Question about Jet 3 Ultra Power Chair
How to remove the seat - Jet 3 Ultra Power Chair
  • 692 Answers
Bubba, Under the front of the seat is a latch that you must release there is a rubber block that must be rotated forward to be able to release the two little knobs that it is wedged between Rotate the knobs inward and lift the front of the seat. the seat will flip toward the rear of the chair and you now have access to the batteries. to remove the seat disconnect the joystick cable from the base and slide the seat forward after you have it tilte back and lift it off the base. Hope this helps you
Posted on Aug 28, 2010
How to remove back seat in 1972 buick skylark
Remove the seat cushion retaining bolts, detach the seat cushion and remove it up and out from the vehicle.
Remove the rear seat back retaining bolts at the bottom of the seat back. Pull up then out to disengage the upper frame from the hangers and remove seat back from the vehicle.
Installation is the reverse of removal.
Courtesy: Haynes GM repair Manual #38025. You can probably find a copy of it on Amazon or eBay cheap
Jun 20, 2011 | Buick Skylark Cars & Trucks
How to remove bottom of back seat need to remove seat to remove rear shocks..
PUSH IN CENTER FRONT EDGE CUSHION TO DISENGAGE PART OF SEATS WIRE FRAME FROM CLIPS.WITH CLIPS UNHOOKED LIFT UP AND REMOVE SEAT.IF REAR SEAT NOT HELD IN PLACE WITH CLIPS. LIFT UP THE REAR SEAT CUSHION AND PIVOT IT FORWARD. DETACH THE RETAINING BOLTS AT THE LOWER EDGE OF THE SEAT BACK AND IF NECESSARY REMOVE THE SEAT BELT ANCHOR BOLTS.LIFT UP ON SEAT BACK REMOVE IT..
Feb 06, 2011 | Jaguar X-Type Cars & Trucks
How do i take the back off on a 1999 nissan maxima bucket seat
Hi, follow the instruction below......
Rear
See Figures 3, 4, 5 and 6
  1. Remove the lower seat cushion by pulling straight up on the front portion and disengaging the clips. Then hinge the seat upward to release the rear clips.
Fig. 3: Pull up on the front of the lower seat cushion and disengage the clips
  1. Remove upper rear seat back-to-chassis bolts.
Fig. 4: Remove the bolts behind the center armrest ...
Fig. 5: ... and the bolts on the lower corners ...
Fig. 6: ... Then pull up on the seat to disengage the three clips on the top of the seat
  1. Remove rear seat back by tilting forward and pulling straight up.
To install:
  1. Install the lower seat cushion and torque the lower rear seat-to-chassis bolts to 15-20 ft. lbs. (21-26 Nm).
  2. Install the upper rear seat back cushion and torque the upper rear seat back-to-chassis bolts to 15-20 ft. lbs. (21-26 Nm)
Jan 19, 2011 | 1999 Nissan Maxima
Remove front seat
SECTION 501-10: Seating 1998 Escort/Tracer Workshop Manual REMOVAL AND INSTALLATION Seat —Front Removal
NOTE: Driver side seat shown, passenger side seat similar.
  1. Slide the seat to its rearward position.
  1. Remove the front seat track to floor front bolts.
  1. Slide the seat to the forward position.
  1. Remove the front seat track to floor rear bolts.
  1. Disconnect the safety belt warning indicator switch electrical connector.
  1. Remove the front seat.
Dec 06, 2009 | 1998 Ford Escort
How to remove rear seat in 1996 dodge ram 1500
REMOVAL & INSTALLATION
  1. Clamp the seat belts to keep them from retracting.
  2. Locate and disconnect seat wiring at the connector(s).
  3. Move front seats forward or back for access to the hold down hardware.
  4. Put the rear seats in the stowed position.
  5. On Durango 3rd row seats, lift the cushion upward and forward to floor cargo position.
  6. Remove the hardware securing the seat.
  7. On split bench models, lift the center seat upward to clear attachment stud
  8. Remove the seat from the vehicle.
NOTE Do NOT activate the track adjusters once the fastening hardware is removed.
  1. Installation is the reverse of removal.
Fig. Disconnect the wiring from under the seat
Fig. Seat track mounting hardware locations-typical
Fig. Bench seat components: seat (1), nut (2), stud (3), floor pan (4), bolt (5)-Ram
Fig. Split bench seat assembly-Ram
Fig. Bucket seat mounting components-Durango shown
Fig. Rear seat removal/installation
I hope help you with this; good luck (rated this help).
Aug 31, 2009 | 1996 Dodge Ram 1500 Club Cab
Middel seatbelt will not loosen
I think you have to remove headrst bfore folding seat back down. You may have to unbolt seat from floor. 4 bolts.
Rear Seat Backrest —Split Bench Removal
NOTE: The 40% rear seat backrest must be removed before the 60% rear seat backrest.
