Question about Uniden PRO510XL (40 Channels) 2-Way Radio
I have a Motorola MTS2000 800 mhz truning radio, when nothing is being broadcast I gets intermitting static, it has short bursts of static. what is casusing this and how do I get if tixed?
  • drazinsky Aug 26, 2010
    it is not a Uniden Pro510XL it is a MTS2000 Motorola trunking 800 mhz radio
  • 3,866 Answers
This might be your mic causing this or a loose ground
1. Do others hear it when you que up?
2. Do you have all your wires shielded
3. Ground wire in the correct place.
This could be many causes mainly the mic that causes this also loose or poor connections do cause this as well, please check and let me know.
Please do click the accept button for my efforts.
Posted on Aug 26, 2010
How do you get the cobra walkie talkie to say the weather
Provided that your 2-way radio has the feature, there should be either a dedicated weather button or somewhere in the menus. Not sure what model you have. If it is a more advanced radio where you can set the frequency, the list of weather broadcast frequencies taken from NOAA are listed below. Two way radios are normally automatically programmed to one of these frequencies and usually require a push of a button.
Nationwide Station Listing Using Broadcast Frequencies
162.400
MHz 162.425
MHz 162.450
MHz 162.475
MHz 162.500
MHz 162.525
MHz 162.550
MHz
Jul 02, 2014 | Radio Communications
Mag One Radio - Static
If your BPR40 radios are all about the same age, it could be a sign of your batteries getting old and needing replaced. A bad or weak battery will cause the radio to exhibit static, and then eventually poor or no transmit. Check your battery date code first, it is a 3 digit number on the battery label, followed by a space and then usually a number 1. On the 3-digit code, the first number is the year, the next two the week of the year. 229 would be 2012 the 29th week. Replacement batteries should be available for around $35.
If you feel the battery is not the issue, you may have ONE radio which is causing the problem. Try using all your radios and testing by shutting off just one radio at a time. You may identify the culprit. Motorola offers a one year warranty on the BPR40, after the warranty is done, flat rate repair is typically available for $69.
Third possible cause is some type of interference in your area. If this is the case, your radios may need a PL code programmed into them, if you don't already have one. This will filter out unwanted noise or transmissions. Sidenote: If you've added any new computers or electronic office equipment recently, it may also interfere. Some foreign produced computers will lack the filters required in the USA to prevent interference with communications. Coiling excess cables can be helpful in stopping RF noise.
The second of static at the end of your transmission is called "white tail" and is common in all modern radios. There is a programming feature to eliminate most of the white tail noise, it is called reverse burst. Your radio dealer can reprogram your radios and add this to your radios, or future radios you buy. The trade-off with reverse burst is that you will loose the last of your spoken words if you do not hold your PTT an extra moment, as reverse burst actually transmits back or cuts off the end of a transmission to eliminate the noise. White tail is worse when mixing old model and new model radios together.
Best regards.
Jul 12, 2012 | Motorola Mag One BPR40 Two Way Radio
I need to know what the number for the weather frequeancey for my radio.
Nationwide Station Listing Using Broadcast Frequencies 162.400
MHz 162.425
MHz 162.450
MHz 162.475
MHz 162.500
MHz 162.525
MHz 162.550
MHz
For active frequencies in your county, visit the National Weather Service web site:
http://www.weather.gov/nwr/indexnw.htm
Bill B.
Listening in since the 60's
May 23, 2011 | Uniden BC92XLT Handheld Scanner
What frequency do they broadcast at?
FRS/GMRS frequencies range between 462.5625 and 467.7250 MHz.
Let me know if you need the individual channel breakout.
Bill B
WQJV930
Aug 05, 2010 | Motorola Mobility T 4900 AA RADIO, T4900...
Short static burst
I don't know a whole lot about microphones, but if it's wireless, then it has to accept interference according to the FCC. Wireless microphones normally connect using RF transmitters/receivers which can normally be tuned to specific short-range broadcast frequencies, which can be interfered with by passing waves of other frequencies. Even if the broadcasted radio waves aren't the same frequency, or within the same bandwidth, the harmonic distortion radiates at multiples of the fundamental (broadcasted) frequency.
If you can, try changing channels and see if that clears things up. If not, then perhaps contacting the manufacture can help.
Jun 03, 2010 | Sennheiser (EW165G2A) Professional...
I get static so bad that I can't squelch it down enough to get rid of the noise. Traveling out on the highway it usually works ok. But when I enter a town the static gets badusually around power lines. How...
You could install a filter in the line between the antenna and the transciever. I reccommend a high-pass or band-pass filter set for the 27 MHz band to remove any interference at different frequencies. Also, some older TVs can cause interference to CB radios if they are close. If this doesn't work, the radio may be poorly sheilded or your area may have implemented the broadband power line initiative (BPL). This produces a strong buzz of noise that obliterates all weak to moderate radio signals between 2 and 80 MHz (CB being at 27 MHz).
May 21, 2010 | Cobra 19 DX IV CB Radio
I can't retune the channels on my motorola xtn
Sorry, but the XTN446 has only the 8 channels pre-programmed by the manufacturer.
Channels 8
Codes 121
Frequencies 446.00625 MHz
446.01875 MHz
446.03125 MHz
446.04375 MHz
446.05625 MHz
446.06875 MHz
446.08125 MHz
446.09375 MHz
Here is a copy of the spec sheet: http://www.comm-spec.com/pdfs/radios/Motorola-XTN446-UHF-License-Free-100225.pdf
Best regards.
Mar 27, 2010 | Motorola XTN 2-Way Radio
Can i change the frequencies on my two way radios?
No, unfortunately there is nothing you can do to change the 462-467 MHz radio to do the PMR 420-450 MHz which is legal in the UK.
Here is some info concerning PMR446: http://en.wikipedia.org/wiki/PMR446
Apr 24, 2009 | Motorola CLS 1110 (1 Channel) 2-Way Radio
Cant get weather on hand held scanner
The 92 does not have a separate/dedicated weather band feature, but you can program individual NOAA frequencies into it. Weather broadcast frequencies are: 162.400 MHz : 162.425 MHz : 162.450 MHz : 162.475 MHz : 162.500 MHz : 162.525 MHz : 162.550 MHz.
Apr 10, 2009 | Uniden Nascar BC-92T Scanner
I get static after someone else talks
One of the main causes of static can be a bad battery. If you are using rechargeable batteries you need to replace them every 14-18 months. If you are using alkaline batteries, they have been known not to fully power the radio once your cross the 10 hour mark. Your radio would then be operating in somewhat of a brown out. This would lead to static.
Another cause of static is simply being nearly out of range of the other radio(s).
The burst of white noise at the end of Rx on some radios can be rather annoying. On the basic talkabout radios there is nothing which can be done to solve the problem, other than replacing the radio.
Jul 26, 2008 | Motorola Talkabout T5700 AA (22 Channels)...
Uniden PRO510XL (40 Channels) 2-Way Radio Logo
Top Uniden Radio Communications Experts
Jason
Steve
eradiostore
eradiostore
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
