Question about Toshiba 43H70 43" Rear Projection Television
Good picture but no color
I have a good picture but it has no color. All the menu's are in color but the picture itself is black and white. I have tried all video inputs and antenna inputs and still get the same. It will flicker with color if I bang it on the back or side. lol What would be causing this? Thanks ahead of time.
  • David Goodson
    David Goodson May 11, 2008
    The problem is not in any menu's. There is something loose inside. Like I said, when I bang on the side of the tv, the color will flicker on and off.
  • 3,037 Answers
Check in the TV settings menus for the color mode. Other tvs have the option to the output to either black and white or color.
You may have to go into the service menu to get this working
Let me know if you need any further help
good luck
Posted on May 06, 2008
  • Benjamin Patri
    Benjamin Patri May 07, 2008
    Please don't forget to let me know your thoughts about my solution.
    If your problem is fixed, please rate this solution as that is one of the biggest
    aspects of how this website works and in order to receive any credit in
    helping you, I need to be rated.
    Otherwise, let me know if you have further questions and I would be glad to help.
    Thank you
    Brigadier General:
  • 6,966 Answers
Initially, have you tried a full hard reset? If not, pls unplug from the mains. Most current devices would reset and revert back to factory default settings (assuming no internal hardware fault) when unplugged for a considerable period of time (from a few minutes to a couple of hours).
If the above does not prove to be corrective, you may have to consider:
1. demand service from an authorized service center if the unit is still under warranty;
2. seek onsite services of a qualified professional; or
3. consider a DIY (do-it-yourself) which would require access to a service manual or at the very least a schematic diagram, familiarity with electronic components and circuitry, a DVM and possibly as soldering iron.
From initial search, it would seem that this is a common issue with some Toshiba models.
Hope this be of initial help/idea. Good luck and kind regards.
Thank you for using FixYa.
    Genius:
  • 1,665 Answers
Check your user guide troubleshooting . Is ntsc system?
    President:
  • 2,267 Answers
There is a loose contact somewhere in the color circuitry of your TV. Specially where the color oscillator is or it could the 3.58 Mhz Crystal that is defective.
A cold/crystalized solder joint will cause this failure too.
Poor viewing quality
By poor color quality, do you mean that if you turn the color control all the way down, the black and white picture is more like black and red, green or blue - or do you have a good black and white image? If the B&W image is good, and the TV is an old (8+ years) one, maybe the mirror inside the set needs a good cleaning - especially if there are smokers in the room. If you have a B&W picture that is tinted, then you may have to go into a service menu to adjust it back to a better picture. Hard to guess the problem without more specific description of symptoms.
Jul 17, 2012 | JVC HD-56G787 Television
I have what I think is a Hitachi 55 inch ultravision rear projection TV that is 12 years old. I think the model is 55UX58B. The color goes out and it becomes black and white. It comes back after a few...
When the tv is it totally black and white and the tv picture are good and clear wright?when the tv colors are fade in and out are clear up and when the tv picture it is in colors it is look good normal picture wright?Tv have no shadows of any kinds of colors when picture are good in colors wright?Yes,take ur hand make fist or take a wooden hamer bangs all around the tv bazel frame if the tv colors come back or tv stay in colors it is have good picture in colors.Tv it is still good just have components parts are cold soldering or CRT colors guns R,G,B just require resoldering works only.
Aug 22, 2011 | Hitachi 50UX57B 50" Rear Projection...
E50A10; color become not natural. The red look too strong. Seem like un-balance white balance (white color shown not clearly white but too much red)
Good day!!
I am suggesting you to hit the menu button on the tv itself or on the remote...
then the following will appear:
sound
set up
when you see that please hit the picture then you will read the
AV mode please hit that by hitting the arrow next or up and down volume button so that you can pick what mode do you want also you can change/adjust the bright, contrast,sharp,color, tint...
hope it helps...thank you..
Jun 17, 2011 | Sony Televison & Video
What is a good Microwave Leak detector - make  absolute measurements? Can a cell phone be used to detects leaks from Microwave ovens.?
I replaced two convergence chips the resistors were all fine. This took care of the 3D look. I also replaced the coolant in the blue and green although it was the blue which was badly contaminated. The picture is now clearer than before but I am unable to get color. I can see vibrant colors when I pull up the TV's menu. I can see the colors in the convergence menu as well but no color in the picture. The color controls only make the picture brighter or darker. It is sepia in color not black and white. What could this be?
Feb 22, 2010 | Philips 51PW9303 51" Rear Projection...
No color only black and white picture
one of your color tube has gone out on you.
Jan 25, 2009 | Hitachi 43F300 43" Rear Projection...
The picture is in black and white but menu is color
you might have the colorwheel checked to see if its bad
Nov 03, 2008 | Sony KP-51WS500 51" Rear Projection...
Having problem with getting the color and contrast right?
Good Day;
Turn your color down all the way, do you get a good Black and White picture with good black, white and grays? If not your picture tube may be going bad. It can be adjusted sometimes to get a 'better' picture.
If picture is a good B&W; adjust britness level: 50% > contast: > 90/95 % >color: 50%.
Good Luck, big IRISH.
Sep 25, 2008 | Televison & Video
Bad color
Turn the color level all the way down and see if you have a good black and white picture. If your screen isnt black and white it should have a predominate tint to it. then turn the screen control for that color down to achieve the best black and white picture. then adjust your color level that should help.
Jun 13, 2008 | Mitsubishi WS-48311 48" Rear Projection...
Red , Green And Blue.
Heres the best way to set a phillips screen controls. Go into the picture controls and set picture or contrast to roughly 75%, then set brightness to 50% and then set the color level completely off. Then adjust the screen with the 3 color controls untill you recieve the best black and white picture as possible. If you are unable to achieve a good black and white picture change the coolant in the green and blue tubes. But if you can get a good black and white picture stop there then turn your color level back up and the picture should be correct. Let me know if you need further assistance.
May 22, 2008 | Televison & Video
Toshiba 43H70 43" Rear Projection Television Logo
48 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
