Question about Sanyo DVW-7100A DVD Player/VCR
I put on the DVD disc, it tries to read it 3 times and then I get error message - check disk, after several open/close the system reads the DVD, any suggestions?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 61 Answers
Hi! If you are not technically proficient, I would recommend using a quality DVD lens cleaner, readily available from many retail stores. In essence, they are just a DVD disc with tiny brushes attached to the playing side, that gently remove surface debris from the lens. If you are brave, you can also take off the cover of the unit (make sure it is not plugged in to the power outlet...duh...!!!), and the exposed lens may be very carefully (...did I say VERY CAREFULLY strongly enough...?!?) cleaned with a cotton swab and alcohol. If you are not able to correct the tracking issues with either or both of these techniques, I would consider buying a new unit. Unfortunately, the repair cost for realigning the lens and/or circuit replacements are generally more than you would want to spend on an older player (unless it is a very expensive unit). Hope some of this helps.
Posted on Aug 26, 2010
My Xbox 360 isn't reading any discs. Games nor Movies. When i put either in the game console it tells me to open the tray because it didn't read.by the way it makes a funny noise when it tries to read the...
take out the cd. close the tray with no disk in it. let it read till it says open tray
open and close it like 3 times with tha method mentioned above with out the disk. then put the disk back in and it will probly work.
sometimes the system turns dumb and u haft to remind it to reconize when there is actally no disk.
Oct 25, 2010 | Microsoft Xbox 360 Console
Wont read games only reads dvds
This is going to be a bit long -- but very detailed, so please read it carefully. There are several reasons that an xbox 360 system will have problem reading discs. The error messages also vary from unreadable disk, no message at all but the game skips, "please insert disc in a 360 console" to "open tray." There are a few reasons this may happen:
1.Bad disc. Check the back of your disc for scratches. If it looks good (or plays fine in another console), then the disc is probably fine. Also-- try more than 1 game to be sure.
2. Bad laser. The XBox 360 has a DVD drive very similar to a PC's DVD drive inside. The drive contains a bunch of parts including a few motors and gears and a laser.The laser is the part that actually reads the disc. The reality is...with all the hours and hours of game play, lasers do eventually wear out. The laser isn't very easy to replace, but it is replaceable. You can find any and all XBox 360 lasers at the following website:
http://store.richspsxparts.com/xb360ac.html
3.Bad DVD Drive. Sometimes other components inside of the DVD drive can become bad such as the motor that spins the disk, the motors that open the tray, etc, etc. You can get a new DVD drive to just replace everything,including the laser, in one shot but there is a catch. The XBOX 360's DVD drive is tied to the motherboard using a software lock.The easiest way to overcome this lock is to buy the exact same manufacture DVD drive that is in your system now, remove the circuit board from the old DVD drive (which contains the software key) and transfer the circuit board into the new DVD drive that you purchase. If you do this simple procedure, there is no flashing involved. The following website carries DVD drives and also provides instructions on swapping the circuit board from the old drive into the new one.
XBox 360 parts: http://store.richspsxparts.com/xb360ac.html
DVD Drive Swap Info: http://store.richspsxparts.com/imnooninxb36.html
May 15, 2010 | Microsoft Xbox 360 Pro System Console
Panasonic dvd players error codes
I tried the WD-40 and it worked........thanks a million !!
Mar 28, 2010 | Panasonic DVD RV22K
Everytime i put in a game in my 360 it says open tray
1. Bad disc. Check the back of your disc for scratches. If it looks good (or plays fine in another console), then the disc is probably fine. Also-- try more than 1 game to be sure.
2. Bad laser. The XBox 360 has a DVD drive very similar to a PC's DVD drive inside. The drive contains a bunch of parts including a few motors and gears and a laser. The laser is the part that actually reads the disc. The reality is... with all the hours and hours of gameplay, lasers do eventually wear out. The laser isn't very easy to replace, but it is replaceable. You can find any and all XBox 360 lasers at the following website:
3. Bad DVD Drive. Sometimes other components inside of the DVD drive can become bad such as the motor that spins the disk, the motors that open the tray, etc, etc. You can get a new DVD drive to just replace everything, including the laser, in one shot but there is a catch. The XBOX 360's DVD drive is tied to the motherboard using a software lock. The easiest way to overcome this lock is to buy the exact same manufacture DVD drive that is in your system now, remove the circuit board from the old DVD drive (which contains the software key) and transfer the circuit board into the new DVD drive that you purchase. If you do this simple procedure, there is no flashing involved. The following website carries DVD drives and also provides instructions on swapping the circuit board from the old drive into the new one.
