Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Drive belt replacement for 502-25-1220 lawnmower
How do you replace the piece that the belt an blade are attached to on a mountfield RV 150
you talking about the self propelled model
Repairing Lawnmowers For Profit Part 55 Replace Mountfield Lawnmower Drive...
the blade is a one piece ..you take that off
take off the belt cover
if really stuck .. use a puller for the pully/blade boss
remove the back plate to get to the idler tension pully
there was a tension device or ider pully and spring
for the belt tension
Jul 03, 2016 | Garden
What is the drive belt diagram for a model 616 grasshopper lawnmower
check the deck carefully it might be written on the right side
Sep 18, 2014 | Garden
How to change the belt on a craftsman rear wheel drive lawnmower
open drive cover take plug out roll belt off pully by pulling it to the side and hand turnig the blade after comes off drive remove blade and take off belt to reinstall do reverse
Aug 28, 2014 | Craftsman Garden
Lawnmower wheels won't drive
If its a riding mower it probably the drive belts off track or slung off. The mower will still start up and turn blades with the drive belt off, but want engage to go forward or reverse if this is the problem.
Aug 17, 2013 | Garden
How to replace drive belt
you buy other belt
May 30, 2012 | Garden
I need the size of the poly v belt for a qualcast 4000 lawnmower.
Most time you don't have to get original parts like belts from the manufacturer. Suggest you go to a reputable lawn and tractor supply store where they can easily measure the belt and give you a comparable one for your machine. Hope this helps!
Mar 26, 2012 | Computers & Internet
My husband was injured and cannot replace the main drive belt for our riding lawnmower. Is there a place to get the schematics of how to put it on? If I have a picture I can do it. Model 917271041,...
Normally the belt diagrams are in the owners manual. Seeing this is a 12 year old machine the diagram stickers are possibly gone, but the drive belt diagram is normally on the bottom side of the foot rest, and the mower belt is on the top of the mow deck. Both are typically on the left side of the tractor as you sit on it. Please vote 4 thumbs up. Thank you.
Here is the link to a typical 42" Craftsman mow deck belt:
http://www.askmehelpdesk.com/attachments/tools-power-equipment/21777d1247094945-craftsman-lawnmower-belt-diagram-aypwobrk.gif
Oct 16, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
How do you replace drive belt on a hydrostatic transmission craftsman riding lawnmower that has slipped off or my be broken.
Its not a hard job just push in clutch and lock it, remove mower belt then replace drive belt and then put mower belt back on and release clutch.
Jul 17, 2010 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Are all drive belts on lawnmowers compatible I have ariens ride-on lawnmower
All belts are not created equal. I recommend staying with the manufacturer's belt. Riding mower belts have to take a lot of torque when engaged and a lesser belt will have much less life. You may end up changing belts several times to learn a valuable lesson.
May 01, 2010 | Ariens 34 In. Zoom Series Riding Mower
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
48 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
