Question about Yamaha 12V Air Pump
WANT TO BUY THIS YAMAHA GP1200 IT CRANKS BUT ITS NOT GETTING SPARK THEIR IS A WIRE COMING OUT THE GLOVE COMPARTMEN WITH AN ON AND OFF SWITCH WHICH I BEKIEVE GOES TO THE ELECTRICAL BOX I HIT THE ON BUTTON BUT STILL NO SPARK THINKING ITS A KILL SWITCH SHOULD I HOLD DOWN THE BUTTON WHILE HITTING START
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 118 Answers
That sounds more like an aftermarket bilge switch, is the boat all stock?
Posted on Sep 10, 2010
Why does the waverunner does not start
You are in the wrong category.
Jun 12, 2013 | Cars & Trucks
Yamaha waverunner does not start
hi there it sounds like the switch gear need pulling apart and the copper contacts cleaned as it sounds like the kill switch is closed up and the starter button contacts need cleaning as well also check to see if the stater soliniod might need a cleanup where the wires go,also check your fuses to see if there contacting alright if you ride in all weather or the bike sits outside it can have these problems as mouisture gets into everything. hope this helps cheers pete
Jun 12, 2013 | Yamaha 98 Gp 1200 Air Box Intake Mount...
I just replaced the piston in a 74 yamaha 175 mx. It had spark before the rebuild, but not now What tests can I perform? Thanks, Randy.
First, get a new spark plug. Next remove the gas tank and check the small black wire running out of the coil. Is it plugged into a wire connector?. Check the spark plug wire and plug cap also. All connections should be snug and clean. Is the handlebar kill switch in the off position? Check the key switch wire connections. Check the neutral switch wire. I don't remember if the side stand had a kill switch or not. Check it out. I think it didn't have a switch. Check the battery connections. Check the wire coming from the points. Good connection? Run a fingernail file between the contact points to remove any pitting and foreign matter. Set the points to a .015 opening when the points are at full open position on the cam. These things are in the sequence I would check. Please rate my answer. tombones49_217.gif
Jul 30, 2011 | Yamaha Renegade 200 Motorcycles
I am not getting any spark
You will need a digital multimeter for easy reading ( The one I use cost $5 ). Find the connecter for the two wires for the on/off switch. Disconnect the wires and connect the meter leads to these terminals. Set the meter to Ohms and check that the switch opens and closes connection. Should read OL when open and .01 when closed depending on meter setting. If it checks out, then not the switch. Also check the coil and spark plug boot/wire with Ohm meter. Be sure that the boot is firmly connected to the wire. Small wire to frame- OL. Small wire to spark plug boot- thousands of Ohms (possibly 5000-30000 but don't know the spec). If either of these shows a small number of ohms (example: .01-7 ohms), then there is a short in the coil. Also check that the steel bar of the coil is grounded to the frame/engine with Ohm meter- 0.01. To test the source coil connect ohm meter to small wire coming out and other meter lead to engine ground- should be hundreds of ohms. Sometimes it is easier to start replacing at the least expensive part!
Nov 18, 2009 | 2007 Yamaha Stratoliner
Problems starting my 2003 Yamaha TTR225
The cylinder is the coil. It might be bad but it is expensive and you would not replace it till you know for sure there is no spark. You can take the plug out and then put it on the wire and ground it against the engine while a friend cranks the starter. Look for the spark flash. Make sure the kill switch is in the "on" position.
If that shows a spark then you will need to move into a different line of troubleshooting. I always recommend that people buy a Clymer manual.
Jul 31, 2009 | 2003 Yamaha TT-R 225
1998 GP1200 yamaha jet ski won't start
When replacing battery in yamaha GP1200 when attach negative cable the unit seems as wants to turn over the engine while the unit is off and no key in place.. also notice in seconds that the battery terminal on negative side started smoking..actually melt the new battery terminal on negative side..yes, postive was connected to positive. Any ideas what why this would take place??
Jul 15, 2009 | Yamaha 12V Air Pump
Hello, i have seem to have forgotton where my ground wire connects to for my 1999 Yamaha GP1200.Please help.......
you can ground it to any clean bolt on the motor make sure its clean and the right size bolt and youll be good
Jun 24, 2009 | Yamaha 12V Air Pump
No spark on my bike haven't road for a year now help please
Check the kill switches including the side stand switch, with an Ohmmeter. Good battery? Good fuses" All wires clean and with a solid connection? Check the loom. Any abraded wires? Check the operation of the ignition switch with a volt ohmmeter. Is the bike in neutral and the neutral light is lit up? Get new stock spark plugs.
If still no spark, get CDI system and coils checked at the dealers shop.
Please rate this solution. Thanks burbee904!
Apr 05, 2009 | 2000 Yamaha YZF-R6
Yamaha 12V Air Pump Logo
238 people viewed this question
Top Yamaha Water Sport Experts
Colin Stickland
Colin Stickland
Piyal Perera
Piyal Perera
Are you a Yamaha Water Sport Expert? Answer questions, earn points and help others
