Question about Amana ABB1924DEB / ABB1924DEW / ABB1924DEQ Bottom Freezer Refrigerator
Amana BR22 Bottom Freezer works good, but top fridge stopped working. Could this be due to excessive lint build-up on cooling coils under fridge? If so, how is it possible to clean the coils, as there is only a tiny little access from the front, no access from the back, and no way for me to lift up the appliance in order to access from underneath? Thank you for your help. JR Bailey
  • Amana Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Aug 28, 2010
My amana abl1922fes has quit cooling several times in the 5 years i've had it. We unplug it, let it set overnight and plug it back in and it cools fine for a few months when it quits cooling again. Can...
when it stops cooling, you will see some ice build up in the freezer. Letting it sit unplugged melts the ice and you will see some water under the fridge. Connect power and it works. Cause: don't overload the fridge and the freezer. Make sure the doors close snugly. Clean all lint build ups by vacuuming under and behind the fridge after switching off power.
Mar 06, 2014 | Amana Refrigerators
I have model number ARB1914CB, 4 years old and the fridge part has pretty much just stopped working. Tiny bit of cool air coming in from the back vent but the "running" noise of the fridge is no...
A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Condenser
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
Aug 20, 2008 | Amana Refrigerators
Fridge as excessive ice forming on back panel
heatman101
Sep 06, 2010 | Baumatic BR22 8A Bottom Freezer...
Amana #srd2555w bought from a friend in working condition. 3 yrs old brought home on its side. vacumed coils working 3 days then stopped cooling in fridge followed by ice build up and not working in...
You have a defrost problem. 3 parts: Timer (or "adaptive defrost control"), defrost heater and def. termination thermostat.Find the timer, it shoud be nehind the bottom front grille to the right on Amana (if you see a blck box under there with a sticker on it, it's the ADC model) turn the timer CW until it clicks. Take the back off the bottom of the freezer and listen. After 5-10 minutes if you hear the sound of the sound of water hitting a hot grill. If you hear this the heater and thermo are working and the problem is the timer/ADC. No hiss? Unplug fridge. Check thermo and heater for continuity. Replace the one that's open. If the heater's open, replace the thermo too: Maybe it didn't open soon emouhg and caused heater failure.
Sep 25, 2009 | Amana SXD524VW Side by Side Refrigerator
The bottom freezer on my Maytag BR22 is not
Look at the inside back wall of the freezer, If you see that it is built up with frost. You have a defrost problem. If not, check the coils under the bottom, make sure they are clean and not covered with dust. If so clean with vacuum and long brush. If they are clean, check the fan that blows on the compressor. Make sure it's running. If not you have a bad fan. Last be sure the fan inside the fridge is running.
Please rate solution
Sep 07, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Freezer working but fan not on in fridge - where to locate fan?
May be ice build up - happened with mine. Had to defrost completely (unplug for 24+ hours) then it worked fine on restarting.
Aug 15, 2009 | Amana ABB1927DE Bottom Freezer...
Fridge wasn't cooling but freezer was working, now both aren't
Hi,Your husband did good job, after cleaning and vacuuming, did freezer (bottom) have excessive ice?, if there's excessive ice in bottom, after cleaning, you have a defrost problem, but if there're no ice in freezer after cleaning, you got freon (gas leak) , there's a condensate loop, that passes through ref. body, from compressor that naturally develop, freon leak after few years, by rusting, normally it can be by- pass. vacuum and refill with freon, if there's no freezing, but compressor running, you'll need a mechanic, you got a freon leak. good luck.
Aug 10, 2009 | Amana ABB1927DE Bottom Freezer...
Amana BR22 top refrig not cooling
HI, your Air damper control assembly is faulty. you should replace this vital part asap.
May 24, 2009 | Amana ABB1924DEB / ABB1924DEW / ABB1924DEQ...
Refridge not cooling
freezer side is working good but cooling side is not cool
Sep 24, 2008 | Amana ARB8057CSR Bottom Freezer...
Amana ABB1924DEB / ABB1924DEW / ABB1924DEQ Bottom Freezer Refrigerator Logo
163 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
