Question about Whirlpool Dryers
WHEN INSTALLING A DRYER, IF THE APARTMENT HAS NO WASHER DRYER CONNECTION, DOES THE DRYER NEED TO BE INSTALLED BY A WINDOW ?
  • 139 Answers
Not really; but the vent hose has to vent out side some how/ put the dryer where you want it run the vent hose to outside..good luck /joe/
Posted on Aug 26, 2010
Dryer not getting hot / washer won't run unless dryer on.
If these are separate units, you might have an electrical wiring problem in your house or apartment. If one unit (washer with dryer above), check to make sure the power cord is firmly attached to the terminals. Many other possible causes, too.
Apr 02, 2016 | GE Spacemaker GTUN275EMWW 27" Electric...
Balay washing machine door wont open
We were staying in a holiday apartment and couldn't get the Balay washer/dryer door open on dryer cycle. Tried all the previous solutions and none worke. my husband turned the power off to apartment at fuse box and the door clicked open after a couple of minutes.
Feb 18, 2014 | Washing Machines
Apartment size washer dryer. I have the chance to
Formed in 1976 in Winston-Salem, NC, the Crosley Corporation consists of a group of independently owned distributors who resurrected the Crosley trade name and introduced a line of refrigerators, freezers, ranges, dishwashers, air conditioners, and other appliances. We carried the heritage of such features as "Shelvador" and "Conservator" that were marketed for decades.
Sep 27, 2013 | Crosley Dryers
I just moved into an apartment and have a Bosch front load washer and dryer. I'm not sure if I'm putting the soap, bleach and fabric softener in the correct trays . There are three slots and I
I am not sure of the dispenser trays but if the clothes are taking to long to dry and are still damp, check the vent hose and the duct work going out the apartment for lint buildup.
Oct 14, 2012 | Bosch Axxis WFL 2060 Front Load Washer
I have used tedx640eq0 whirlpool dryer. Just moved into a new apartment that had a 3 prong plug. I connected the 2 hot's and put the ground on one of the ground terminals at the new 4 prong socket that I...
The reason for the 4-wire plug/socket system is that in the older 3-wire units, cabinet 'ground' was actually 'neutral' carrying current for the 115 volt parts of the dryer, while the two 'hots' were supplying 230 volt power for the heater and motor. This allowed a voltage difference between the dryer cabinet and true ground. How did you wire 3-wires (coming from the apartment electrical panel) into the 4-wire dryer socket? Dryer cabinet ground should go to true ground at the electrical panel, and dryer neutral should go to electrical panel neutral. Did Whirlpool violate the separation of 'neutral' and 'ground' when the machine was made (did the timer neutral connection go to cabinet ground instead of machine neutral or is the timer motor stuck)? Your dilemma would be answered by having the apartment owner hire a licensed electrician to upgrade the dryer service to 4-wire specifications. The ground to neutral connection you mentioned may make it work, but you will wind up with the 'hot' cabinet condition that the 4-wire setup was supposed to alleviate. Hope some of this helps!
Jun 04, 2010 | Whirlpool TEDX640PQ Dryer
Haier washer/dryer combo not drying clothes
Check things like the Filter / clear fluff...Make sure outlet hose if any is not kinked and passing air..Hope this helps..
Oct 02, 2009 | Haier 14.3 lb. Washer/Dryer Combo
I have front loading washer/dryer;need to install pedestals.
Yes!!!! Do not lay the machines on their backs with out the shipping bolts/hardware installed..Major damage will occur!!!!!
clarkco
Feb 28, 2009 | GE WBVH6240F Front Load Washer
Electrical how to make it to 120v.
The drive motors for the washer and dryer run off 120 VAC, but the heating circuits require 240 VAC in order to work. You will need to have a 240 VAC outlet installed in order for the appliance to run properly. There is no conversion for this. This is the way the appliance was made.
Oct 07, 2008 | Kenmore 98702 Stacked Washer/Dryer
Clothes-snagging dryer
first check for any sharp edges, look inside around back and front of drum the felt seals could be bad.
Aug 07, 2008 | Kenmore 98702 Stacked Washer/Dryer
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
