Question about Samsung HL-S5679W 56" HDTV
Half of the screen has picture and the other half is all rippled and has vertical lines
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 453 Answers
U have a bad dmd board , or optical block , this part is about $200
Posted on Aug 26, 2010
Any advice on what board I should replace if the left half of the screen is no good, just showing white and black vertical bars? Right half is fine. Is the panel kaput?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 29, 2015 | Panasonic TH-37PH9UK 37" Plasma Display -...
How do I fix vertical lines and no picture.
Line, faults & possible causes to both Plasma & LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 20, 2015 | Vizio E320VP 32" LCD TV
Only half a picture
"the vertical lines" is not correlated with the lamp
1,the interface between the mother board and DMD drive board
2,to clean the the interface with some alcohol
3,securely plugged
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
skype:lampdeng
Feb 16, 2014 | Vidikron MODEL 65 Lamp
Tv 27" has only half screen picture horizional I
Possible failure of the VERTICAL SECTION of the deflection circuit. It is possible that the areas related to the vertical circuit is checked , check for weak capacitors near the output vertical drive. Also a faulty vertical coil- deflection coil- can result in half picture.
A vertical signal test can confirm.
Oct 16, 2011 | GE Televison & Video
Plasma only showing half picture
This is beyond consumer ability to repair. Please have it looked at by a qualified electronics service company.
Nov 23, 2009 | Panasonic Televison & Video
Lines running vertical that appear to be red
hi
it is colour wheel problem,,,check it
please rate it..
thank u....
Jul 04, 2009 | Televison & Video
Screen is half picture and half black with vertical colored lines
I had the same issue. I could get the tv to work intermittantly by pressing on the boards while playing. This points to bad solder joint, so I resoldered every molex plug connector, and it nows works like a charm.
Apr 06, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
CRT TV with a white line half way up the screen
The white line is result of a Vertical failure. Believe it or not, the whole picture is contained in that one white line, but it is not spread out from top to bottom on the screen.
Usually, a vertical failure is IC or capacitor related. Should be an easy, fairly inexpensive fix for a competent repair shop.
Hope this helps you...
Jan 05, 2009 | Televison & Video
Can only see half the picture
Locate Vertical Output device--replace w/OEM equiv.or better.
Oct 10, 2007 | RCA TruFlat 27F520T 27" TV
Tv image
Hello bouloulou, Well let me tell you what you have is a loss of Vertical Linearity. This could be cause by a power supply issue or by inproper filtering of the dc voltage used to supply the vertical section of the TV. There used to be a control which allowed you to adjust this along with Vertical Size which controled the bottom of the screen. These days the signal processor chip takes care of this along with a few capacitors. I woould suggest that if you do not have a background in electronics that you take the set to a shop for repairs, If you do have a background in electronics, get a schematic for this set and the use your multimeter set to DC volts to measure the DC levels in the vertical section of the TV. Also you will need an oscilloscope to measure the ripple voltage on the DC power supply the schematic will show you how much ripple is allowed. I hope this helps. Thank you, Shuttle83
Oct 08, 2007 | JVC AV-27230 27" TV
Samsung HL-S5679W 56" HDTV Logo
76 people viewed this question
Henry  Thomas
Henry Thomas
