One of my motherboard ic's is burned .. and i need to know what is the basic role of this ic
    New Friend:
  • 76 Answers
Your best solution is to buy a new motherboard or send it to a laptop repair specialist who have proper tools for switching ic's
Posted on Aug 26, 2010
I have an hp g4, my ic is burned out is there any replacement?
What you need to ask yourself is Why did the IC burn out. You may risk replacing the ic and some other fault with the motherboard burns out the new IC.
Jan 26, 2014 | HP Computers & Internet
Asus motherboard chip level circuit diagram
As motherboards all have different specs, you will need to provide the model number to get any relevant information. Plus the IC number is written on the chip casing.
Apr 24, 2013 | Computers & Internet
How to troubleshoot a mother board
to trouble shoot motherboard you need to know basic of motherboard there are mainly three thing s for motherboard to work first voltage +12v +5v +3.3v the motherboard then needs clock and reset to start adreesing the lcok is produced by the 14.318Mhz crystel and restet is produced by 32 khz crystel when the power is on first the clock has to be present for the reset to function if the clock and reset and there and the adress line is not still working means the elecrolitic capcitors are fult the capacitors in motherboard have huge role to play they are ones prvent audiolines entering the adress lines
Jan 29, 2011 | ASUS M2N-MX Motherboard
Work on daynow it don't
The modern motherboard performs many functions and connects to a wide variety of devices, but the hardware's most basic role is to connect the system's microprocessor to the rest of the computer. The central processing unit, otherwise known as the CPU, is typically housed in a socket on the motherboard. From there, the motherboard receives electrical power from the system's power supply and distributes it to the CPU.
Oct 24, 2010 | Computers & Internet
Replacing a IC on a ECS RS400-A motherboard
Hello kingjaymes,
Here's a picture of your requested motherboard,
http://www.ixbt.com/mainboard/ecs/rs400-a/board.jpg
Hope this helps.
Nov 19, 2009 | Acer Veriton 7100 PC Desktop
What if the power ic of philips freevents x60 was burned?is it repairable? the value of the power ic cannot be recognized. is there a way to find what value it is?how?
1.If the power IC is burned, it isn't the only IC that's going to be defective now. Kind of like a 'domino effect'.
2.It isn't a simple fix, of just un-soldering a component from a motherboard, when dealing with a laptop motherboard. All motherboards are built in layers, (Desktop and Laptop), but laptop motherboards are even more layered.
http://en.wikipedia.org/wiki/Printed_circuit_board
(Scroll down to the heading -> Lamination, then read the entire article. Also check the links at the bottom)
This means the actual circuit trace may be between layers. (Circuit trace. The thin strip of copper, left behind after the Printed Circuit Board is etched)
You won't be able to un-solder it without burning the board, (Motherboard, or also called PCB), and re-soldering is twice as tough.
You need a reflow machine, high magnification, a precise soldering station, and highly developed soldering skills.
Not trying to ruin your day, or offend your computer repair skills.
Replacing the motherboard may be the only viable option. Check Ebay-> Computers and Networking>PC Components>For Laptops and Notebooks.
Also > Laptops for Parts.
You have seen that this IC is burned? I ask because the X35, and X55, had a bad problem with the On/Off switch going bad.
Aug 06, 2009 | Computers & Internet
Regarding BIOS
BIOS stands for Basic Input/Output System.
It's a 64MegaByte (MB) program, that is 'burned' into the BIOS chip, on the motherboard.
(Chip is slang for IC.
Integrated Circuit. I suggest you go to Wikipedia.org, and in their search bar, type -> Integrated Circuit. Also look up -> BIOS)
When you push the Power On button, the Soft Power On, part of your power supply, is momentarily connected to Ground. This makes the power supply come on.
Power is supplied to the motherboard, through the 20/24-pin ATX motherboard power cable. (Also, some processors require a separate power cable, connected to the motherboard. Either a 4-pin ATX power cable, or an 8-pin EPS +12 volt power cable)
The BIOS program, on the BIOS chip, on your motherboard, receives power.
BIOS then looks to see what devices are connected to the computer, (Peripheral, and what's in the Expansion slot/s), does a Ram Memory count, then turns the processor on, and hands the computer over to the Operating System. (Windows XP is an example of an Operating System. O/S)
For more info, I suggest you check out Wikipedia. Start with Motherboard. Anything you see in Blue, is a link you click on, for more info about it.
Also check out Howstuffworks.com- "Computer Channel"
And, check out Hardwaresecrets.com
Apr 28, 2009 | Biostar P4M80-M7 Motherboard
The power supply burned out. replaced it. Still I get, no signal
there will be one INTEGRATED CIRCUIT (ic) near by the pci slot it is called as the video adapter ic ....
if this ic is dead then the the display will not come ...
so you need replace that ic ..
you can do that if you are experienced professional ...
if you have no idea then you need take it to motherboard technician ... ..
regards
-Dileep
Nov 23, 2008 | E-Machines (308714) Motherboard
Gigabyte GA-8SDX Motherboard
Whats the board? Is the IC soldered on the board or does it plugin? What are the numbers on the IC itself?
Jul 14, 2007 | Gigabyte GA-8SDX Motherboard
Computers & Internet Logo
146 people viewed this question
David Payne
David Payne
