.
10. My color and black and white print came right back!
Hope this helps.
Mar 17, 2009 | Canon PIXMA iP90 Mobile Printer
Head carriage stays left and grinds
Did you check to see if the ink was low in the printer? Epson wont let you print if the ink is low, happened to me before!
Oct 22, 2008 | Epson Stylus Photo R1800 InkJet Printer
INK CATRIDGE CARRIER
Turn the printer on and as soon as the print head moves, pull out the power cord, or switch the printer off at the mains. You should now be able to move the print head (gently) by hand over to the left side.
Sep 28, 2008 | Epson Stylus Photo R390 InkJet Printer
Epson c43sx does not print
change the cartridge thats simple red light indicating you must change your catridge
Apr 02, 2008 | Epson Stylus C43SX InkJet Printer
Panasonic KX-P2130 Matrix Printer Logo
119 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
