Question about GE Profile 22.2 Cu. Ft. Bottom-Mount Refrigerator - Stainless-Steel
Tic toc noise-compressor not starting-not cooling
  • GE Master
  • 43,501 Answers
<span style="FONT-FAMILY: Arial; BACKGROUND: white; COLOR: black; FONT-SIZE: 10.5pt">Hi,</span><br /> <span style="FONT-FAMILY: Arial; BACKGROUND: white; COLOR: black; FONT-SIZE: 10.5pt"><br />As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.</span><br /> <span style="FONT-FAMILY: Arial; BACKGROUND: white; COLOR: black; FONT-SIZE: 10.5pt"><br />If your refrigerator is running but warm, then&hellip;</span><br /> <span style="FONT-FAMILY: Arial; BACKGROUND: white; COLOR: black; FONT-SIZE: 10.5pt"><span style="mso-tab-count: 1"> </span><br />Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...<br /><br />Refrigerator Condenser Coil Cleaning Refrigerator Repair<br /><a rel='nofollow' href="http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning" target="_blank">http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning</a><br /><br />Refrigerator Troubleshooting Refrigerator Compressor<br /><a rel='nofollow' href="http://www.fixya.com/support/r3885294-refrigerator_troubleshooting" target="_blank">http://www.fixya.com/support/r3885294-refrigerator_troubleshooting</a><br /><br />Refrigerator Compressor Start Capacitor and Start Relay<br /><a rel='nofollow' href="http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor" target="_blank">http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor</a><br /><br />heatman101 <br style="mso-special-character: line-break" /><br style="mso-special-character: line-break" /></span><span style="FONT-FAMILY: Arial; COLOR: black; FONT-SIZE: 10.5pt"></span>
Posted on Aug 26, 2010
Sunbeam mantel clock cant get chimes correct model no.882-497
Have you made sure that the clock is perfectly level? It needs to be level from side to side and front to back. Just a millimeter or two off and it will not keep a proper beat. When you first start the pendulum swinging is the tic toc sound off a bit? If so try putting a very small shim at either side to see if that helps, if not try putting it under the front or back of the clock until you get an even tic toc. If you still cannot get it right let me know and I can give you another suggestion.
Sep 24, 2017 | Home
Build your own tic toc clock
You can try google but yellow pages may be better.
Search your yellow pages for clock repair or watch repair. Not many left but they exist. These guys don't always show up on google.
Sep 04, 2014 | Watches
Toc read
It is the toc part of tic-toc! You need to put your question in contex!
Jun 29, 2014 | Insignia Audio Players & Recorders
The compresor make a noice but not start
Faulty compressor. May be new electrics would work but most likely compressor needs replacing
May 15, 2012 | Avanti Refrigerators
My 1996 Suzuki Bandit 600 makes a tic-toc noise, as I accelerate. It increases in speed as the motor gains rpm, coming from the clutch area. New chain and sprockets so thats not the issue. How do I check...
Shift cams ( more correctly known as shift drums ), never get broken and I have never seen one wear out in over 40 years of fixing bikes. No real pressure is put on them and they only rotate due to the shift lever moving up or down. The noise is likely a broken tooth on the clutch hub or generator gear or (possibly), too much slack in the cam chain. Please rate my answer. Thanks! tombones49_198.gif
Jun 26, 2011 | 1996 Suzuki GSF 600 N Bandit
It is making a tic toc noise. It is not refrigerating. The model is : Magic Chef MCBR445W1 Thanks
the noise is from the ptc overload relay located in the lower rear on the compressor,its a safety component that aids in starting the compressor and shuts it down if the compressor overheats,unplug it off the compressor and get an exact replacement and the unit will again cool and stop tick-tocking
Mar 03, 2011 | Magic Chef MCBR445W1 Compact Refrigerator
Fridge not cooling and make tic tic noise
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
dfafh
May 19, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a knocking sound in the engine when I first start it up that goes away after a few minutes. 1998 Ford Windstar with about 116,000.
Is it a low down in the engine toc, toc, toc or a lighter tic, tic , tic sound?
The lower one is quite often the main bearings, rather than pulling the engine to fix it run 10W30 oil in it instead of 5W30 and treat the old lady with respect and don't rev or drive her till the knocking stops. It stops because the oil pressure has build up. If it is the lighter ticking this is the hydraulic lifters, don't worry about it, just do the same. Make sure you don't go longer than about 4000 miles between oil changes. I put Synthetic blend in all my cars and run 5000 miles between changes.
Hope this helps.
Sam
May 12, 2009 | 1998 Ford Windstar
GE Profile 22.2 Cu. Ft. Bottom-Mount Refrigerator - Stainless-Steel Logo
95 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
