The headphones only work when I wiggle the jack in the player.
  • SaritaJAY Nov 16, 2008
    The sound is screwed down slooooow and quiet until I pull and hold the headphone jack to the left. This isn't the first problem: The play button doesn't work half the time so I browse in order to gat hte music started.
  • edgrassroots Dec 28, 2008
    aside from getting better headphones, what might be the solution
I too had that problem and when I took it in to be repaired, I was told that the unit was out of warranty. So I fixed it myself. This is what I did:
1. Removed the back and the battery
2. Removed the the top cap that holds everything in place.
3. Removed the on/off/lock buttom
4. Removed the two small screws from the top
5. Removed the unit from the case. This was a little tricky and took some finagling.
6. Once removed you see the circuits. I removed the part with the jack which had a metal covering.
7. Removed the metal covering which had two small screws.
8. The connectors in the jack I scrapped with my tiny screwdriver and I pushed them in more to make a tighter connection when the headset goes in.
9. I put everything back together and voila! The chit is working like new.
If you're not brave enough to do this yourself, ask a friend who is tech savy and a do it yourselfer.
Good luck.
Posted on Mar 15, 2009
    Problem Solver:
  • 8 Answers
I have a ZVUE Spirit MP3 that has speakers but when i hook in headphones it only comes out of the right earphone and still out of the speakers. does anyone on here know anything to help?
Posted on Jan 10, 2010
The Sansa's are notorious for the headphone jacks failing.
Posted on Aug 04, 2008
    Problem Solver:
  • 19 Answers
Try getting better headphones
Posted on May 06, 2008
3 Suggested Answers
SOURCE: small headphone jack on crap headphones from Brookstone.
i used a cellphone adopter when my headphones broke.
Posted on Dec 04, 2007
  • 8 Answers
SOURCE: HEADPHONE JACK DOES NOT WORK
what kind of headphones do you have??? some Mp3s cannot supply enough power to those big headphones out of the market right now... try to use a earbud or earphone first and if they are not working it means that the jack is defective
Posted on Sep 07, 2009
I have a 2002 Chrysler Town & country and I can't get the sound to work for the Vcr/player Without headphones. How do I get the sound without the headphones?
I had one of these and it turned out to be the headphone jack, when you put the headphone plug into the jack it disables the speaker and when you unplug the headphones it enables the speaker. There's a contact in the jack and it is probably stuck to headphones. The jack may need to be replaced. Try and wiggle the plug a few times but not hard as it may break from the curcuit board.
Oct 19, 2014 | Cars & Trucks
No sound on spi mp3 player
All it will be is bad soldering to the headphone jack inside the player. If you have a soldering iron you could do it yourself. The problem will however be getting inside the player. If you can't do it yourself, it shouldn't cost too much to have it fixed.
Nov 21, 2011 | Audio Players & Recorders
No sound, worked fine for 9 -10 months.
could be that your headphone jack has gone out most likely this is whats wrong try diffrent headphones and wiggle it around in there and see if it helps
Sep 12, 2009 | RCA TH1611 MP3 Player
How do I fix a bad connection with the headphone jack on my ipod touch? When plugged in, the music is static-y. It is definitely the headphone jack that is the problem.
Hi, this seems to happen on a lot of mp3 players , usually when you wiggle the headphone in the jack the sound cuts in and out, its the result of the headphone jack bending the metal contact inside the player or can be due to a build up of dirt/ grime in the socket.The problem generally gets worse as time goes on
if you have tried it with different headphones still get the problem and its still under warranty I would get on the apple site or down to you local apple centre and try and get a replacement.
Sometimes a spray of deoxit (plastic conductive lubricant /cleaner)
in the socket does the trick , but I would strongly reccomend trying to get a replacemnt
Jul 23, 2009 | Apple iPod touch
When i put my headphones into the mp3 the left side does not work
THE HEADPHONE JACK INSIDE YOUR PLAYER IS BENT AND NEEDS TO BE SENT OUT TO FIX! IF NO WARRENTY BUY A NEW ONE ,IT WILL COST AS MUCH TO FIX!
Dec 01, 2008 | Insignia Sport MP3 Player
Headphone connection
Common to all mp3 players - there are a few videos on YouTube purporting to show you how to fix the headphone jacks, but they usually don't work. Replace the mp3 player is the only solution.
Aug 22, 2008 | SanDisk Sansa m240 MP3 Player
Sound Problem with Headphone
First try the headphones in a different machine, such as an mp3 player or cd player to make sure the headphones still work.
Try going to the start button, then settings and control panel. Then select "Sounds and Audio devices" Down at the bottom you should see "Speaker settings." Click the "Advanced" button and then select stereo headphones.
Then, place the headphones into the green audio jack (or the headphone jack up front if you have them), play some music, and then gently wiggle the jack to see if some of the sound makes it into the headphones. If not, try slowly pulling the headphones out of the jack while the music is plaaying. you might find that the jack has slipped a little and may play only if your connector is slightly pulled out or more firmly pushed in. If his helps, then your audio connector is loose and you should replce the sound card. If the card is on the motherboard, you can disabled it when you put a new card in.
Jul 09, 2008 | Compaq Presario 700 470024-192 Notebook
MP3 PLAYERS ARE MADE CHEAPLY!
I have one that had the same problem. I solder the jack back on but noticed that the solder pad came off the circuit board. Look at the circuit board and find the component where the connection from the solder pad leads. Using a piece of wire you should be able make a new connection. even after Soldering the jack back on, check to see if the pads inside the jack are bulging out enough to connect to the headphones. The constant wear and tear from rocking the headphone jack back and forth is what causes it to "brake". Could happen when its on your pocket.
Apr 11, 2008 | Samsung YP-U2JQB MP3 Player
Headphone jack problem
Most likely the solder points inside the unit where the headphone jack attaches to the system board have come undone. If you know how to solder, you could open the unit and fix it. If that is not an option, you could resort to using the other headphone jack instead assuming it is not damaged as well.
Apr 10, 2008 | Insignia NS-DV2G MP3 Player
186 people viewed this question
 Grubhead
Grubhead