Mar 17, 2010 | Microsoft Xbox 360 Halo 3 Special Edition...
DVD Player stops reading disc Error message :
usually this happens when lens cannot read the the disc. Due to few reason 1 Your disk is scratched 2 Your DVD lens is covered with dust 3 You need to replace DVD lens
Try another few CD/DVD to rectify whether there is any problem with dvd you are trying to play
if this error occurs on all the dvd you played then the most likely proble is with your DVD lens either its coverd with dust use Disk cleaner if not you got to replace a new DVD lense as per model
Feb 18, 2010 | Samsung DVD-V9800 DVD Player/VCR
My xbox360 will not read disc, message reads
First some basic steps to troubleshooting
1) Restart your console.
2) Check for loose cables.
3) Pull out all the cables, and get them back in.
4) Take out the hard-drive, and put it back in. Repeat this 4 times.
Try to use several similar Xbox 360-compatible discs in the console to determine whether the disc that you are using is causing the problem. To test whether the problem is caused by a specific disc, use a disc of the same type, such as a game disc, DVD movie, or music CD. If the problem does not occur when you use other discs, that specific disc might be the cause of the problem.
For disc-specific issues, check the disc for any visible signs of damage or dirt. Hold the disc by the edges without touching the top or bottom surfaces with your fingers. Clean the disc by using a soft cloth. Lightly wipe from the center outwards. Do not use solvents or chemicals to clean the disc.
If you suspect that the Xbox 360 device could be causing the problem you can follow these steps
1. If you have access to another Xbox 360 console, try to play the disc on the other console. Or, if the disc is a CD or a DVD, try to play the disc on another device, such as a CD player, a DVD player, or a computer that is equipped to play CDs or DVDs.
2. If you have an Xbox 360 Hard Drive (HDD) or Memory Unit (MU) attached to the console, turn off the console, and remove the HDD and any attached MU. Then, turn on your console, and try the disc again. If this seems to resolve the problem, turn off your console, reattach the HDD and MU, and then delete any saved games for the game that is causing problems.
If this does not resolve the problem but removing the hard disk does, clear the hard disk drive cache
To clear the cache, follow these steps:
1. Move to the System Settings section of the Xbox 360 dashboard.
2. Select Memory.
Highlight a storage device.Do not press the A button, Press the Y button to view the Device Options screen, Select Clear System Cache, and then select Yes to clear the cache.
I presume you do not have a hacked version of Xbox 360 because this problem is prevalent with Xbox 360 dvd drives which are hacked also if the above steps do not resolve your issue, please send your Xbox 360 to Repairs, call up MS support and check for the charges of Repairs in case your Xbox is not covered under warranty.
Let me know of this helped and please do take time to rate my solution
Happy Gaming, Happy Holidays
Regards
KreativeGeek
Dec 29, 2009 | Microsoft Premium System for Xbox 360
My NAD cd/dvd T550 displays NO DISC.
I have the same problem. When I insert a disk, my NAD T 550 DVD player displays 'No Disc'. It started with new disks while still reading older disks, but at some time it stopped recognizing any disk. Did you receive any suggestion yet or has anyone a suggestion?
Jan 27, 2009 | NAD T550 DVD Player
"loading" message appears several minutes, then "no disc" message
check another disk.
or your dvd lens is weak to read dvd
i think it can read cds now.
if not, try to update firm ware or your dvd.
Jan 17, 2009 | Televison & Video
Fisher CD-RW1000 2-Disc CD-dvd stuck in player
hmmmm.... try to take off the cover of your dvd player and observe it.(if you try my advice, try it in your own risk and with caution) then check the tray maybe there is something got stuck in there and also check the gears, if nothing, a belt just came off. check the motor too, I guess It has 2 switches too. clean them up. and then try to power up.
note:
(keep you fingers away at the power supply section)
Jan 29, 2008 | Fisher CD-RW1000 2-Disc CD Recorder
Error Code:DVD HO2
try to clean it first bring cleaner cd from radio shack. put your cleaning disk in and let it run-remove cleaning disk and put your disk and try,
Nov 03, 2007 | Panasonic SC-HT75 System
Televison & Video Logo
26 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
