Question about Microwave Ovens
Manual for acu-rite 00754-RX - Microwave Ovens
How do I use power feature?
Sanyo EM-S5002W Instruction Manual & Cooking Manual
www.manualslib.com > ... > Instruction manual & cooking manual
Sanyo EM-S5002W Manual Online: Control Panel And Features. OPERATION (1) ...Sanyo instruction manual microwave oven em-s5002w. Hide thumbs ... cooking. (4)POWER LEVEL. Use to set power levels other than. 100%. (5) KITCHEN ...
Oct 09, 2015 | Sanyo Microwave Ovens
Frigidaire glmv169dqc microwave
So you have the problem with the microwave not turning on?Or is it just the touchpad.
May 10, 2008 | Frigidaire GLMV169D Microwave Oven
Tip
Error Code F8E5
F8E5 Exhaust air template detection failure 1. Press CANCEL - CANCEL - START, verify failure code, and then press CLOCK/OPTIONS to display the exhaust air temperature sensor reading. Verify the sensor temperature reading is at room temperature (typically 50?F to 90? [10?C to 32?C]) and verify failure code. If failure code matches complaint, continue to Step 2. 2. Unplug microwave oven or disconnect power. 3. Disconnect sensor from ACU PCBA. 4. Measure HF NTC resistance between connector pins and confirm reading is between 9.5k??and 10.5k??at room temperature. If measurement is not correct, or if a short or open circuit is found, replace sensor. 5. Replace all parts and panels before operating. 6. Plug in microwave oven or reconnect power. 7. If the sensor temperature reading is still not correct, replace ACU PCBA. 8. If failure does not appear, stop.
on Jul 21, 2015 | Whirlpool WMH31017AW
I have an AcuRite #00994W oven thermometer and have just tried to use it for the first time and find that it will not turn on. I assume the battery must be dead but cannot find battery replacement...
Hold firmly to the face of the thermometer with your right hand. With your left hand fingers push the stand towards you slightly. Then use your thumb on the opposite side to separate the stand from the main unit. Do not squeeze the sides together. Do not be surprised if breaks the tabs that hold the stand to the unit. This part of the unit is poorly designed. You should then see the battery compartment on the back of the unit. Be aware it takes 2 AAA batteries.
May 16, 2011 | Microwave Ovens
I have a cookworks microwave and turntable wont turn
you may find that the turntable motor has failed but it may also be the coupling under the plate to get to the motor u need to remove the plate and tip the unit on its side rite in the middle of your unit you will see a square plate u will need to cut this away at the corners when you have taken this off you will see the motor do unplug the unit before you do any work on it also to refit the plate all u do turn it around and use a small screw to hold it in place
Nov 03, 2009 | Microwave Ovens
Manual
RE: Kenmore Microwave Model 5668878411 "Instruction Manual"
Kenmore Customer Care @ http://www.kenmore.com/shc/s/nb_10154_12604_NB_CustomerCare?adCell=AF
Click on the above link to order a manual or download a free manual.
jackiaria
Mar 01, 2009 | Kenmore Microwave Ovens
Microwaves without a turntable
It is very hard to find any quailty microwave made today without a turntable.
You can go to Rite-Aid or Walgreens and find them there without turntables.
Feb 12, 2009 | GE JE1860 Microwave Oven
Need users manual
I need a user manual & parts list for a Quasar microwave, Model # MQ9968W built in 1991. Is this manual available in a pdf format or in hardcopy?
Nov 26, 2008 | Goldstar MA-1112 Microwave Oven
Microwave Ovens Logo
685 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
