Question about Haier HLP21E Top Load Washer
I have a Haier HLP21E washing machine. The drain hose is broken and I need to change it. I have the replacement hose. How do I change it?
  • dugie972 Aug 27, 2010
    I paid $20 for the comment by tiger56h? That's all I seen in 24 hours. What a rip off. That guys a master? what a joke.
  • 176 Answers
Can you do that
bay onw fram D&L stor and cheange it
Posted on Aug 26, 2010
Water is running out of the hose
What hose? Intake or drain hose?
If the drain hose makes sure you follow the user manual and set the drain end to the proper height. If it is too low you will not be able to fill the washer. It will just continue draining.
Jul 23, 2013 | Haier HLP21E Top Load Washer
My Haier HLP21E top load washer is only one month old, and there is some leaking from under the machine.
Check the hose clamps on the bottom. Sometimes the clamps are not all the way on or tight enough. I saw one that did the same thing.
EDIT: one of the mounting screws on the bottom of the tub will create a "tear" (or another word that rhymes with track) in the tub (Fixya says "The word $@#%^ is considered as profanity on Fixya. Please review your answer and try again").
I used a plastic soldering iron from Harbor Freight and cut a piece of the plastic webbing off the tub to "solder" the hole shut on the tub.
Aug 22, 2012 | Haier HLP21E Top Load Washer
My washing machine can't store water. When I press the start buttom, water was coming in, and just keep draining. It didn't stop until press the pause buttom or unplug it. It worked very well before...
Hi- It sounds like the water is siphoning out the drain hose. Make sure the Drain Hose has a loop in in above the level of the highest point of water inside the washer tub. Hope this helps.
Sep 23, 2010 | Haier Washing Machines
Will not hold water ,when filling it just drains out
I just had this problem also. The reason I was having this problem was that I was letting the draining hose run into my bath tub to drain. Because of this the water was immediately draining out of the washer. So I had to hook the draining hose onto my bathroom sink to drain. By raising the hose higher,the washer filled up with water and worked just fine. Hope this helps.
Jan 24, 2010 | Haier HLP21E Top Load Washer
Error e1. washing machine will not drain. The tub is full and between the wash and rinse.
Two problems. Step one check the drain pump motor, to see if it draining the water out. Next step if the drain pump working you have a clock in the hose between the drain from the tub to the pump. Messy job witht he machine being full of water. I suggest take a small bucket and empty try to empty it out as much as you can.
Aug 10, 2009 | Haier HLP21E Top Load Washer
How long is the fill and drain hose for Haier HLP21E washer?
No need to worry, you can get a new inlet hose & drain hose of any length at any major hardware store. I have the larger Haier outside my kitchen & got a 10' drain hose & inlet hoses & this same situation was instantly solved...
Howard
Feb 19, 2009 | Haier HLP21E Top Load Washer
Draining extra water
Cut off the zip tie that holds the drain tube. Bring the drain tube as close to the ground as possible and siphon out the water - yes, that means sucking on that hose. Have a bowl handy to collect the water, or do it somewhere you don't mind getting wet. Just keep the end of the hose lower than the basin of water and you should have no problems.
Oct 10, 2008 | Haier HLP21E Top Load Washer
No Drainage Stoppage?
The drain hose has to be higher than the full water tub level or it will keep draining out make sure your hose is high enough
Feb 06, 2008 | Haier HLP21E Top Load Washer
Haier HLP21E Top Load Washer Logo
128 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