  1. Remove the 40% rear seat backrest.
    1. Remove the nuts and bolts.
    1. Remove the backrest.
  1. Remove the 60% rear seat backrest.
    1. Remove the nut and bolt.
Installation
NOTE: The 60% rear seat backrest must be installed before the 40% rear seat backrest.
  1. NOTE: Do not tighten the nut and bolt at this time.
    Install the 60% rear seat backrest.
    1. Install the rear seat backrest.
    1. Install the nut and bolt.
  1. NOTE: Do not tighten the nuts and bolts at this time.
    Install the 40% rear seat backrest.
    1. Install the nuts and bolts.
60/40% rear seat backrest
  1. Tighten the 60/40% rear seat backrest nuts and bolts in the sequence shown.
40% Rear Seat Backrest
  1. Tighten the 40% rear seat backrest nuts and bolts in the sequence shown.
Jun 11, 2009 | 2005 Ford Escape
Mustang rear seat removal?
please rate highly if this is what you need
Section 01-10: Seats and Tracks 1994 Mustang. Workshop Manual
REMOVAL AND INSTALLATION Seat Cushion, Rear Removal and Installation
  1. Release pin from locks by pressing release button under rear seat cushion.
  1. Pull rear safety belt and buckle (60044) through openings in rear seat cushion pad and frame (600A88) and remove rear seat cushion pad and frame .
  1. To install, reverse Removal procedure.
REMOVAL AND INSTALLATION Seat Back, Rear Sedan
Removal
  1. Remove rear seat cushion as outlined.
  1. Remove rear seat bolster. Refer to Section 01-05 .
  1. Remove rear seat bolster mounting bolts. Remove bolster assembly.
  2. Remove four seat back to package tray retaining bolts.
  1. Remove seat back.
May 04, 2009 | 2004 Ford Mustang
How to remove the back seat from my 1998 Mercury Villager
it is not designed to be removed. It is designed to slide back and forth as needed.
Section 01-10: Seats and Tracks 1998 Villager Workshop Manual
REMOVAL AND INSTALLATION Seat, Rear Bench
Removal
  1. Remove the center seat(s) if equipped. Refer to the procedure in this section.
  1. Slide the bench seat forward to the center row seating position.
  1. Use a flat-blade screwdriver to remove the cover caps from the front of the rear seat cushion latch cover.
  1. Remove the two rear seat bolts from the front of the rear seat cushion latch cover.
  1. Lift the rear seat cushion floor cover on the back of the rear bench seat and remove the two inboard rear seat bolts and the two outboard rear seat bolts.
  1. Remove the bench seat from the vehicle through the body side door opening.
Apr 30, 2009 | 1998 Mercury Villager
I want to make my 1999 Mercury Villager Sport into a cargo loader, with just the front seats kept and the rest of the back empty. How do I remove the other 3 seats? So far, I can't get any of them to budge...
the middle seats come out easily. There are 2 handles you have to lift up on each of the bucket seats, they are in the front of the seat down by the seat tracks. After you lift them, tilt the seat upward in the front and rotate them backward. Then lift out of the hooks. Each seat is held down by 4 hoks.
The 3rd row seat is not designed to come out xcept by a technician. It does slide forward all the way up to the front seat. It has a sliding seat track.
First, lift the T handle under the seat cushion on the left front side of the seat. This will allow you to lift the seat bottom up all the way to lcok in the full up position.
Then, lift the lever on the same side of the seat and slide the seat forward. It will stop in 4 places.
Rear -Rear
6 inches forward of that.
another two ft to the second row seating position
full frward against the front seats.
Pleae rate as fixya if this helps.
c4253aa.gif Seat —Third Row Bench Removal
sxv~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Removal of the third row bench seat requires more than one technician.
  1. Remove the second row seats. For additional information, refer to Seat—Second Row .
  1. Remove the floor mats.
  1. Lock the seat cushion in the upright position.
    1. Lift the handle to release the cushion.
  1. Move the third row bench seat to the second row position.
    • Lift the seat track release handle.
  1. Remove the two bolt covers.
  1. Remove the two seat track front bolts.
  1. Remove the four seat track rear bolts.
    1. Position the rear seat cushion floor cover aside.
  1. Remove the third row bench seat.
Mar 02, 2009 | 1997 Mercury Villager
Seat Belt repair/replace
  1. Remove front seat.
  2. Remove adjuster cover. A
  3. Slide floor anchor cover.
  4. Remove floor anchor bolt. B
  5. Remove shoulder anchor bolt. C
  6. Remove front and rear kicking plate, then remove center pillar upper and lower garnish.
  7. Disconnect seat belt pre-tensioner connector.
  8. Remove the screw securing seat belt pre-tensioner retractor, then remove seat belt and seat belt pre-tensioner retractor.
  9. Remove bolts securing seat belt adjuster, then remove seat belt adjuster. Reverse procedure to install.J
Nov 03, 2008 | 2000 Nissan Maxima
Jet 3 Ultra Power Chair Logo
147 people viewed this question
Top Jet Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
MobilityRepairSpecia...
Level 1 Expert
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
