Question about Sakar IConcepts Windows 107 Keyboard (16252)
I have an i-Concepts 62350NS wireless multimedia keyboard and mouse pair. They connect via a USB hub. Both worked great out of the box on my desktop which is running XP. However, this morning the keyboard simply stopped functioning. The device manager still recognizes it and says that it is working properly but it isn't working at all. The mouse is still working, though.
  • jameswgreen Aug 26, 2010
    This problem has been fixed. I disassembled the back cover and put a folded up business card over the ribbon connection between the keyboard and the small pc board next to the negative battery connection. Presto! Since the manufacturer did not use a real connector and simply relied on contact pressure from the back to maintain contact between the ribbon cable and the pc board just a little more pressure did the trick.
4 Suggested Answers
  • 51 Answers
SOURCE: Computer not recognizing Keyboard, only Mouse
Go through the process outlined in the instruction manual for connecting the keyboard to the wireless adapter. If this does not work, then replace the keyboard batteries and do it again.
Posted on Aug 17, 2007
MrFixIt268
  • 52 Answers
SOURCE: mouse works fine but cant get keyboard to sync
Might be a defective keyboard. Check and make sure its compatible for windows vista but all keyboards should work with any system.. As well maybe the port on the computer is bad..
Posted on Jul 26, 2009
  • 5 Answers
SOURCE: keyboard
I've used the 62150 black combo on XP Pro, not the 62150N Deluxe silver combo, for years without a problem after setting them up. Had 2 PS2 ports so had to use an adapter for the keyboard connector. To sync, press the ID button on the receiver. LED will blink fast for a few seconds, then slower Press the ID button on the mouse and keyboard while receiver is still blinking (need a pen or something for the mouse button). If the receiver LED blinks whenever you move the mouse or hit the keyboard, it is receiving the signal. If the OS does not recognize input, it could be the connectors (I had separate PS2 for mouse and keyboard each).
Their website does not provide driver downloads or much user support - stop posting the link for everything SLSL2000.....
Posted on Jun 20, 2010
Pair to iPad
Till now I did not know you could pair a mouse to an iPad. When someone is selling mice you can connect via bluetooth, they will give you the manual to. I hope you know, the iPad is not a computer on which you can connect lots of things. Only when Apple allows you to put anything on, or connect via bluetooth, it can work. Not when you think it should be great.
Because Apple made it possible to connect their key board to the iPad, you now can buy third party keyboards that work with the iPad.
Jan 30, 2015 | Ckeyin Mini Optical Bluetooth 3.0 Wireless...
Wireless keyboard and mouse not working after reastart
Just a thought--try this. Go into the device manager and delete all the USB ports. Don't worry--they will be reinstalled on restart. Sounds like there is something having to do with them that is confusing the computer.
Just right-click on My Computer (or Computer in Win 7), choose properties and then click on device manager to get there.
Nov 20, 2011 | Computers & Internet
I cannot get my keyboard or my mouse to work with my dell computer. what can i do?
Please add more information to get specific assistance. Are these wireless devices? If wired, do they use USB or PS/2 connections.
For wireless devices, try replacing the batteries and resynching to the receiver. (You may want to check putting the receiver in different USB ports.)
For wired devices, disconnect and reconnect. For PS/2 devices, you will need to restart the computer to check if the devices work. For USB devices, try connecting to different USB ports.
Next step, try using a different keyboard and mouse (that work on another computer (stick to USB or PS/2 to match the current pair)). Try a wired set if the problem is with a wireless pair. If those work, continue diagnostics on the wireless keyboard and mouse. Check if the mouse and keyboard work on another computer. If they don't work with another computer, replace them.
If another USB keyboard and mouse pair don't work in any port, your USB ports may have failed. Check if even one port works enough to access the Device Manager. (Start > Control Panel > Hardware and Sound > Device Manager (Win7); similar directions in other versions of Windows) Check for a problem with the drivers (For USB ports, scroll down to the USB drivers and look for a triangle with a yellow exclamation point or red x). Try to update the driver or roll it back. If that doesn't help and one USB port works, a USB hub may solve the problem.
Otherwise if the USB or PS/2 ports do not work with any devices and the driver fix doesn't work, then I'd suspect a problem with the ports on the motherboard. Replace the motherboard/computer.
I hope this helps.
Sep 12, 2011 | Dell Computers & Internet
I just purchased the 62350NS 2.4Ghz Wireless Multimedia Keyboard and Mouse. I am having trouble geting the windows tool tray with the icons to appear, it isn't there. Also, my mouse 'page-up &...
processes of installing the keyboard device. first plugin the wireless adpator onto the computer as the means with which the wireless signals are captured from keyboard to computer. Second, the wireless adaptor installs the required programs on the computer. Usually the keyboard once powered on would capture the signal display where for example, a prior installed adaptor is recognised by the computer either as logo indication on the desktop or control panel area. observe the component devices that require connectivity to ascertain that least attained from which restoration is attained.
Feb 19, 2011 | Computers & Internet
I need a driver for a sakar/I Concepts 62350N wireless multimedia keyboard
INEED A SET OF INSTRUCTIONS FOR MY MODEL 62350NS KEYBOARD AS LOST IN HOUSE MOVE,having just bought it before the move.
Nov 20, 2010 | Sakar Wireless Optical Portable Mouse...
I was given the wireless 1045 is there a usb plugin that goes with it ??? If so is it posible that this key board can work offf the usb addapter that I use for my mouse its a microsoft also. the model...
The keyboard is also paired with a wireless mouse. They both use the same USB wireless receiver. If the wireless mouse you are using is not from the set then no, you can not use the same receiver for both.
Jan 09, 2010 | HP Multimedia Cordless Keyboard/Mouse...
Wireless Multimedia keyboard volume keys won't work.
Go to start and run then type services.msc or if using windows 7 just go to start and type services.msc in the search box. Once open find the service "Human Interface Device Access". Change it from manual to automatic and make sure that it is started.
Apr 04, 2009 | Microsoft Wireless Optical Desktop 1000...
My Keyboard is Not Typing
press the connect butto the kbd along with the connect button on nthe usb port hub
release both the buttons together
it should work
Mar 28, 2008 | Logitech Cordless Comfort Duo PS/2...
KVM GCS1734 with microsoft wireless mouse/keybrd 4000
The MS keyboard & mouse receiver is effectively a USB hub with two devices connected to it. So, plugging it into the keyboard socket on the KVM switch may well work, depending on how that particular switch implements USB. If it just passes things through, it should be OK. On the PC side you should only need to plug in the USB cable from the switch's keyboard port.
Sep 30, 2007 | IOGear USB gcs1734 4-port KVM Switch
I'm having the same problem. Mouse works great but the keyboard doesn't. I've uninstalled and reinstalled the software at least twice via remote desktop- done a hard reboot on the hardware (it's a Logitec wireless keyboard) - I've even tried installing it on another computer and the keyboard and mouse both work great! I just can't get it to work on my computer. The curious thing is that the side buttons (like sleep work) but it won't Ctrl Alt Del so I can login - what am I doing wrong? Are there settings that need to be changed?
Aug 17, 2007 | Sakar 62150 Keyboard
Sakar IConcepts Windows 107 Keyboard (16252) Logo
959 people viewed this question
Top Sakar Computers & Internet Experts
micky dee
Ravi
Are you a Sakar Computer and Internet Expert? Answer questions, earn points and help others
